Cadillac DeVille Climate Control
Hey all:
My 1998 Deville is such a cherry of a car. Recently though it was 98 degrees outside and my lady and I pulled up to the swimming pool with the A/C on high and it was working just fine. (Just had it charged a week earlier) After we got done swimming and got back in the car no cold air would blow from the vents? 134a canister still feels icy cold, I checked all fuses trunk and motor block. They are all good. And the climate control center in the cabin of my car still functions properly as well. I can still hear the doors open and close when adjusting temp from 60 to 90 degrees. Could it just be the Blower Motor Is burnt out? Cant find any type of fuse in the manual that controls the Blower Motor. PLEASE HELP GUYS. It is sooooo HOT out Right now.. Thanks!! Rich K
Like you, I cannot find the fuse either. I can't believe that this motor is not fused. Can't understand why this is a secret.
Dave D.
I have a 1993 sedandeville that i recently bought. when i first got it the heater fan didnt work at all then i found that a fuse was missing. I replaced the fuse and the fan wouldnt stop, even if the car was off. No matter what the climate control system said the fan was constantly blowing. Any ideas?
aaron
Especially if it blows even with the key off.
Check the power lead from blower motor backk to find the blower control module. Advanced Auto reported has them for 93 and on H bodies at about $100. If you find it's the problem, they may have yours.
Yesterday the ac quit working. I noticed the climate control wont go on auto... it stays on econ, the fan works fine and will go on auto. Could this be a problem with the control? I have checked and the 134 is fine although i cant turn the compressor on by bypassing the low pressure cut-out switch.
There should be an error code set in the system which will tell you what problem the sensors are seeing.
There are other places on the internet which will tell you how to put the dash display into error reporting mode, and show you all errors that have been set.
Overall, your AC has broken again.
I've already been slapped silly over this.
It's aganist Edmunds' rules to post links to competing sites.
Google is your friend.
There is a Maintenance, On-board Diagnoistis, and Reference link. I'm about 100% sure your 1996 will be covered here for instruction about how to put it into diagnoistic mode, and a section telling what the codes mean.
Thanks for the Help
Actually, I wouldn't throw parts at this problem. I would either take it to a dealer, or to a good private mechanic that says he knows Cadillacs. This might take some testing to actually find the problem.
I also have a 2003 Deville since it was new. I am also having the same problem. Sometime the blower motor works sometime, not. It seemed for a while that if I hit a bad bump the fan would kick on! I have checked the fluids and fuses, all the easy fixes and they seem fine. When the fan does work everything works fine. I can adjust to all speed settings. The rear blower usually works but it also fails on occasion. I do get a bit of heat when moving just due to the air flow that exist in the system. I feel like a fool warming my car up in the morning with an electric baseboard heater! Thank God for the heated seats! I am an old school (pre-computer) car guy and I am completely lost on this one. Any HELP would be greatly appreciated. I am not really in a financial position for a big mechanical bill. I live near Chicago where the temp is 5 degrees today! :confuse:
Thanks in advance,
Bud
Denny
I need some help, summer has come and it seems to be going pretty quickly and I want to be able to drive it before winter hits because then the car gets stored away until next summer.
Anyone got any ideas what I might be able to check for?
Al
everything worked well untill last week when tempreture hit around 100 degrees.
Since then, when i get into my car and start the car the digital display works fine and shows the fan on auto. But the fan doesnot work. sometime i drive about two blocks and it will kickin and sometime it does not come on at all for a day.
Is there a possible quick fix for it?
Please
Thanks -- Jim
I had this problem and had to change the blower motor.
cars with climate control have to run the blower motor almost constantly in different speeds to keep the inside tempreture constant so the motor does not last as long as cars without climate control.
shop around if you have to change it. I was coated from 150.00 to 450.00 dollars for the motor.
sia
Thanks for your reply -- Jim
sia
Thankx Eddie
Ok, read in your owners manual closely about the Heater/AC system. I think there is a section that talks about how the blower will continue to correctly run after shutdown, under certain conditions. But I think it runs only for a couple of minutes or so in this mode. I don't know what these conditions are, but they are an attempt to 'dry out' the system, or some such thing. If you system is supposed to do this, then maybe it is working correctly.
In humid weather, with the AC running, with the car idling and stopped, does water come out of the bottom of the car? Normally, you should get condensation on the AC coil inside the car when running in hot humid weather, and this water comes out of a drain outside the car. If you car does not do this, then the drain is plugged. But, if you have had service done for the smell, they surely should have checked this.
If you get mode growing in the AC coil, it can be very difficult to 'kill' it. This may be what is happening to your car.
Auto means the AC system is switched on.
You have a problem with the AC. One of the high or low pressure sensors detects a problem, and will not let the Auto mode be set.
Fix the AC.
also when you press on the fan speed selector...I get nothing.
I tried to add refrigerant but since the system wont kick on it wont cycle to get refrigerant flowing thru it.
HELP!!! Its HOT in AZ and I need this sytem to work as soon as possible.
The rest I can deal with and work on with some leisure...but the switch, the blower and the AC not working...is just frustrating me
thanks a million for help.
BTW...new here but real used to working on MOST cars but this is the first caddy I have ever had so any help be real appreciated
