Lincoln Continental Maintenance and Repair
I have a '95 Continental that I like better than any car I've ever owned (and I've owned nearly fifty cars in my fifty-five years of driving). I have had almost no problems with it in the five years I've owned it. I've put 52,000 miles of the total of 91,000 miles that are on it. Since nothing lasts forever I'm thinking ahead to replacement time. I'd be interested in another very low miles car but I don't like the air suspension on my '95. I've had zero problems with the suspension, but I don't really like the way it rides, and it is noisy. I understand that Ford changed to a more conventional suspension somewhere along the way befor they quit production. Anybody know what year was changed over? Thanks.
Gene
Gene
My 94 does this too, but also I have a question you may be able to help me with.
I had the transmission lines go bad and I had them taken out and now cannot seem to see where they go. There are two lines coming out of the radiator going somewhere and there are two emply connections on the transmission cooler and then two coming out of the transmission itself. I cannot find where these lines go. I have been to the library and looking for a diagram but nothing seems to bring up the preciswe locations. Thanks for your help. Mark
It appears that I am not the only one with these troubles. I also have a 1997 Lincoln Continental acting very similar to yours. My vehicle has been doing this for at least 1 1/2 yrs. All though I am the new owner I have a pretty good history of the car. My car has had new fuel pump/filter, plugs/wires, sensors of which I'm not sure which ones, and a few scanner diagnostics tests, all of which have'nt helped. My car does not show any codes, no engine light or any other indicators. If you find anything positive could you please forward your fix, i would very much appreciate it.
Thanks ahead of time.
K.Whitford
I recently bought a 2000 L. Continental. I´m happy with it, but i dont know why doesnt appear snapshots of that car on the research pages such Edmund´s or CARS.COM.
Is this a Good Car?
Is it necesary to fill it up always with premium gas?
Regards
My problem is that I start up the car, it starts perfectly, then when I put it in reverse or drive, it stalls out. Does anyone know what this problem is? Once it is driving, it goes well....and this has been happening for the last couple of months.
I was wondering if anyone had any answers?
Suspension Alternatives
I recently replaced the air suspension system with the coil suspension system, guaranteed for life of the car.
The body is in beautiful condition. (some paint peeled off the rubber front bumper). Inside, there is a ripe in driver's seat upholstery, and the headliner is coming down in the back above the rear window. The passenger window works intermittently (tho it is up, it has never stuck when down)
I have done all scheduled maintenance, and kept records of that. Emissions passed easily.
What i want to find is a Lincoln Enthusiast, who would love to own and work on the car, and restore it to its day-before-yesterday top-running condition.
If anyone knows such a person, Please let me know!
Thanks so much, You all !
Advised by mechanic to replace entire cluster.
Bought one from salvage yard online. Had it installed. Still getting 'Check DCL' (comes on, beeps 10 times, goes off, very random), gas level read 8 gallons, drove it 120 miles, gas level reading went to 12 gallons. Getting 'CO' reading on left display for fuel reading.
Is this related to the instrument cluster or is there another potential cause?
Bought one from salvage yard online. Had it installed. Still getting 'Check DCL' (comes on, beeps 10 times, goes off, happens randomly), gas level read 7 gallons, drove 60 miles went to 11 gallons. Also getting 'CO' reading on left display.
Brandie
http://townhall-talk.edmunds.com/WebX/.f10ba3f/4
I know I sound like a female and I am.
A) the cap is leaking and lost it's seal. Check this by driving with the blue washer fluid filled up in it and drive over some bumps and take a few hard turns. Look under the hood and see if you see any signs of splasing near the top or leaks. Get a big rubber washer to fix it. Look for at auto parts store or Lowes plumbing dept. poss dealer part too.
Use colored water or blue washer fluid. Remeber, it may only allow it to leak if the weather is warm and the engine is warm due to thermal stress on the crack. If you find the leak you'll still have to take the tank out so why not by a new one although it can be glued with the right kind of plastic/nylon or whatever material type glue the tank is made from.
I'd just buy a new one or if you can afford it. Hope this helps.
I tried removing the stiff fabric covering the inside of the trunk lid by removing the plastic pins, I found the bulb holder but I could not pull it out to replace the bulb. I also tried to turn it without success. How does one get to the bulb housing to replace a burned out bulb?
Im at a loss.. Please, any advice will be welcome before I have to take it to Lincoln distributators..Thanks in advance...
How can I reset it on the Freeway..Im pretty dumb about this stuff..LOL Now it is kind of acting like it hesitates a little when I push on the gas from a stop so I have an appointment with AAA for next week to have it diagnosed by them but they charge so much that Im having second thoughts..Do you think I should do that?
I have no idea why your have headlight has condensation..Hopefully someone smarter than me will answer that question for you..Maybe you can check an auto dismantler..Surly someone has wrecked on of these cars at one time or another..
a little hesitant? thats weird...mine kinda slips when the engine is cold from 1st to 2nd gear...but when its warm its fine...i dunno is diagnostics will be able to tell why its hesitant...does it jerk or is it slow reaction u pressing the pedal
i think i need to just get a new headlight :--/
No, no jerk, just a slow reaction, when I press the pedal, kind of like pressing on air for a second or two then it takes hold..It may have been doing that all of the time now with the lower gas mileage I may just be noticing it...Maybe I won't get the diagnosis..They want way to much.. Oh yeh, my "check engine soon" light is on now..I think it came on when I hit 40,000 miles..How can I get that off?
It may be a good idea for you to buy the new part instead of a used one...You may be money ahead that way.. I tried to find you youtube thingy but not succesful..
we get about the same mpg hwy and city what year
ur welcome dude. thats what we're all here for
what about a headlight, do they sell lights for 00 online or should i get a new seal from the night....theres so much condensation
CAt
.My print out says,
PO172
OEM Brand:OBD11PLM has determined that during testing (can't read word)
system for bank 2 was to lean.
Defination...
fuel bank 2 condition explanation.
The ECM has detected a rich or lean air/fuel ratio condition on engine bank 2.
Probable causes.
1.If bank 1 and 2 are set together suspect fuel condition or MAF fault.
2.-failed Ho2s21
3. -ignitation misfire condition
4. fuel injector problem
5. engine mechanical condition.
CAt
