Sienna sliding doors freezing shut- HELP PLEASE
If it wasn't bad enough that our 2005 XLE had the door weld issue, AND the cable corroding and breaking causing the door not to open NOW on cold days both sliding doors won't open until it warms up ( and not just in the driveway. We have to drive to school about 20 min). The kids have to climb over the front seat.
This didn't happen last year. They did however replace the cable in the one sliding door. Could they have broken a seal or something that's somehow causing moisture to get into the car and freeze up the doors?
YOUR DOOR: Was just cable replaced, or was it a $1,500-$2,000 job? Fixed by dealer or _____?
One thing I Do know- anyone who buys a Toyota should be prepared to shell out more money for the 8 yr/ 100,000. All of our problems started after 50k (except we did have a cooling issue early on).
They were polite & honest. My Toyota had passed the time limit for the recall (Othere was a recall on a part for the rear trunk & driver/pass. door welds). However, I bought extended EasyCare warranty with the car and it covered everything! The problem with the sliding doors was that they were freezing up due to cold weather. They gave me a free can of silicone spray, put it on, washed my car and gave me a bill for $100. My warranty covered $1100 worth of work! Toyota took care of the legwork for me, made me feel valued, and had my car up & running in a day. My advice is to stay positive, go directly to a Toyota dealership, be polite & honest. You could also just go ahead and put silicone spray on it, hope this helps. I still love my Sienna and Toyota hasn't screwed me yet, so stay positive.
Last week, I received a "warranty extension" letter from Toyota on this exact issue. They've extended the warranty to 9 years or 120k miles, whichever comes first. Well, we are in the DC area, and 120k miles on a 2004 vehicle is simply not realistic.....and especially since it's a DOOR!!....if it were the engine, I'd be more understanding. Anyway, I contacted Toyota Corporate, and all they will do is recite the warranty to me, and will not even consider an exception to the mileage limit (oh, ours has about 210k miles). OH...and GET THIS!!....one guy I spoke to said that since we do not get our vehicle serviced AT Toyota, they would not consider a Goodwill adjustment to the mileage limit.
Needless to say I am thoroughly disgusted with Toyota over this.....the guy at Corporate said that until it is turned into a Recall, there was nothing he could do. Perhaps if EVERYONE with this issue called corporate to complain, we could get a recall!! Please call their Customer Experience Center at 800-331-4331, and go through the menu until you get a live person. Then, when they tell you that you are over the mileage limit (if you indeed are....otherwise, go get the service covered under the extended warranty), insist on escalating the issue and request to speak to a manager.....they'll tell you "he/she is not available", but insist on a call back. And if you really want to ensure the message is getting through, everyone should ask for the same manger, Steve Gardner.
Ok....let's get to work!....call, call, call!!!....let's get this escalated to a Recall and all get our doors fixed!
Both our doors on our 2005 Sienna have been freezing shut since we purchased it new. It was always annoying, but we never took it to the dealer. But this year, my brother in law ripped the handle off trying to force it open. I called Toyota and they were very unsympathetic and told me this was not a common problem and not covered beyond the warranty. I'm glad to hear about the silicone spray. I would not buy or recommend this van again.
It is standard procedure in northern climates to apply 'protectant' to the rubber seals of all vehicle doors in the fall. There are dedicated products available to do this.which are silicone-based. -or- some folks use Vaseline petroleum jelly.
A very thin layer is all that is needed. The doors on treated cars will NEVER freeze shut. (due to the seal icing up)
It is also a good idea to do the same treatment to refrigerator and freezer door seals once in a while too. In this case, it is not to keep the door from freezing shut. Instead, it is maintain a perfect seal around the door to save electricity.
Here are some sample products for this purpose
http://www.autogeek.net/1z-einszett-rubber-care-stick.html
http://www.walmart.com/search/search-ng.do?_rel=303+products&search_constraint=0&search_query=303+aerospace+protectant
http://www.z3bimmer.com/OffTopic/E24Bimmer/Gummi/
Meguiar's M40, or Aerospace 303 would also be great alternatives.
The best stuff I've found was from the Honda parts counter back when I owned an Odyssey: Shin Etsu grease. http://www.amazon.com/Honda-Genuine-Shin-Etsu-Grease/dp/B006Z9TZ9M. 4.8 out of 5 star rating. This product is best used on clean seals. Meguiars rubber & vinyl conditioner is great if you need to clean up old treatments or a lot of dirt first.
Thanks for the pointer to Shin Etsu grease, as it turns out, the BMW product I used to like the best (Gummi-pfledge) is no longer sold in USA. :-(
You are most welcome!
You can find the Gummi-pfledge in Amazon.
Along the very top of the door, where it meets the roof, after running a thin-bladed screwdriver along that seal then carefully and sloooowly prying the door open a little at a time (at the back edge of the door where the window meets the door itself and the door meets the car frame), I noticed by sight and sound, that the door sounded like it was ripping (like slowly tearing paper) at that top area. Once it was opened (it literally just popped open), I discovered that while I had sprayed the front-facing part of that seal, I hadn't gotten the top of it, and lo and behold there was a small strip of frost all along top edge of the seal. Hard to believe such a tiny amount of frost could hold that door closed. So I applied a good bit of silicone spray, and it's working great!
