Nissan Altima Winter Driving
I am planning to purchase a 2008 Altima with the 2.5 engine w/o traction control and I live in Wisconsin. I really like the car, but I read a few posts from other message boards that said this car handles poorly in snow. Can anyone confirm that this car handles OK in snow? Do I need to purchase snow tires for this car?
Thanks in advance!
Thanks in advance!
Unfortunately, I don't know how the car handles in the snow. If traction control is a must for you, the 2008 Accord comes standard with it.
One thing to note is these tires are speed rated tires which are not normally very good in the snow. I plan on replacing my tires next year with a non speed rated tires to see if the traction improves.
I do not know whether the 4 is more stable or not. But, please for your own safety and the safety of your family, do not purchase a Nissan 2008 Altima V6 for northern climates.
It really bugs me that both Nissan and Toyota are putting cheap, junky tires on their cars, just to reduce the sticker price. The same thing happened with my 2004 Highlander: I got just over 25K on stock tires before they wore out.
I did not think that the 2.5 has the CVT. I thought CVT was only available on the 3.5 (v6). Anyone know if this is correct?
It is surprising that Nissan would put a top of the line tire on a car since typically all car manufactures put average/mediocre tires as OEM!
The car is parked in the cold outside for hours. So its interior is as cold as the outside, if not more. The outside temperature is showing to be in the upper 30s. I start the engine and then set the temperature to 90 degree with "dual" turned off and "auto" turned on. The air blows towards the leg and the fan speed is lowest. It stays like that forever even after the engine warms up.
In such situation, I expect the air to blow towards the face (or face and leg) and the fan speed to be maximum. But that is not what happens in my car. Is this normal? Or, do I have a problem with some sensor related to the automatic temperature control?
Winter handling is made difficult because of the tires. It's worse with older cars without ABS!
Best things to do for winter driving in the Altima:
1. Drive SLOWER
2. Drive carefully
3. Get new All Season Tires or just get snow tires if winter snow is that bad in your area
4.
