Toyota Sienna Warning Lights & Problem Codes
The last time we got gas in NJ, the attendant did not close the gas cap properly and the check engine light went on. We have now tightened the gas cap and the light is still on. It appears we have to take the van to the dealer to get it checked up could cost 75 dollars or more. Seems like a steep price for silly mistake of a loose gas cap. The van has about 40,000 miles and any ideas on what the problem could be. I would especially like to know if any of these would still be covered by warranty. Just curious.
Nagesh
See also: What Your Check Engine Light Is Telling You
Nagesh
Nagesh
ODBII requires the idiot light because they want people to go to the dealership to fix it, since it might affect emissions.
They basically assume the vehicle owner is not smart enough or ethical enough to do the right thing and fix it.
-juice
Nagesh
Tanker
For $45 the service manager told me how to reset the lights DIY: Under the instrument deck, there is a fuse box. Remove the one labelled "EFI" for 30 seconds. That's it. Hopefully you all benefit from my tuition. But only do so if you are sure that those lights are false warning as in my situation.
Yes, it is normal for the VSC to "fault" after a long period, ~45 seconds of continuous VSC or Trac activation, longer period for semi-continuous. The one in my 2001 AWD RX300 will reset on its own after a period of cool down time.
But the CEL is another matter entirely, I don't think that was normal for your circumstance.
I was looking for information on this forum; thought I share the result here.
TIA,
saafedt
After one or two trips to drop and pickup the kids at school, the light automatically went off. I am not sure why the light came in the first place; I am puzzled.
I went to auto zone , atre scanning , the code indicates
air/fuel sensor heat circuit response. (bank 1 sensor 1)
it says probable causes
1. open or short circuit condition
2. poor electrcal connection
I would guess to start looking at the electrical connections at bank 1 sensor 1 , but what is that ?
cylynder 1 or what .
I 'd appreciate any help .
these are toyota's version of an o2 sensor .
the heat circuit is added to make it get to operating tempature faster .
on the sienna ,there are 3 .one on each exhaust manifold & one downstream of the cat. they all work in conjunction w/each other to make adjustments.
bank one is the first , next to the firewall, two is in front just behind the radiator , & three is last after the cat.
at toyota , the sensor was $210 so, I bought it on the net from a toyota dealer fo $158, delivered. comes w/ a dab of antisieze on the threads.
you're supposed to check the 02 sensor w/a voltage meter . there are paramaters to check if the part is in fact bad b4 buying an expensive replacement .
This site was recommended to me, are you familiar with them?
http://www.trdparts4u.com/
of FUEL DOOR and at bottom of the gauge by E(empty) I have a lighted gas pump symbol. I did fill up the tank and close the fuel cap to one click and fuel door secured.
Both the warning indicators still remains.
Does any one have a similar problem/resolution?
I think that will require a dealer visit.
Then I went to the local dealer for help. First two times they could not find anything wrong so they just reset the button. The third time they told me they found the problem and had to replace the computers (sensors??). But the warning light still comes on the next day.
After three visits I feel they may not know what the problem is. So I come here for a suggestion. Also wondering am I the only one has this problem??
I would try fixing a few things at a time, to see if that's enough to clear the codes. Maybe the things I mentioned above and the coils.
I'm not sure you need to replace the catalyst system - it's working properly, reporting misfires. Unless you've been driving with those misfire codes for a very long time you probably caught it early enough to fix the symptom, and not the catalyst itself.
http://www-odi.nhtsa.dot.gov/tsbs/results.cfm
After reading other owners' complaints in this forum, I think the new Toyota Sienna is definitely having some issues over here. Should they issue a recall for this? How can we, the owners, get together and make them to do something about it?
Funny I looked up the emmissions warranty on my 2001 said its covered for like 7 years/80k yet toyota says 3/36k whats with that?
By the way these toyotas seem to have an awful lot of sensors that go bad.
I would also ask the dealer how they determined it would cost $700.00. Just by looking at some codes or did they actually run a real dianostic. Ask them what they would replace for that kind of money? I am going through a simular issue with emmisions and they just want to change parts out till the issue is resolved. Real shops will run tests on the components even run smoke through the system to find a leak. Which is what toyota should have done from the start.
It sure sounds like the dealer is trying to rip you off.
It's these types of issues that will make me not buy another toyota. Problems their repair facilitys can't solve. All they do is replace parts hoping the problem is resolved. When it isn't they want more money to take another guess.
Glad to hear you can replace the door handle on your own. You saved boco bucks. Mine is still the orginal.
Also don't just take your car to the dealership for second opinions. Try a local shop as well. The dealership uses a rate book that is basically the same at all dealerships. Also if you want to buy a part try to get a non oem as they are cheaper and work just as good. I have also called dealerships for dealer only parts and have gotten as much as a 30% difference in price for the same part.
So it's not just Toyota. At least for 2007 on the vans they went to an actual sensor in the wheel, rather than just relying on the ABS sensors.
On 11/3 (Sat), all three MIL (malfunction indicator lights) went away.
As of today, the warning lights remain off.. I have been asking around, some repair shops claimed that the lights that went on the second time might caused by a loose gas cap valve. It might take couple of "running cycles" for the computer to reset.
Now, I am very frustrated. Was the service that performed by dealer on 9/21 necessary? That might caused by a loose gas cap also??
I learned my lessons this time. I am not going back to my dealer anymore.
I will try to get the link to work...but try to search by the TSB number when u are in the site...
Latest update, check engine light, VSC and Trac lights went back on again after they were off for 1 wk....
-Check Engine light comes on
-Begins to lose power
-Starts "hunting" a gear it can sustain in. Back & forth, back & forth
-Starts acting like it's running on 3-4 cylinders
-Starts bucking
-Won't go over 50 mph uphill.
2 dealers say they can't find anything wrong. They tell me it must be gas. What a crock! Stopped at WalMart and put in a 20-oz Fuel System Cleaner plus a full bottls of octane booster. I have a 2000 Odyssey with 193K, runs like a dream. I'll never drive this piece-of-junk Toyota on the road again. Only 4.5 more years of payments. Drove 250 miles like that last night, have 400 more miles this morning. I hate this Toyota. Anyone have any ideas? The experts don't.
