Visitor Agreement.
1. Attempt to loosen drain plug (faces front of car 16mm hex). Verify it can be loosened. (You don't want to change filter and then find out you cannot drain the oil!)
2. Using filter wrench on 3/8" socket, attempt to loosen the oil filter assembly. That done, you now know that you can change oil and filter.
3. With oil drain pan nearby, loosen and remove the oil filter. Clean area of oil and dirt, remove old filter (about 2" cylinder), wipe clean with blue scot towel. Put new filter inside the filter cap, and re-install. You simply tighten it til it is tight; no guessing, using the filter wrench. You really cannot do this using bare hand.
4. Now drain the oil from the oil drain plug. Mine works best with 16mm socket. Not sure why GM used metric. Must be a Cadillac thing. Open hood and remove oil fill cap to allow best flow to drain oil.
5. Replace drain plug. Tighten decently. Others may have Torque details.
6. Double check that filter and plug in place.
7. The 3.5 V6 is a 6.5 quart oil change with the filter. Some may take 7 quarts. I usually put in 6-6.5 quarts and check the next day, and add if necessary. If your oil/engine were hot enough, you likely got the engine pretty empty.
8. Start car and let it idle, checking for any drips. Check again next few days to make sure all is tight.
9. take old oil to Advanced AP or some other place that takes used oil.
I change the oil on both our intrigues, and have 25 quarts of used oil in garage to take back soon
Probably more than you needed,
greg
http://www.carspace.com/guides/Changing-the-oil-in-Olds-Intrigue-(35L)
The oil filter is a cannister type and sits flush with the base of the engine. Once you buy the replacement oil filter, you understand how it goes together. Let us know if you have any questions.
Among the Toyota problems: Leaking rack & pinion, engine oil leak (possibly rear valve cover gasket?), CV joint rubber fell off and joint needs replacing.
Factor in the near zero fun to drive factor and crappy handling, I am happy I did not buy the Toyota that some of the experts in the magazines said I should. And on a highway trip in winter w/o AC I got 32-33 mpg pretty easily, high 20's easily on higher speed roads w/ac on. Why buy a small tin can car when you can have a nice car and still get reasonable fuel mileage....
Scott
It is a 13 year old vehicle....
You are pretty lucky if that is all the problems you have had with your Intrigue. Read the main Intrigue board to see what others have been experiencing.
The Delco battery split at connection post. Of note was a whining noise when accelerating, about 150,000 kms, turned out it was the resonator (aluminum part in an otherwise stainless exhaust system) $137.00 to fix. My question now is at 195,00kms (or 120.000 miles) of relatively trouble free driving should I replace the suspension parts (rear), the alternator and is there a timing belt in this 3800 engine that figures in a preventive scenario??
Jimconn
Thank sagain jimconno
My spedometer is stuck all the way to the right. This is the second time. The first time was a couple months ago. I have recently worked on the back brakes/parking brake. The first time the spedometer needle starting working by itself while on the freeway.
Does the cable connect to the transmission or somewhere else? I'm assuming the cable might have a lose connection.
Does anyone have any insight into this problem?
It COULD be as simple as the coolant sensor being bad. Did you check the coolant "cold fill" level? Is there sufficient coolant in the reservoir?
MODERATOR /ADMINISTRATOR
Review your vehicle
