Caravan/Voyager Electrical Issues
                    I am female so I will describe the problem. This morning I started my van and the speedometer and the tack would not work the gas and the oil gages work fine. But also when I am driving I have what I call a glitch in the drive. I will be driving then in feel like a very hard shift. I can feel the pull when it does this. My question is can both of these issues be the same problem? Can it be that I have a bad computer switch? PLEASE HELP!!!!
It is all right when it is cold for the first 3-4km.
I disconnected the battery to see if that would reset anything because it almost seems electrical as opposed to mechanical. I checked the error code (ignition ON - OFF - ON - OFF - ON in 5 seconds) and get a 12 which tells me only that the battery had been disconnected.
Twice shutting the engine off and re-starting then it worked. Now it makes no difference.
I acquired a 1997 Plymouth Grand Voyager a few months ago from a relative. The Registration expired in March, and I am trying to get it to pass smog.
It has a bizarre problem where, while driving the engine just shuts off. The lights, radio, everything still works, the engine just quits. And it takes anywhere from 10 seconds to 15 minutes before I can restart the vehicle.
Now it does this anywhere from 1 to 4-5 times a day. Ive tried to get the vehicle smogged, but it wont pass, because several of the sensors wont come back as initialized, or something. The guys aid there were no 'codes' but that the sensor/monitors still needed to reset - only they dont.
How does one diagnose this sort of intermittent problem? Ive read about all sorts of other mysterious electronic problems with these mid-late 1990's chrysler minivans.
I do know that I have some sort of radiator problem, with a stuck belt or something. Im not sure the radiator fans are turning (they havent when Ive looked)
Does anyone know what the best way to have something like this diagnosed, is? The Dealer charged me $100 just to tell me to replace the vehicle (Quoted me something like $5000 to replace the transmission, which works fine, the radiator, reseal the engine, yadda yadda)
I just need the thing to pass smog (Emissions are great, just the electronics problem)
Any advice would be helpful. The vehicle has 178K miles on it.
Has this happened to anyone else? Any suggestions?
Jim
97xpresso, "Chrysler Town and Country EX/LX/LXi/Limited" #1919, 3 Aug 2005 4:27 pm!keywords=allin%3Amsgtext%20limit%3A.f0a25f0%20needles
Its the Speed sensor located in the Transmission, it cost about $65 CAD and you can replace it yourself.
remove it first, the connection plug may vary from one model to another.
regards
the second time, 1 day, now it blows out between 1 to 10 minutes after start.
I've taken the van to the dealership, but they can NOT find the Problem. This is no surprise by the way.
Has anyone had this problem before? What is it? and how it was resolved?
Thank you in advance.
thank you
Then I noticed the raido started to fade out but it was storming out so I thought it might be the weather as it was fine again the next day.
Well finally today I stopped the van and it wouldn't start. Got a boost to get me home but my suspicion is the alternator is bad.
So my real question is (assuming I'm right) how hard is it to change it? Looks like my biggest challenge would be dealing with the serpentine belt etc.
My battery is only a year old and I will throw a charger on it tonight.
I cannot believe anyone would actually go to all the time and effort to try to modify a Voyager in such a way. The electronic interfaces have to be a mess!
I doubt if anyone will be able to help you on this, other than maybe whoever did the modifications in the first place!
All you need to do is start your van. Then slide your temp lever all the way to full cold. Then turn the Mode Control to the one that sends air to your face only. Then turn the 'blower switch' to all the way to full. Now go to the leftmost three buttons. Press the top one (rear wiper on constant) and the bottom one (rear wiper washer fluid). Hold these two for a few seconds. Once the lights come on solid then begin to flash, you can let go. The AC will now calibrate. You will feel the air blow out of all the different zones at different intervals and see lights come on and go off. Then after a minute or two the top button you pressed will be slowly flashing. This means it has been completed. Press the last flashing button and you are done. Turn off the van and started it back up and see now you don't have those infernal blinking lights anymore! Hope this helps! Oh, be careful with the battery, it is very touchy on Dodge Caravans and can blow out any electrical thing so it is better to take the battery out and charge it and don't charge it directly. One guy mentioned it blew his on board computer just accidently touching the wrench and grounding the battery so be careful with the battery.
I was pulling into a parking space when it shut down.
Acted as if someone turned the key off.
I have no radio, turn signals, idiot lights/gages or wipers.
I do have emergency flashers, headlights, interior lights, heater fan remote tail gate lock and that enoying ding when you leave the key in the ignition.
I called 3 dealerships (they all wanted me to bring it in or didn't have any idea. How? Tow it again? ) & Chrysler's help line ( that gal told me to check the battery wich I told her was good) didn't have a clue either.
Any idea where the fusable links are located???
Anyone have ideas?
After talking to a few people I decided to take a chance and replace the ignition coil...no dice there either...
Does anyone have an idea of where I should start next?? :sick:
Only one dealer will look at it anymore and he has no idea. At least they didn’t charge me. My normal mechanic has no idea. The electrical guy we take the cars to has no idea. We have replaced the: BCM, downstream O2 sensor, the MAP sensor, ignition switch. I have a feeling the alarm system is causing this. However I have been told the alarm is integral to the BCM and cant’ be deactivated. Any help would be appreciated. Thanks.
Is the sensor expensive, where is it located and can I replace it myself?
Finally found a service manager at a local Chysler dealer that would give me a clue!
He told me to check the fusable links in the wiring harness.
He was nice enough to eplain they are orange in color ad tagged "fuse link". They are still hard to find. Looks just like an orange wire spliced into rhe middle of a red (or other color) wire. Some were covered with factory electrical tape.
Found one burnt going to the first (front) relay. Spliced in a new wire and it burned more as soon as I turned on the key.
Anyone know if a bad relay could cause the problem or what that relay controls? Radiator fan? :confuse:
As I was flipping thru Chilton's for 20th+ time, I ran across a drawing (no where near the electrical section) of the 3 relays on the driver's side inner fender.
The front relay is the radiator relay. I unplugged the fan & spliced what was left of the fuseable link. The van started right up & didn't burn the link.
Picked up an after market inline replaceable fuse link & a new fan motor.
I soldered the new link in place of the factory fuseable link wire.
The new motor was around $45 at Advanced Auto Parts.
You have to drill the rivets out of the mounting bracket & replace them with bolts. Well worth messing with. I was quoted around $143 for the whole assembly
I have a 98 Cavalier that had a fan motor go out also.
At least GM puts a fuse box under the hood that doesn't shut down half of the electrical system if the fuse blows!
Hope this helps someone in the future!
I haven't had the same type of problems you are. Judging by the way things are acting, I'd guess the problem my be in The Body Control Modual (BCM)?
The only intermitent problem is my speedometer. Some times it will not work when you start it up and drive down the road. All of a sudden I here a ding & it it'll start working. The needle might stick at 10 to 35 mph at a stand still.
Maybe you can get some info from a local Chrysler dealer's service manager (but don't hold your breath).
1. My passenger side window regular stop working
2. Bigger problem is my lift gate lock remins in lock position not able to open i.e. can not close
Any advice ?
Any thoughts?
Mark
Mark
Mark K
It was the cam sensor. It went bad. Replaced it and the stalling problem completely went away.
Open the driver's door, look for the door latch and there's a black button under it. That's the switch. Use a Torx screwdriver to remove the screw and lift the plastic tabs for removing the terminal. Should be less than US$ 3 bucks
1) The Ignition Switch
2) Any alarm module installed in the car
3) The Automatic Shutdown (ASD) relay on the relay box
Hope you can fix your car
Every once in a while the car will start, but as soon as you let the key go to the “run” position, it will die.[/quote]
Check the Ignition Switch.
If you aren't getting the digital gauges, it's the switch.
If this does not work, try checking the alarm module at your dealer.
You might need to disassembly the dash. Look for a connector in the back of the gauge panel. This connector carries the CCD bus which has all the data needed for the gauges to run, it might went flaky and the readouts are bad. If this doesn't works, buy the Voyager Haynes manual and look for electrical diagrams, from the engine computer to the gauges there must be some color-coded cables that might be fried and need some TLC.
Hope you can fix your vehicle :shades:
I can't find any fuses that do not work, but these functions do not work: remote control, remote door locks, remote mirror control, ammeter gauge, ceiling lights, radio. The tailgate release button only works now when the key is on, whereas it normally works either way.
I can't see any burnt wires or fuses. The Owner's Manual speaks of a "circuit breaker" behind the console somewhere, but does not give specifics. Could that be the problem? If so, exactly where is it and is it something I can fix or replace?
Thank you for your guidance.
Thanks for reading and responding!
