Have you checked the transmission fluid level?
Suggest you get it checked out and see if might not just need to lube your diffs
The transmission fluid level is fine.
Are you talking about a grease fitting when you mention the drive shaft at the differential and transfer case ends?? If not how do you the drive shaft ??
Thanks again for the info.
I'm pretty sure that a little lube will reduce or pretty much eliminate the clunk you're noticing. And also, this is a "trait" that most LCs have at one time or another. Another thought--while your under your truck you might want to look at the diffs and TCase drain and fill plugs as you might want to chain the oil in these sometime. If you do decide to try that--loosen the fill plug FIRST! you don't want to drain the oil and then find you can't get the fill plug loose to re-fill the diff
When you get oriented under neath the truck, you'll also see why you only put a small amount of lube in the grease fittings that go in to the tcase. Too much lube and you'll compress the propeller shaft toward the differential end of the shaft.
HTH
If I'm just wrong, and this doesn't seem like an alignment problem, any replys will help.
For parts-try this link http://www.toyotapartsworld.com/ I haven't used them, but you can at least see what their prices are like.
Also, shop your local dealers. Fib a little. Tell them dealer B has the same part for X less, or ask them if they give club disounts.
According to this Wall Street Journal article used SUV prices are down several thousand dollars. Although its the domestic products that are the hardest hit there has to be a spillover effect - now might be the time to buy or trade up for a good but a lot cheaper Landcruiser.
I have a few questions about the bluetooth function and/or the phone dialing capability when vehicle is in motion. I have a 2006 TLC with NAV/Bluetooth.
(1) Does the NAV system enable voice dialing?
(2) Is there a way to circumvent the inability to dial a number or even a 1-touch phone number stored on the NAV when the vehicle is in motion?
(3) If not to the above two questions, how do you cope with the very limited ability to initiate phone calls - - limited to when the vehicle is stopped?!
Thanks for your thoughts.
I originally came into the Toyota dealership to check out a brand new Sequoia because I had heard such great things about them and drove one around for a few hours but I just didn’t like it. Nothing impressed me about it. So on a whim the salesmen told me to try out the Land Cruiser. The difference was just unbelievable. There was JUST something about that car. I wanted that car from the first 30 seconds I drove it. I had a hard time hiding my excitement from the salesman and I probably didn’t do a very good job of it but I’m sure we were both very happy with the outcome. The interior was beautiful and perfect even after 37,000 miles. The navigation system was VERY impressive, far superior to the Escalade. The Land Cruiser just feels solid and everything fits like it’s supposed too. I only wish that Toyota had something comparable to On-Star, which I really wanted.
I traded in an 01 Navigator, which was a beautifult car. I know they get a bad rep, but I never had a single problem with it in 4 years. Just decided it was time for a change. Depreciation though, was quite severe.
I really love reading this board. So many owners talking about their LC’s with over 100,000 miles and no problems. Makes me think I made the right choice. My dealer had a brand new 06 on the lot. MSRP was $64,000. I couldn’t see much difference between mine and the 06 except for a bigger engine, which I can live without.
I too felt the same way you did when I drove a LC. I originally went in to drive and look at a loaded 4 runner and was not impressed the way it drove. They had a new 06 LC that I asked to drive, I was HOOKED! It is like nothing else that I have driven. I traded in my 04 Touareg V8 :lemon: that was nothing but trouble for a certified used 04 LC with 13,000 miles. I could not be happier, I would have liked the extra power of the 06 but not enough to justify the $$$$$. Good luck with yours!
AFAIK, the '01 Nav doesn't compute mpg, etc
Don't know if this is of help or not, but the Nav package does have a lot of features
http://tinyurl.com/b4uhk
WRT trip computer with the Nav system--I believe the newer ones (perhaps beginning in '03?) have that feature. My mother's LS 430 (an '05) has it as part of her Nav system.
A far less technical method of gauging your mpgs and distance is to look at the fuel gauge--once you get below half it starts falling faster than it does from full to half full--guess that means the fuel gauge is both an optimist and a pessimist?
$10, that was fast
$20, that's nothing new
$30, humm..I remember paying this much for a full tank 4 years ago
$40, this was almost normal now
$50, wow......I've never gone past 50 before
$60, so....is Toyota thinking about sticking a hybrid in a LC?
$62.34, FINALLY IT STOPPED!!
At least I'm not paying $75....yet
But on the up side, I almost got a average of 15mpg on the last tank
Is there any way of getting around $$$250.00 plus for a spare key. Called a couple of dealerships and thats they quoted me.
Thanks for any advice
There are some uncut keys avaliable on Ebay. All you have to do is get it cut, and then programed. In most cases, the keys will cost around $100 or less shipped, and may or may not include programing instructions, so you can program the transmitter yourself.
That's about the cost of a tank of gas - what are you waiting for??
BTW, my M45 and A$ both have a compass even though they each have Navigation. Yes, both are completely redundant.
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Arthur
PS...My trip computer resets every time I turn off the engine?? My overall mileage is correct but the trip starts over every time I take the key out. Any Clues??
Thanks! :confuse:
