http://www.yarisworld.com/forums/showthread.php?p=624601#post624601
Maybe one of the more knowledgeable people will chime in; I'm definitely not any kind of great mechanic...
Also, if you ever need engine codes read, Auto Zone will do it free. And Harbor Freight has cheapo code readers for about $40
Right off the bat though I have this advice.
Stay away from the dealer unless you want to spend $$$$ for nothing.
I think its a good sign the noise doesnt get more or less frequent. Also that there are no engine codes. Its just one of those noises that dont mean trouble just drive you crazy.
You will get used to it and it will become "normal".
But its possible the cause will be revealed to you one day.
If so post it here for others to benefit!
After my car was off warrenty, I started taking it to another business for servicing and they asked me if I wanted one installed, since mine was missing. I told them what I had been told and they just started laughing, and then showed me where to find it.
Since then I have replaced my own every year - it's easy. I am an older female and don't appreciate service personnel pulling the wool over my eyes - I have not been back to the local Toyota dealership since that time.
For anyone with allergies - the cabin filter is a godsend!
For my Echo, Scion, and Sienna I buy a big home air conditioner filter, and cut pieces to fit each car. Really cheap, and looks to be a better filter than the ones from the auto parts store.
Have you looked in junkyards?
Go online used parts and ask people.
I think you will see it is very reliable.
Be careful cause the cars good repair record is well known and scum are selling them for top dollar. You could get scamed with car with major problems...
Still, not bad considering (and the trunk issue should be fairly easy to fix).
You might consider on line junkyards they wight be cheaper than $100.
mIGHT.
The lock and the trunk problems can be fixed but might entail doing cosmetic dammage to the car.
Or not if you are good at that sort of thing.
Since they can be worked around they are pretty much part of the ageing process and not critical like a tranmission or internal engine problem would be.
The car is flat out amazing longevity wise.
EXCEPT
if the CEL goes on the mass air flow sensor is often why. THESE THINGS ARE KNOWN TO FAIL AS THE CAR AGES.
gOOD LUCK AND TELL US WHAT HAPPENS AND YOUR IMPRESSSIONS!
sorry for caps!
herm.mark@gmail.com
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Can you add this to the Echo's as well???
The good news for ECHO owners is the cable allows a smooth transition from standing still to moving. Like at a light or stop sign. The fly by wire of the Yaris has a very jerky and uneven transition.
I wish I had an ECHO but my son still has his!
My '12 Yaris SE is much much more fun to drive, what with the vastly improved handling and somewhat better steering as well. The deal-breaker in this car is unfortunately the throttle-by-wire, which is so calibrated so poorly that you have to count one-one-thousand-two-one-thousand after you press the gas pedal before the engine starts to rev. And it actually has "dead" space - the first couple inches of travel of the pedal don't cause the engine to rev at all, even if you sit there for a count of ten.
I think they do it in the name of fuel efficiency, but all it does is irritate the driver immensely and make the stick-shift version almost impossible to drive smoothly. This is the first time I have ever leased, and I was sort of thinking of buying it at the end of the lease when I first picked it up. Now I think they would have to offer me a really great deal, WAY below the residual price listed in the paperwork, for me to buy this out of the lease, just because of that issue.
It's still great as cheap transportation though, and I continue to pull 40 MPG on average, which is nice even though gas prices really didn't jump up this summer like in years past.
I think more people are buying small cars now and that may be the reason for the price stability of gas. Certainly the average use of a vehicle, a short trip to work with a single occupant, doesnt justify a Ford F150 with a V8 engine, or even a V6 in a sedan. Buying a big car which is what the public does, gaurantees they will pay through the nose for gas. Its like putting a sign on your back that says "KICK ME!"
Dont worry gas is going up in the long run...
My Subaru also has e-throttle, but it revs right away and quickly with pressure on the gas pedal. Toyota should have made the one in the Yaris mimic the old days of being connected to the throttle plate by a cable more than they did.
My old Echo was old enough to still actually have a cable connection to the throttle. I miss that soooo much in the car that replaced it.... :-(
Are you on Yaris World?
I bought a 2000 Echo with about 155k miles three years ago for a second car, and have been extremely pleased with it. Only real issue right now is a recurring problem with auto trans slipping. problem begins with while driving residential speed of maybe 30mph trans will slip, or disengage, engine revs, and after coasting a few seconds, will reengage and function normally. however at same time, speedometer will go crazy; down to zero, bounce back up, etc. Check engine light comes on also. speedometer error will continue even if trans does not slip anymore. condition will persist maybe several days intermittently, and then disappear for many months. Normal use of the car is usually around only 150 miles per month. I found a similar posting here; any suggestions?
Thanks guys...
At 150 miles a month/1500 miles a year it doesnt make sense to fix it. Just take your foot off the gas when it slips. Just drive it!
Is the trans oil level good?
Get a used trans from a junkyard and have a shop put it in. Either now or when it goes.
Please post whenever you feel like it!
The ECHO is too good a car not to have followers and a place people who own them/have problems can talk about!
And its lonely being the only one here!
But keep in touch and the best of luck with your ECHO!
It's a good thing too, because he is trying to pay off his wife's car before replacing the Echo, and so hopes to get another couple of years out of the old Echo. I told him he had to let me know when it crosses the 200K threshold. ;-)
Mine was a 5-speed, 4-door. And on a sidenote: I just traded in the '12 Yaris that replaced it. Just not a good enough car to go on paying for after the lease was up. Did not have the purity of purpose the Echo had, and felt much cheaper, more poorly designed, and less well put together than the Echo. So I have moved up to a Civic SI and put Toyota in my rear-view mirror - first time in 25 years I haven't owned a Toyota, and not sure when I will be going back, if ever.
MY 09 Yaris has needed a water pump and the oil pressure sensor recently leaked and had to be replaced! 35k miles.
Still I feel the Yaris is the only thing out there for me...
Its possible I will swap my Yaris for my sons 2000 ECHO. It has ~200k and my son needs a newer car maybe. I just need to drive to work for another year...
All in all I think my new car buying days are over.
I haven't checked in for a few years but I still drive my 01 Echo sedan daily. It's been banged up by bigger cars but at 184,000 miles it still drives like new. I finally replaced the battery this winter, I thought it'd never die! 13 years in a very cold climate, good job Toyota!
I put Cooper snow tires on the Echo and it makes all the difference in winter driving! When my Echo does meet it's end I'll buy another one! A great money saver overlooked by many!
Hi folks I wrote a book!
See it at www.outskirtspress.com
Click on bookstore and search for The Storys
The best small car made IMHO!
