Oldsmobile Intrigue: General Care & Maintenance
in Oldsmobile
I want to start changing the oil in my vehicles and have a question regarding the paper filter for the INtrigue. This is the first time I have seen this type of filter and I haven't bothered to look under the car yet at the oil filter. How does the paper filter work? Also is there a special tool needed for the oil change?
I have a 2000 3.5 Intrigue.
Thanks for any help.
The mounting base is of a composite with a very course thread and tends to bind with a moderate amount of friction. A T bar would be helpful to prevent a side thrust on the mounting, but I have never had to use one.
Anyway it's a piece of cake. Good luck:
Regarding the difficulty in changing the filter, I would have to say it's more difficult than the average canister. Maybe I have been spoiled by cars with filters that were more accessible. My 2 cents.
Don't forget it takes about 6 quarts.
Ron
to where is the relief valve/discharge point. It seems to
run to a tube behind the engine. Does this tube discharge
when the system overheats or just feed back to a different
part of the system?
BTW, the tank is supposed to be half full always. It's got markings on the appropriate levels.
And do not mix coolant types: if it has orange coolant, do not add green coolant.
HTH
changed mine at 95K and saw little effect on milage. Note,
that I got a price from Goodyear for the changeout and it
was 50% higher than the dealer.
Single platinum plugs last only 60K.
The wipers on my 2000 GL will sometimes stop in the UP position when I have them in the low setting. If I turn them up to high, they move like normal.
Also, does anyone know a good way to keep the washer nozzles from freezing in the winter? I've had to pour hot water on them to thaw them out. It works, but is probably shocking the cold plastic.
When purchasing washer fluid, make sure that it's a winter mixture. Many places, particularly oil-change shops, use the cheaper summer mixture in the summer and there may still be some of it in your Intrigue's reservoir.
HTH
George
Any tricks? Am I doing this correctly????
Not sure if i read this right or not but only the pedal pressing is needed in five seconds, not the key bit.
Some things to verify: problems I've seen.
The key to ON not ACC.
After key on, wait a several seconds for dash lights self test to settle down.
When pressing down, be smooth, going to fast is just as bad as too slow.
Don't forget to let pedal up after the third push.
Wait several seconds for the change oil light to flash.
cheers
Anyone else here have this happen, and if so cost to fix (or why bother, as I typically go by the 3000 mile oil change interval anyways)?
When i pulled the old one out, the larger end was pretty snug in the hole. When i put the new one in, it waas not as snug and could be pulled out with little effort. Will the engine cover be enough to keep the valve in place? Does the engine sort of "suck" the valve in place? Changing the coolant next weekend.
I remember reading up on a note in a Gm service bullitin about OLM light not resetting after following the proper reset procedure.
Although this note was for another vehicle, a truck, I think. Not sure if the same procedure has any effect on other models, I thought I would mention it.
Paraphrasing: due to bad memory
It said that, after a failed reset attempt, to cycle the key 15 times (off to On) and the oil monitor would reset.
take care.
It's been two wweeks since i changed it and no "check engine" light has come on. My gas mileage is still 25-27 mpg.
Be prepared for the gas to spray out when you remove it.
Chad
Chad
Like everything else mechanical, heat and pressure eventually degrade their materials. I'm surprised that they last so long!
Chad
Surprise! I wanted to use OEM parts so purchased AC-Delco plugs, but it came with NGK platinum plugs and are specified in the owners manual. I returned the AC-Delco and got the proper NGK plugs.
Make sure that the engine is cooled down before removing the plugs or you may strip out the threads in the head due to galling.
The silicone boots were not extremely difficult to remove, but I would recommend a big 90 degree offset needle nose pliers. Or GM has a special tool for removing the boots.
The cassette with the coils lifts up easily after removing the 7 mounting studs.
At 75,000 miles the plugs were found to be in good condition and I didn't really need to spend $10.00 each for new plugs. But I have heard the horror stories about the plugs being frozen in place. But probably they were trying to remove them from a hot or warm engine.
Be sure and put anti seize on the new threads.
Do you have to go under the car? Can I do it with out jacking it up? I looked up the directions posted before but I'm still a bit unclear about how to do it.
Any help would be great, thanks.
It doesnt feel any smoother at the moment however.
Chad
I have dog hair and 3 yr old bug parts (sorry to be so graphic)lodged in there and looks as though the only way to get in there to clean it out, is to disassemble behind the whole back seat area.
This is just another example of how GM made everything so difficult on this car...can't easily change the battery, air filter, nothing.
Thanx anyone
