Lexus LS 400/LS 430 Instrument Panel Questions
in Lexus
I've got a 94 LS 400 with 130,000 miles and lately the dashboard lights won't come on unless it's warm outside or after the car has warmed up quite a bit. With winter coming soon warming the car enough may not happen since I only drive about 4 miles to work each day Since the gas gauge stopped working about 3 years ago I use the mileage and the low fuel light to tell me when to fill up. Without the lights that makes it near impossible to know when to fill up. Anyone with ideas?
OTH, there is the low-tech way a former co-worker used: Keep a written log of last fillup and miles driven since then, provided your odometer still works. You'll need to know the MPG you're getting, and then do the math.
My '05 LS has a digital LED readout on the odometer requiring dashboard lights ... I don't know about the '94 LS.
Old age is rough, isn't it, even for cars.
regards,
cinci1
tjpatpdg@yahoo.com
By the way, welcome!
Everytime I start no action in the needles and no lights on Dashboard. I have seat belt light on and i can see the transmission lights (Park, Drive, Reverse) lights blinking.
Any advice/Help would be appreciated.
George
It worked when i removed the negative lead and let the system reboot. Amazing! Thank you very much George.
Although, i have new problem which is my ODO showing as 3098 instead of somewhere around 92000. Is there way to display correct ODO??
I can drive safely now. Thank you again
Sorry, can not help you with the ODO, but hopefully someone out there can! Might also try the Toyota Avalon forum.
George
I had some service done to my car, and I assume they must have left the battery terminals loose, because the other day I was leaving work and the car wouldn’t start. It was totally dead. Once I jiggled the battery terminals, everything seemed to be fine... Until I noticed that the instrument panel was no longer lit or working. The car is in the shop again right at this moment, and they’ve told me I need a new instrument panel or something crazy like that. I was awaiting a call back for the price quote when I decided to Google some info, and it led me here. I can’t describe the elation that I will have if this little trick solves my problem. Seems to be the same situation (battery disconnected, cluster no longer lights), so I’m very optimistic. I’ll let you know, but if there’s any advice you can offer in the meantime (before I get to my car and try this out), please chime in! Thank you!
I got the same story about repairing or replacing the instrument panel. Fortunately, this worked for me!
George
The car runs perfect. Also had him put in a new alternator. He did not hook all the wires on the alternator. Drove 150 miles and the car stop. It was running on battery only. All the lights came on dashboard. Radiator, brakes, battery etc. He fixed the alternator but all the lights are still on the dash board. He took battery cable off and lights on dash board went off but came back on again.
The battery is almost new. Do you think the problem can be the defected battery cables could be causing the problem. He charged the battery and ran the car. Next day would not start and battery was dead.
Please do me a favor and if any one can think of what is wrong let me know. The car runs perfect and every thing seems perfect but the lights on the dash board will not go out. I can not get the car inspected until the lights go out. I would appreciate any help or suggestions.
Thanks, Paul
Thanks again
Tony
1993 Lexus LS 400 V8 Two Wheel Drive Automatic
My dashboard lights flicker on and off constantly sometimes the dash goes completely black. Cant see anything and don't know how much gas I have and how fast I am going. Dash lights do not work on cold/damp mornings until the car warms up, Takes about 50 miles to drive in cold weather and 5-10 miles when it's warm. Dash lights never turn on until the temperature reaches good temperture. Also I have problem which my ODO, sometimes it's mixed up . Is there way to display correct ODO?? Any help would be most appreciated. Thanks
Gwen
I'd suggest you go to Lexus owners' boards or eBay and look for a used radio pulled from an LS dash in favor of an aftermarket unit. If that doesn't work, consider a whole aftermarket in-dash radio -- it'd probably be cheaper than getting the radio from a dealer, and the new ones with today's technology are much better.
Gwen
i can't find that in the web.
i'm inresting for description of the fuse box.
thanks!
Do you have a name and address of the repair shop in Minnesota who did the dashboard repair? thanks loads.
http://cgi.ebay.com/ebaymotors/Lexus-LS400-Instrument-Cluster-Repair-Dash-Lights- -/140607508881?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ALexus&hash=item- 20bcdc5191
You can also e-mail him at TheLexpert@yahoo.com for all the details.
At this point, the speedometer works fine, but not the tachometer. I don't think I can pass TX state inspection this way, so I'm trying to run the car on the freeway more often. Back in about Jan-Feb of 2014, I got a new battery, and the gauges ran fine after that for a while (long enough for me to ace the May 2014 inspection).
My question: is it likely that freeway driving would cause the tachometer to reset, when the speedometer is working? And if not, what would be my options? I read (on Edmunds.com; can't find it any more) about something someone purchased through AutoZone.com for a little over $80 (this may be an old post) and had his mechanic install for $25? How about that?
I don't see any reports of the needle actually sticking in the housing (that happened to me on my old Nissan).
Lexus LS400 Faulty Capacitors in ECU
You may have also lost the tach signal to the instrument cluster, or there could be a problem in the cluster itself.
I'd recommend surfing the Club Lexus board for more ideas and also giving these speedo/tach specialists a call and seeing what they say. I haven't done business with them but they seem very helpful:
http://www.mrwhizard.com/
Not sure if you need a tach to pass smog. That's also worth checking with your state authorities.
