http://www.kbb.com
TIA
Gonefishin
http://www.gmpartsdirect.com/index.cfm
http://www.gmotors.com/
I took my 01 YukXL in for the same tire wear problem. I have tombstones (a.k.a. Firestone) on the truck they had 10,674 miles and I went in for LOF and rotation of tires. The service manager told me that the tires were bad and failed "road force and balance" He ordered me two new tires against service bulletin #00-03-10-007 under warranty. So I'm wondering if its suspension or tire QA? No other problems with the vehicle what so everl. Hope this aids your battle with your delearship. No adjustment to suspension required!
ndared1
No offense, but why do you find if necessary to belittle things you have no control over? May I add, why would one really want 4 wheel steering on a light duty SUV? Too be cooler than your neighbor?
I have an 02 Suburban, it is supurb, I do not want nor need 2 tone paint, 4 wheel steering or most of the other bells and whistles that you crave.
By the way we find a 13" tv with built in DVD player works wonders between the two front buckets for the kids (with and sometimes without) headphones, and the savings are in the neighborhood of over $1000 compared to a built in system or a notbook pc.
Perhaps you are simply venting frustration, but it is beginning to sound like whining or poking others in the ribs, I for one am tired of hearing it.
Get that Ford and have a great life.
Robert
As far as 4 wheel steering - it seems someone had posted here that it would be available on the 1/2 ton suburban. If it were avail. I would change from a Tahoe to a Suburban desire.
Of course if you had spinal problems and couldn`t easily turn to judge close parking, you would see the benefit of four wheel steering in Tahoe or Sub. Don`t feel the need to be cool at all, do feel the need to have a truck to fit my needs. I won`t be cool when I sell the aluminum wheels supplied and change to painted steel wheels.
I apologize for hurting your feelings and will try to ease up.
Better yet will post rarely. Will do more reading and less writing. Have a great life all.
I'm really surprised that there aren't more postings on this problem, i am finding that very few of the suburbans or tahoes that i check out don't at least have some minor cupping.
I also have a 95 k1500 p'up with the turbo diesel. i removed the stock goodyears at 10,000mi.(only because i didn't care for them).i put on a set of dunlop rv's that i finally had to replace at 80,000mi.,and they were still road legal. i can only hope that i can get that same kind of tire mileage on the suburban.
As far as the rest of the suburban goes, everything else seems to be ok so far. i just hope that the dreaded "gm eng. knock" doesn't rear its ugly head.
The only vehicle that could get me out of this sub., is when they finally offer the duramax diesel as an option. that knocking i can live with!
To rzurawik, i'd hold out for dealer cost, "plus" the 0% financing.
Any advice is appreciated!
IF you have a need for 4wheel steering either wait for 04, get a smaller vehicle, or get the HD model. It really not hard.
I guess it seems you want it all, and don't want to have to do anything to make it happen.
It does not work that way. There are tradeoffs all the way.
What about the Yukon/or Yukon XL series, if you have all the $$$ for the options that you want, surely the upgrade to that line is doable too.
Tradeoffs/
the strange thing is that both my wife's '01 4wd Subn and my '01 Z71 have the same problem with different brand tires..this is gonna get good.. I can feel it..
I had test driven it before but when I was on the way home noticed that the venicle would sort of "bounce" or "quiver" when driving on a fairly smooth road.
Now this was not a perfect black top and I expected the Z71 to be a little stiff naturally but this seems a little odd.
Is it because of the Surburban's long wheelbase in conjunction with the stiffer shocks?
Is this normal?
Is there any way to tone down the stiffness of the suspension any?
I mainly got the Z71 for the looks and features that were the middle of the road from the LS to LT but will do some minor off roading and gravel travelling from time to time.
tidester
SUVs; Aftermarket & Accessories
It has to be going somewhere, so you gotta find it. Heck it might be a cracked fluid bottle, or the seam might be not sealed all the way. Try to get them to swap that part out first. Also have them check the water pump for a seal leak.
The vehicle checks out great, and I got a 4 yr/48K extended warranty on it.
My question: assuming I put less than 10K a year on it and only engage 4WD once a year for the infrequent snows we get, what kind of problems should I look forward to? My understanding of this vehicle is that I should be able to go about 150K without much problem. The 5.7 L engine has a long lineage (from the 350 V8 GM has made for years), and the 4 speed automatic also appears to be fairly reliable.
Thanks from a previous owner of a 1995 Ford Windstar which ate head gaskets and transmissions.
Out west here we have mountains. So towing 6000 lbs. of boat, trailer, kids, through those mountain passes is a non-trivial task.
The 5300 motor in the 1500 does not do it for me.
The 8100 motor is downright kickass but fuel economy prohibitive.
That said, the 6000 with the 4.10 rear gear is where I'm headed.
However the "look" of the enormous gap between the fender well and the stock 16" 8 lug wheel/tire combo is wayyyy too much!
I contacted Bell Tech and they said they have no lowering kits for the 2500 series.
Do any of you know a lowering solution to what I consider a somewhat frustrating dilemma?
Thanx
Very strange?
Does anyone know how long it usually takes for a vehicle to be built and delivered?
Chris
http://www.angelfire.com/tx5/gmpistonslap/
denali any time in the future? .
the front end checked and it's ok. My G M dealer also says he can find nothing wrong. Any ideas?
* Color keyed moldings and handles.
* OnStar.
* Electrochromatic inside mirror.
* Heated seats.
* Automatic climate control.
