Oldsmobile Intrigue Problem Codes/TSBs
in Oldsmobile
The patient is a 99 Intrigue with the 3.5 shortstar and 96k on ther odo. For the last two months I have been noticing the service engine light comes on every so often (one or two days). When I read the code it is a P306, indicating that there was a misfire detected in Cylinder #6. I usually clear the code right after.
This seemed to have started right after I replaced all the plugs. I replaced #6 plug again, and subsequently swapped the ignition modules between both banks, expecting the misfire to appear at Cyl #1 if it was a bad coil or module.
I have also run three tankfuls of three different injector cleaners, one was by Prestone, the other two were Techron.
Any ideas? Has anyone seen this behavior and cured it? thanks.
Did you change your sparkplug wires also??? That would be my prime suspect. Even if you did, the new wire might be bad.
HTH
given the code P0101, will replacing the mass air flow sensor solve my "Service Engine Soon" problem? I did notice my gas mileage was down about 2-3 mpg.
Mark
A code reader tells you what the ECM "sees", not always what is wrong.
A code is merely a guide and not gospel.
The MAF sensor may be bad, however you must first verify(unless you have lots of money to spend) a un-corroded electrical connection and the sensor. It is inline from the air box to the intake throttle.
Verify that there are no leaks in the hose or at the air box or throttle. How's the air filter?. The MAF measures air going into the intake manifold. Any un-metered air (through a crack, PCV valve hoses etc etc) will create problems for the ECM not being able to figure out what the MAF is telling it.
The bang may be the pcm dropping the car into default/limp mode as it cannot figure out what the sensors are telling it. (Or that the signal from the MAF disappears, for whatever reason)bad sensor? bad wiring? bad air flow?
Also check for vacuum leaks at the MAP sensor. Faulty info from this guy can set a MAF code. This sensor monitors air pressure/elevation. Higher teh elevation, less oxygen. The ecm needs to know this and correlates all of the data from several sensors.
The sensor is a fine tiny delicate piece of wire that can be contaminated if oil gets to it, sometimes a cleaner can be sprayed on it if your careful, although a dealer will probably never do this.
You can change the sensor if you like, however, like all codes, there can be many reasons why they are set. Without properly diagnosing the output from the sensor relative to input provided to it, you are effectively guessing.
reseting the ECM is done by erasing the ecm memory( ie erasing the code/freezeframe data stored in memory. Disconnecting the battery will not erase codes on OBD2 cars. post 1996.
The code is "reset" by erasing the codes with a reader/scanner or by eliminating the cause of the error and going through the appropriate drive, start, or warm up cycles which is dependent on the code.
What engine are you running?
cheers.
We have Mitchell electronic manual at work, and it says to check for other things -
Skewed or stuck Throttle Position Sensor (TPS)
Sticking throttle plate or deposits on plate or bore
TPS connection short or poor connection
Poor connection at PCM or sensor
Misrouted or damaged wire harness
Plugged intake duct or dirty air filter
Water entering intake system and contaminating MAF
I wish I would have checked this before spending the money.
It has been extremely cold here (high of only 25 today, low of 0 last night). I'm not a mechanic but I'm not afraid to look under the hood and get dirty. I'll check the hoses and air filter and some of the wiring. I don't feel like throwing money for a MAF when the air filter is dirty.
Thanks Moonshadow.
As for checking other things - It is probably a good idea to check the throttle plate and throttle body for carbon build-up. Take off the air intake tube, and check for black build-up. Manually turn the throttle plate and look inside. Use carb or choke cleaner and a rag to clean it up. Make sure the air intake tubes are both tight, too.
To really check the TPS, you would probably need a mult-meter and need to know what the voltages are supposed to be at each pin on the connector. You might find that in a service manual.
Hope this helps some.
Mine had been off for a while and reared it's head this week. It was about 25-30 minutes into a 2 hour return trip and the light came back on. Stayed on for a couple of days and then went off again. My gas mileage is back up to 26-27 mpg (that's 95% highway at 75mph). I bet I could get to 29 or 30 if I slowed down a bit.
Thanks blue
1. where is the sensor
2. has anyone done this replacement (and can offer some insight)?
3. what else could trigger that code besides an actual bad sensor? Could it actually be a wear issue with the timing chain @205k?
4. Anyone know of a good picture of the 3.5 with some circles and arrows and a paragraph on the back of each one explaining what sensor is what?
Thanks for your help.
Thanks again.
Thankyou!
My car does not overheat, and if the second code for lean mixture requires a oxygen sensor, where the heck is it? I got under the car today, and could not find it. Any help is greatly appreciated!!!! still trying to find a manual that covers everything!!!!!! Issy
For P0171, check out Post number 477 in the "Oldsmobile Intrigue problems & solutions -Read ONly" forum.
dtownfb, "Oldsmobile Intrigue: Problems & Solutions" #459, 10 May 2005 6:57 pm
This DTC identifies a malfunction within the EBCM. (electronic brake control module )
Conditions for Running the DTC
The ignition switch is in the ON position.
Conditions for Setting the DTC
DTC C0550 is set when an internal EBCM malfunction exists.
Action Taken When the DTC Sets
If equipped, the following actions occur:
* The EBCM disables the ABS/TCS/VSES and MSVA for the duration of the ignition cycle.
* A malfunction DTC will set.
* The ABS indicator turns on.
* The TCS indicator turns on.
* The PCS indicator turns on.
* The Red BRAKE Warning indicator turns on.
Conditions for Clearing the DTC
* The condition for the DTC is no longer present (the DTC is not current) and you used the scan tool Clear DTC function.
* The EBCM automatically clears the history DTC when a current DTC is not detected in 100 consecutive drive cycles.
Had your mechanic tried clearing/reset the codes with his scanner? 'Cause a100 drive cycles may take a couple months depending on driving habits.
I would for the fun of it, disconnect the battery and unplug then replug the connector going into the EBCM and then reconnect the batt.
EBCM is under the hood right of the master cylinder in front of the box with all the brake lines.
How long did the repair take and how long to install the new part?
Appreciate your help.
Disconnect the battery (which I forgot to do, but no damage was done).
Disconnect the large electrical connector in the front of the module (pull the white locking tab to the left about 3 inches).
Remove the 6 torx-head screws (this is a little tough because the bottom two are hard to see. Also, if your torx screwdriver is too long it will make it difficult. Try not to drop the screws. I was lucky.
Once the screws are out you can separate the module from the BPM by pulling it apart. It's a little tricky here because there are about 12 solenoid coils that you have to clear while pulling this thing away. The hardest part was putting it back on and trying to line them all up. I got frustrated and walked away for about 30 minutes, but I tried it again and it fell into place.
One more thing: there is an electrical plug on the bottom of the module that you have to disconnect after you separate the module from the BPM.
I think I made this sound tougher than it really is. If you've had any luck working on cars, then you can probably do it. If you are not very mechanically inclined, then don't do it. It took about 2-1/2 hours total. I could probalby do it again in an hour.
Yes, the car is driveable just fine, but no ABS, just regular brakes. None of this requires opening the hydraulic brake lines.
Modulemaster turned it around in 2 or 3 days, I can't remember. I used USPS Priority mail with insurance. It only took 2 days to get there and I live 2000 miles away.
Modulemaster has lots of info on their website. Mine is working great so far and I would recommend them.
What makes you think your EBCM is bad?
http://www.automotiveforums.com/vbulletin/showthread.php?t=622475
Still getting a p1676 code...canister purge solenoid...anyone have any ideas on what it might be ??
I need to pass emissions test,and car wont pass with 'Service Engine Soon light on.
