Jaguar XK Convertible electrical problems
I own a 2007 XK Convertible that has been nothing but trouble. The car fails to start at least twice a month. In the first 10,000 miles I have had 2 battery replacements. I have been afraid to drive it a long distance from my house and really havent gotten much use out of it. The Jaguar service department where I bought the car cannot find the problem. When I complained to corporate headquarters they said they could do nothing for me. In fact when I told Jaguar Credit I was thinking about withholding a lease payment because they could not fix the problem, the response was that they would damage my credit rating. I spent a lot of money for a poor quality vehicle and an organization that simply doesnt care. Has anyone else had this problem?
I have had issues with ASC Not Avail and Engine Fail Safe messages as well as all my rear lights going oiut sporadically. Possibly an electrical short?
and off all the time. The dealer is saying I am not driving my car as required.
My answer maybe you should have had a disclaimer that if there is less ,mileage in your car you will have engine light problems
I have driven lots of jaguar with low mileage but never had any problems
The records are with dealer
The car has been to Canada - Edmonton dealer last year for 3 months
costing over $4500 and is back to the dealer - will keep you posted
nshariff
ALL of the problems complained about here are the result of low battery voltage - and yes, if you do not drive the car daily, this will happen. This is NOT a "Jaguar problem" - it happens frequently will all modern computer-laden cars. When the battery voltage drops you will get random electronic symptoms: warning lights, window, seat, convertible top, SatNav problems, etc. ALL of which are caused by battery issues. If your battery is more than 3 years old - replace it. But the very BEST thing you can do, which will permanently eliminate any electrical issues is to keep the Jag on a "battery minder", permanently attached, and plugged in when the car is not actually in use. The new version XK (2007 on) is a superb car. But if you think it has the same electrical demands as a 1995 car, you are very much mistaken. It needs full voltage, all the time.
I was the second owner of an '09 XK coupe. It was my regular driver for 2.5 years, I locked it every time I parked it, no matter where. Luckily, I had none of the issues noted in this forum. I just traded it on a '13 XF, the XK had the original battery, ~4.5 years old. Had I kept the XK, I would have put a new battery in before it was 5 y.o. Great car, I miss it...
I have an XKR 2009 the new 5 litre engine model. It has behaved perfectly from new until now (2014) when electrical problems have started. Battery not charging light (on for a couple of milliseconds on start-up) Then smart key not found (despite new batteries) so had to insert key in slot. Then adaptive headlights warning, then the alarm went off for no apparant reason. Dealer reckons it may be the earth "node" that is faulty and corroded. This is inside the vehicle it seems. New earth node to be replaced this week which will take at least four hours as body panels need to be removed. Hmmmm......sounds expensive. Anyone had similar probems with the 2009 model ??
A well known issue with these cars:
http://www.honestjohn.co.uk/forum/post/?t=91121
