Thanks George
george.eberle at hotmail dot com
what is the Nissan ph# you contacted? Corporate offices? Did they mail you a voucher or what? i am EXTREMLY annoyed by the squeak and thump! Other than that i love the car.
while I don't have a altima, but I was thinking of getting a 09, I had similar problems with my 2005 FX35; almost every 10k miles the brakes were so bad that the pads were completely gone and would warp the rotors causing terrible grinding and shimmering in the steering wheel whenever I applied the brake; suffice it to say the sounds and vibrations were so bad I knew just based on the steering wheel shimmering when I needed to bring the vehicle in and have the rotors resurfaced and the brake pads replaced
and this started within the first 10k miles of the vehicle which is totally unacceptable; luckily for me, infiniti covered it all under warranty or it would have been over $300 dollars every time I had to take it in and have the work done- one time when I was at the infiniti dealer having the rotors resurfaced a guy with a G35 was there and his rotors were so warped that he had to have them completely replaced- in about the 3 and a half years I leased the vehicle I had the rotors resurfaced and brake pads replaced about 5 times- suffice it to say this was the main reason why I didn't buy the FX at the end of the lease because I didn't want to put out of pocket 300-400 dollars every year for resurfaced rotors and new brake pads
these brake and severely warped rotors are a major problem with the majority of nissan and infiniti vehicles- I was told by a mechanic at goodyear one time that unless you get after market brakes and cross-drilled rotors put on the vehicle you'll continue to have pre-mature warping and terribly worn brake pads
nissan and infiniti better get their act together on this problem becasue too many car companies including nissan and others are becoming to complacent and act like these worn pads and warped rotors under 10k and 15k miles are normal wear and tear on the car but they are not and once the 3yr nissan or 4yr infiniti warranty expires you'll be paying out of pocket to have the problems readdressed since they put on the new brakes/rotors that are no different from the originals and then just wear out again
The problem with these brakes is the CVT transmission. IMO, the transmission does nothing to help slow the car down, and therefore the brakes are doing all of the work. That is what I think is causing the problem. I am glad I found this forum...if they try and hose me tomorrow, I will mention this, and then call Nissan and demand they do something.
it almost sounds like metal moving from heat expansion. It's not always in the same place either.
anyway, that kind of BS is getting typical with dealerships and is really poor customer service when you think about it; everything that goes wrong with the car is "oh, there really isn't anything wrong or oh, I wouldn't be concerned" - you think what you had wrong was bad, my 08 TL had a power steering fluid leak and the dealership kept refilling the fluid and sent me on my way and the second time I was in after I lost fluid again the service advisor said the same BS you got, " don't be too concerned because we didn't find a leak!"
can you believe that BS from him, I'm losing power steering fluid and they can't tell me why and just kept sending me on my way; suffice it to say that after getting Acura HQ involved the leak was finally found and the proper parts replaced and no problems so far but the dealerships whole attitude was piss poor to say the least
Back to Nissan though, I have a 2010 Maxima right now on a 3 year lease and I'm going to be using it as a test guide for Nissan in regards to seeing if they have gotten their brake and rotor issues solved because if not this will be it with me with Nissan and Infiniti because I had just come off a 2005 FX35 lease before this max and had terrible brake and rotor problems the entire time I had it, every 10k miles the brakes and rotors had to be done and it was the main reason why I didn't keep it when the lease was over
You would have thought by now that Nissan and Infiniti would have gotten these brake and rotor issues corrected by now since during the early and middle part of this decade they had terrible brake and rotor problems
If you don't believe me just check consumer reports reliability history for the Nissan's and Infiniti's and you'll see all the worse than avg and much worse than avg for brakes/rotors for the 2000-2007 model years!
All i have to say i CAN'T wait for my lease to be over and this is the first time and last time i EVER get a nissan.
I remember reading two long term road test updates in motortrend earlier this year on a 2008 accord and they mentioned as well having to have their pads replaced at like 12k miles
for some reason, Honda, Nissan, Infiniti, Acura, even Toyota etc all seem to think that having to have brake pads replaced and rotors resurfaced at between 8-15k miles the first time is normal wear and tear - they all are sorely mistaken!!
way back when I had GM vehicles, despite dealing with a whole sort of mechanical problems, I used to not have to have brake pads replaced until 40-50k miles, what the he'll ever happen to getting between 40-60k miles out of your brakes???
I was driving 65mph when I saw traffic stopped up ahead. I got one good brake in, which slowed me down to 30-35, then braked again. My foot went to the floor!
I was able to pump and get slowed down enough not to hit the cars or go off road and have something else stop me.
No warning whatsoever! Anybody hear of brake failures like this on 2007 models?
www.nissan-techinfo.com/TSB/TSB_xml/nmsubject.aspx?mseries=%20Altima%20(L32)%200- 7-10&msection=BR+-+BRAKE+SYSTEM
Saturday 01/09/2010; while going at 35 MPH, I had a catastrophic brake failure on my 09 NAH. The brakes were non responsive, could have been a major potential for a FATAL accident if I was doing 65 MPH on highway. Enough to say I am totally pissed about this and Want ANSWERS from Nissan!.
The car is with the dealer now and I will update this thread as more information flows in.
My tow cost $197 to tow me 5 (Yes FIVE) miles to the dealership because the towing company they sent charge commercial rates and because the road side assistance program covers only $100, I am Out 97 dollars! I have another major issue with this and I have asked for the regional specialist of Nissan to contact me, they said it will be within 2 business days and I hope that's true or else I have another thing coming!
Nissan Case# 6699786
Tip: Do not buy the roadside assistance and get a AAA Plus membership instead
hopefully Nissan will rectify the problem and give you answers but in all honest Nissan customer service sucks, especially Nissan Regional Product Specialists, because I have had to contact one about problems with my maxima and she was useless in regards to trying to help me or in regards to information about the vehicle; I don't understand how they can be called product specialists when you go to ask them specific technical questions about your Nissan and they either don't know or say "Go ask the stealership"
your better to just deal with the stealership because the regional specialists take what ever the stealership says as word and won't even listen to the customer or come out and see the problem with your car themselves; the latter is what happened in my case; like I said I would deal with the stealership, see what they say and if your not happy then I would call Nissan Consumer Affairs and speak to someone there directly, don't let them transfer you to a product specialist!
best of luck to you!!!!
Does anyone have an experience like this with brakes , or could this be another issue?
Noisy brake is not a brake problem...yes, it's annoying. When you need to replace the brakes at 15k like the Accord 2008-2010, that's the brake problem.
there is a simple fix for that go to Autozone or online and by Bosch, Rain-X, or Valeo silicon wiper blades and replace the OEM, thats what I did and they work wonderfully; the rest of the car is wonderful though!!
Previously there had been no indication of any problems with the brakes.
How many Altimas have this problem? How many people have to be injured or killed for Nissan to acknowledge they have a SERIOUS problem?
do what I did when my 2009 Altima Hybrid had a catastrophic failure IDENTICAL to yours.
(1) File a case with NHTSA Online.
(2) Call Nissan Consumer Affairs at 1-866-799-1690. Open a case with them.
(3) Write to Nissan consumer Affairs at:
Nissan North America
Consumer Affairs
PO Box 685003
Franklin, TN 37068-5003
I had done all this, the dealer told me the ABS Actuator had failed and took 3 weeks to replace. What was the root cause in your case? Did nissan tell you?
I even called the local CBS station and no one cared!
We need to make more noise (apparently they dont care for forums) to make ourselves heard. Any Ideas?
you guys are going to have to do this if you really want to break the vicious cycle; Infiniti and Nissan will just keep giving you the same faulty OEM brakes and rotors and thus the crappy cycle continues!
wish you all the best!!
