Have you recently purchased a new car or are you trying to and struggling to find affordable options? A reporter would like to speak with you; please reach out to [email protected] by 5/26 for more details.
Isuzu Trooper Alarm Systems
HI..I need some help on this issue please...I have a 2000 isuzu trooper that I really love, but I started to develop a problem when I go to lock the vehicle with the remote. usually you hit the lock button once for the locking of the doors and then twice to activate the alarm. the horn then beeps a couple times and you are ready to go...now if you would have a door open or something, it would beep at you multiple times telling you something is wrong...i have checked all of the doors, replaced the batteries in the remote and it still wants to just beep like crazy at me..it will lock the doors, but I imagine the alarm is not getting set...please help any suggestions would be greatly appreciated
2000 Isuzu Truck Trooper LTD V6-3.5L
Vehicle Level Accessories and Optional Equipment Antitheft and Alarm Systems Description and Operation
The circuit consists of the starter switch, anti-theft & keyless entry control unit, anti-theft horn, front door and tailgate key switch (detect and tamper switch), door lock (& power window) switch, door lock actuator for each door, engine hood switch, clutch start switch (M/T), ANTI-THEFT indicator light and mode switch (A/T).
The system operates as follows: After locking the starter switch and removing the starter key (this sets the alarm), if the door is unlocked in any way other than with the proper key, the headlights start flashing, the horn sounds, and the starter circuit is disabled. (However, the engine hood and all the doors must be locked and closed.)
Once the system has been placed in the warning or alarm condition, it can be released only when the starter switch is shifted from "OFF " to "ACC" by the starter key, or when the lock of the front door or the tailgate is released (to activate the detect switch) by the starter key.
Vehicle Level Accessories and Optional Equipment Antitheft and Alarm Systems Description and Operation Circuit Operation
The Anti-theft System consists of the following components:
Anti-theft and Keyless Entry control unit
Left and right door switches
Left front, right front, and tailgate door key detect and tamper switches
Tailgate switch
Engine hood switch
Door lock actuators
Left and right front door lock switches
Lighting relay
Starter relay
Headlights
"ANTI-THEFT" indicator light
Anti-theft horn
The arming sequence is initiated with the starter switch in the LOCK position and all doors closed. This results in all theft related switches to be open to ground. The "ANTI-THEFT" indicator then flashes for about 30 seconds or until the arming sequence is completed. When the driver's door is locked using the door key, the door lock actuator internal switch will open, removing the ground signal from the anti-theft and keyless entry control unit input. Now all inputs to the anti-theft and keyless entry control unit are open to ground and the "ANTI-THEFT" indicator stays lit for about 8 seconds . The anti-theft system is now armed. If any of the theft related switches are grounded, the theft alarm is activated. The anti-theft and keyless entry control unit does not allow the vehicle to be started by not applying ground to the starter relay. The anti-theft and keyless entry control unit pulses a ground signal to the lighting relay causing the headlights to flash. At the same time, the anti-theft and keyless entry control unit pulses a ground signal to the anti-theft horn, causing it to sound. The system alarm is cancelled when the anti-theft and keyless entry control unit sees battery voltage at its ignition input or a ground signal at its key detect input.
I first unplugged the impact sensor . Next day at work the alarm just went off. I unplugged the omega control box. I thought I had a bad sensor. Early the next morning the horn on the trooper went off . Neighbors are getting upset.
The battery is good and hot. I've checked all the doors with the dome light. The all work. I checked the hood latch and the back doors.
I would appreciate any suggestions
thank in advance
GR
boe
I have tried to program the remote many times and even went back and asked for a replacement for the remote and got the secone one and tried to program it and nothing.
1. What is the proper way to program the remote?
2. Where is this unit so if I want to replace it I can?
3. Are there any tests that I can perform to know if the unit working correctly?
Thanks for any and all help.
Popz
When I push the Torque on Demand button on the dash of my 2000 Trouper instead of the display going to Auto and everything turning green, I get a red error where it usually would show Auto.
Does anyone have any thoughts as to what is no working correctly? and hopefully it won't cost a fortune to repair the problem.
Thanks for any of your help.
Popz
Never have found what is causing this and also not being able to program my remote or when I want to put it in "Auto 4 wheel drive" I get an error and it just stays in rear wheel drive.
