2007 Honda CR-V News and Views
You are used to the domestics' way of equipping vehicles. Not sure about versus Jeep but Honda vehicles are typically very cost competitive when comparably equipped to a domestic. Add this or that option to a Jeep and see how much you are really paying.
I agree that a Honda is probably more expensive than an equally equipped Jeep Liberty (I'm assuming you are comparing this model) after rebates. Keep in mind Hondas have some of the highest residual values in the market so your money is not wasted come trade-in time. Also, they have great lease specials.
As far as fog lights, tow package, etc. Honda never has these as standard features on any models. Even their top of the line EX-L models won't have fog lights.
On the flip side, Honda's lower end cars always come standard with ABS, side curtain air bags, and 5 speed automatics. Other competitors require option packages just to equal a base Honda.
Any possibility of a manual transmission option in the future?
They listed handling as one of it's strong points.
"Routine handling is responsive and fairly agile", "Good grip and balance in emergency maneuvers", "Commendable speed in avoidance maneuver".
Doesn't sound like bad maneuverability to me.
CRV has a larger turning radius than the Toyota even for the 17" wheels. I am not sure if the upgraded wheels on the CR-V 07 are the reason for the larger turning radius?
I absolutely agree about the interior.
I think the RAV is a very nice vehicle. The biggest factor for me was the difference in the rear hatch. The 07 CRV hatch opens upward with very small effort, I never liked the door type hatch on my 02 V and the current RAV is the same, with a 17 inch tire attached that partly impedes vision and adds weight when opening.
As you mentioned the 07 RAV limited has a few extras which is paid for by a $3000. difference in the MSRP sticker.
They should recheck the numbers; the Gen 2 has a 34 ft turning radius, the Gen 3 is almost 38 ft.
The change from '06 to '07 seems to be the result of larger wheels.
The issue of maneuverability, as presented in the original post, was directed at moving around in tight spaces. I suspect the new CR-V is not as good as the old one in that single regard.
Maneuverability in terms of handling at speed is another issue. On that score, the new vehicle is supposed to be even better than previous CR-Vs.
Please explain in further detail.
The previous two generations of the CR-V started with a manual transmission. As I said, changes have been made to existing transmission during a model run but I'd like an example of when a manual was added to a lineup where it didn't exist from the start.
The Gen II model was definitely available with a manual in the first year (2002).
Have to say I was a bit (actually more than a bit) disappointed with the '07 redesign. Seems perfect for commuters with a "city" job, but they appear to have really taken the country out of it. The table is gone (I know, I can always throw another table in the back), and so is my "secret" Santa hatch that was also very handy for stowing valuables out of sight. The "cargo cover" seems flimsy, and not destined to last as long as the car if it gets changed around alot. But the worst thing is that the undercarriage seems quite alot lower to the ground--it might add stability and increase mileage on the highway, but I don't see this new model going where the older one went off the road.
I'm very reluctant to exchange my little burro for this fancy new hothouse flower. And the Element is WAY too Spartan to consider (have to admit to not looking that closely at it).
SO--was the demographic for Gen 1-2 so undesireable that they had to go for a whole different class of buyers? Will anyone who actually USED their Gen 1-2 CRV want the new one? I sure don't....Guess I'll be going for 200K...
You can probably find a used G2 model (2004 or 2005) fairly easily. Those are much closer to the original in terms of utility. Or, the new RAV4 is a decent option.
I'm not sure what you should replace the '97 CR-V with for use on your farm. Even the small pickups of yore have morphed into mid size or greater.
Assuming it still meets your needs, I'm sure your '97 will last for a long time. But it is always nice to get a new vehicle.
Jim
Whatever you call it, keep it lined up with the top of your head in case you have a collision.
Lots more here:
Pain in the Neck
Checklist: Protecting Yourself from Whiplash
