Visitor Agreement.
In preparation for the next driver it ERASES the previously learned parameters when the ignition is switched off.
The dealers seem to be confusing the issue of driver technique/style driving with the ECU's ability to learn, re-learn, continuously the parameters associated with operating the engine and trnasaxle properly as various componets age, wear, degrade, and sensor and servo tolerances change.
THOSE parameters, obviously, are kept forever absent a complete system reset or reflash. Disconnecting the battery will undoubtedly erase some of those parameters but clearly not all.
Also, my tire pressure light is on but my tire pressure is all within range. How do I get the light to go off?
Does not cause any problems that I know of. Hope this helps. By the way....low tire pressure would probably add to this problem.
As a side note, strangely, when I asked them to do the newer TSB (TSB036-07 as I recall, they refused to do it because they said my car didn't need it (even though it's in the VIN range). But then upon driving it, it suddenly understands that there is a 4th gear when using the cruise (before, it alternated between 5th and 3rd constantly on even the slightest grade). So they must have done SOMETHING...
I did the TSB EG036-07 two months ago. The hesitation is gone now but there is a jerking when shift changes mainly in the lower gears. I informed the service dept and the technitian confirmed this after doing a test drive. After long research from their side they applied one old TSB which is TC010-06. After 200 miles now I am having the same jerking when shift changes.
What should I do now with my car? If Toyota cannot fix my problem will they go do a buy back on my car which is 15000 miles? Please somebody help me......
DBW, e-throttle, was later adopted to resolve some of the problems that arose from the ATF pump not having enough capacity to support certain shift patterns/ procedures, especially those with the engine at idle or nearly idle.
So, bottom line...
You can have a Toyota or Lexus with 1-2 second DBW enforced delay/hesitation, or you can have "jerky" shifting and possibly premature transaxle clutch failure down the line.
Eventually I expect Toyota will follow Ford's lead in this, and adopt a variable displacement ATF pump as Ford has done in the new Edge.
You must have really good documentation about each and every time you visited the dealer, what your complaint was, what Toyota observed and what repairs were made (if any). Without the necessary documentation that an issue really exists and the dealer was unable to fix it, the lemon law attorney will probably not take your case.
I approached a lemon law attorney about 2 months ago about my 2007 V6 due to the shift flare. I faxed them all my repair orders (about 6 total). They reviewed them and called me in a few days to tell me they were taking my case. After about a month, Toyota replied and told me they would buy back my car. I am waiting for them to tell me when and where to drop it off.
I wish you much success!
Some have reported it happening even after the engine/transaxle is well into normal operating temperature.
And yes, a few times I experienced the shift flare after 25 minutes of highway driving going approximately 45 mph. However, it is usually worse after 5-20 minutes of driving after a cold start.
So has there been any actual failures and does it happen on every V6 Camry or is it affecting just a certain %? And is Toyota doing anything about it? I am really thinking about the V6 SE to replace my tired old 97 Maxima but I can't bring myself to buy one with this problem. It makes the most sense for me in every way, except this one. I like the price, looks, speed and economy, and I love the 3.5L... Does the "flare" happen with Toyota's 5 speed trannys too? I have an 07 Sienna XLE Ltd with the 5 spd that so far has been perfect and I think the transmission is superb.
My suspicion is that it all began with an attempt to improve FE by reducing the pumping capacity of the gear type ATF pump. Ford has just adopted a variable displacement ATF pump for the new Edge to improve transaxle efficiency and thereby FE.
I suspect the variable displacement ATF pump will also be the final fix for Toyota and Lexus, maybe the '09 models??
Yes, Toyota is trying to fix the problem - they have updated their TSBs at least 3 times. The original solution was to replace the torque converter. When that didn't work, they recommended replacing the entire transmission and torque converter. When that didn't do it, they designed new software for the ECU.
I have had 2 tranny replacements and a software update and the flare is still there. I went to a lemon law attorney and Toyota has agreed to buy back my car. Lord willing, I will be dropping it off tomorrow or the next day.
No, the 5 speed 4 cyclinder does not have the shift flare. Toyota loaned us a 5 speed 2007 Camry when our car was being worked on and I liked it. I was surprised that it had some "get up and go" for a 4 banger.
When I had TC007-07 (aka TC7006) performed, the flares got much worse. It went from around 500rpms to about 800 on average...sometimes as high as 1100. Curious if others have had success or not.
Vicki
You have given very good advice on this subject! ------ I guess I am one of the lucky owners of a 2007 V6 XLE Camry, because I do not have the transmission problem, ------- or my driving style is masking the issue!
As you know from previous postings on these Toyota boards, I purchased a 6 year / 100,000 mile Toyota "top-of-the-line" extended warranty. The vehicle presently has 21,000 + miles, and it is just about one year old. ------ It might take Toyota a couple of years to develop a fix for this transmission issue. Should my transmission fail at 50,000 + miles, then the replacement unit will be the "up-dated unit," and the extended warranty will pick up the total cost! -------- I still think that the "drive by wire" throttle has a lot to do with the operating characteristics of the vehicle. In the cold weather, I make it a point to warm up the vehicle prior to starting out for the day. I then drive on city streets using manual 3 & 4 till I get to the highway. By the time that I get to the highway, the transmission and the engine are at operating temperature! I put the trasmission selector into "D" and I do not have any issues.
Best regards. ------- Dwayne :shades:
Remember that most will burn though a 6 year/100,000 mile in under 4 years....but toyota will fix it when its their fault....best case would be to just drive your vehicle until there is a fix that works....I would rather drive my car 100,000 miles and get a new transmission. There are some who had their transmission replaced but were shocked to have the same problem with the new transmission....I do think its just a computer error not allowing the transmission to warm up (which you fixed yourself) and maybe a transmission fluid level being a little low....Or maybe a presser switch not allowing enough fluid into that part of the transmission....Toyota is addressing the fix but with that they have sent out fixes that were not tested......completely....It seems its a microsoft testing again.....send it out and have the users become testers and toyota will send out fixes....as you may have guessed....this is going to take a while.....remember....rule states if you fix one thing without testing it completely....you could end up with 4 new problems.....effecting 3 different areas.....yes the one thing might seem fixed....but now it runs like sh&t and you are getting 14MPH.....and the dealer is happy to fix it for you..again and again...just because he gets paid from toyota....so plan on really getting to know your dealer.........You will be in and out of there alot....or just wait and best case get a new transmission for free....that works....3 years from now......
I buy Toyota for reliability and comfort, but I have always had MT and really hate automatics. The MT adds to the reliability and is cheaper (I am cheap!).
We should probably put further discussions about this in the 2008 Toyota Camry forum.
Let me know if you have any questions about the MT Camry - why do you
want one?
I don't know if this is the issue everyone is talking about? When accelerating from a stop, there are more often then not, times when my car does nothing at all for a few seconds. Then it's as if it finally catches up and off I go (slowly).
I have a 07 Camry SE 4 cyl.
I read about some people talking about opening cases with Toyota about their issues... What is that and is it something that might best serve my interest?
I have the VSC installed. Does that mean I would also have TBS?
TSB is a Technical Service Bulletin.
There is a TSB issued by Toyota, which addresses engine and transmission performance on 4 cylinder engines. It's a software load to the car computer, takes about 1/2 hour. Read thru the forums, I've posted a link to a copy of the TSB couple times previously.
When I mention the gas milage they just try to say it the cold weather or my driving habits. My habits havent changed but the car has.
Buyer beware until Toyota gets it right!
Last week I took my vehicle in for the 2,500 mile oil and filter change, (my choice)! (My vehicle now has almost 23,000 miles). I wanted to set up a date for a fluid change on the automatic transmission. The Service Manager and the Service Advisor told me that there is no fluid change scheduled for the V6 XLE Camry till it reaches 100,000 miles. This transmission has some "special fluid," and the cost is somewhere around $75.00 per gallon! I also inquired about the engine coolant, and I was told, that it also should last 100,000 miles! I find this hard to believe, but they said that if something goes wrong my warranty will be "ok"!
Best regards. ------------- Dwayne :shades:
I am giving Toyota one more try. I hope I have invested my $40,000.00 wisely. :confuse:
Last week my dealer did the TSB 007-07. Just yesterday after having not driven the car for a day and the temperature dropped outside, it did it again. I backed out of the driveway and cannot get going in forward for a minute or so until the trans gets going. It seems that the 3rd gear issue on deceleration is a little better after the TSB.
Has anyone experienced any improvement from any of the TSB's or transmission replacements?
Also how are people determining when the car was built? my vin ends with U039683. I know that this is the sequence it was built.
How many others have the flare on cold start from a stand still as opposed to the 3 to 4 flare or have people had both?
Any word yet if Toyota will develop a better fix or a recall on the trans?
I am brining mine back to the dealer next week but I am concerned that additional fixes mess up the gas mileage, or don't seem to work as I have read here.
By the way, I found some of the TSB's in pdf format at Toyota Nation. com. Here is the link: http://www.toyotanation.com/forum/forumdisplay.php?f=104. If this does not work, it is under Camry forums Gen 5&6 scroll down a bit and there it is.
Thanks for any additional help on this matter.
Eric
Your problem sounds like a defective transmission or part. You should keep on the dealer to fix the problem under warranty.
