Dodge Grand Caravan Engine Problems
nathangodwin75
Member Posts: 6
in Dodge
Hi i'm new at these discusion boards but
i need help i have 2002 grand caravan sport w/3.3 liter it will shut down about 20 min. after it's up to temp. let me tell you tho, changed crank sensor fuel pump and filter checked for spark while not wanting to crank and it got fuel to the injectors also i have check the relys and fuses they seem to be fine please any one had this problem
Frank
My '04 Grand Caravan SXT 3.8L is running a little rough and when I fill the gas tank, the engine will stall at the next stop light. It re starts and idles a little rough but no more stalling....until I fill the gas tank. I've replaced the plugs and filters. Any ideas as to what is going on with my van would be greatly appreciated.
Oil changed about 1,500 miles ago, so crankcase is full. Went driving in the mountains of NC yesterday. Oil light would briefly come on a couple of occasions after a good hour or two of driving winding, mountainous roads, whenever I stopped. Raced the engine briefly, it would go away. Then would idle with no problem. Drove 4 hours to mountains, 4 hours back home, drove today in town, no oil light.
Question: would altitude have an effect on the oil light possibly coming on? We were, at most, a mile above sea level. I can't figure this out.
Have you had any problems with it since then?
The oil light on the dash is, I believe, just a oil pressure indicator (not an oil level indicator). The pressure threshold for turning on the light is pretty low. So if you were driving the car for a while with low oil pressure, you could very well have done some serious damage to the engine.
Sorry.
An easy way to determine if the engine is seized would be to put a socket on the crankshaft pulley bolt and try to turn the engine. If you cannot get it to turn, that puppy is a goner.
P0002
Fuel Volume Regulator Control Circuit
Range/Performance
Fault code.
Does anybody know what the fix could be?
Thanks to whom ever...
We had the valve cover and oil pan gaskets replaced at around 100K on our 01 DGC EX w/3.8L engine. It wasn't burning oil, but I noticed it was down about a half quart of oil right before oil changes. Since I was changing the oil myself, I was able to see oil on the engine block around the valve cover gaskets. No more oil leaks and the oil level is still full before oil change.
shuts off by itself and will not start back up. Relay clicks but the starter never cranks over. Noticed that the EATX SAFETY SHUT DOWN RELAY got hot and replace that. Then replaced the ignition switch. Starter shouldn't be the issue since that would not shut off the Van. Sometime I can go out and start it up but it soon dies and will not turn over. Just noticed that the EATX SAFETY SHUT DOWN RELAY was getting warm as I was turning the key to strt the engine. The starter/ignition rely clicks but like I said that's as far as it goes. No other relays get warm or hot... Sounds like a ton of people have had the same problem but for some reason, the actual solution that worked does not get posted... Does Dodge have an IT guy hack in and remove the cure from blogs and forums???
First thing you need to do is take it somewhere (Autozone?) and have 'em read the OBD-II codes.
I tried starting it last night after having given up on it for five months and it fired right up (less than two cranks) as though I had only started it the previous day. I drove it around for about 30 minutes to toss fluids around, etc., and it worked perfectly. I shut it down and restarted it with no problems. I tried again two hours later and it was back to no-start. This morning it was the same way. :mad:
I also have the circuit board issue, but that silly thing works less than it doesn't any more, so I really doubt it has anything to do with it directly. In fact, the board was not working Wednesday when the van did work, but came on after it was running for about 20 minutes. Both times I tried starting it yesterday, the gauges were working. :confuse:
Oh and I've replaced the belt and the belt tensioner, so I know I belt is not slipping.
