Toyota Camry Windshield Defect?
in Toyota
I am in Austin, TX. I have a 2005 Camry LE 4D Sedan. Last week, we had a severe winter storm down here for around 4 days. My car was covered with ice all around for around 3 days before I cleaned up the ice with a piece of plastic scraper and the built-in heater in back windshield last Wednesday.
Then I used the car for two day's daily commute and weekend shopping without seen any problem.
But this Monday morning, I found out that the back windshiled was totally cracked but still in shape, fully with fine cracks all over the place. It looks just like someone used a small hammer cracked the back windshield carefully and did not break it. Then I wanted to drive to a Toyota dealership in town to have them check it out and fix it. But on the way to the dealership place, the back windshiled started falling down pieces by pieces. Each piece is in size of green pea.
In one Toyota dealership, I was told that this kind of damage is not coverd by Toyota warrantee. And then this was confirmed by North America Toyota Customer Service Center.
I do not believe that this should be the case! It definitely caused by the bad quality of the back windshiled. It should be the defect during the manufacturing of this piece of windshield. I am just out of luck and got this bad quality windshield.
Of course, I will have my insurance company to fix it as a damage case. But I do not believe that Toyota is out of the situation. They are the one that should take the full responsibility and pay for my lost.
I am wondering if anyone else here knows/experienced this problem. And any suggestions on arguing with Toyota on my situation will be appreciated.
Thanks in advance!
Best regards,
Richard
Thanks in advance!
Best regards,
Richard
Unfortunately, you really have no idea why the window broke, and would be probably hard pressed to prove a case w/Toyota. If they saw a number of these break, or folks on the board here started reporting the same thing....they "might" think something was wrong.
Somebody could have thrown a rock, shot it out, hit it with a bat, or it could have been somehow defective or installed incorrectly.
Be glad you have insurance to cover it.
Too bad.
The dealer don't think it is quality related and refuse to cover it with warranty. I have a $500 deductible so basically we need to pay for the repair.
I knew one case that the door glass of my friend's 10 year old camry automatically shattered, but my car is only 1.5 year old.
Please share your information if you have similar experience.
I'm Very Sorry for the inaccurate message above.
Thanks for letting us know!
I own a Toyota camry 2009. There was a winter storm and it heavily snowed here in Virginia today. Just like others I cleaned the car's wind shield with a scraper and then turned on the heat. After a few minutes I heard a crackling noise and noticed a 4-5 inch long crack on two different locations on wind shield.
After reading this post, I get a feeling that it has definitely to do something with the quality of the glass.
My vehicle is covered under platinum warranty. Not sure if Toyota will honor it to replace the glass. This is clearly an issue with the quality of the glass.
Glass defects are inherent in the manufacturing process. I think they are usually handled as insurance claims. I do vaguely recall a case or two in the past where the factory admitted to some structural problem causing glass breakage, but gee, proving that would be a long haul for the poor owner. We have a topic here in the Forums on spontaneously exploding sunroofs, and owners all report them as being handled by insurance.
No visible sign of rock chip or damage. I don't know if it is perhaps due to some defect in the glass? The temperature was around 70 degrees Fahrenheit so I don't suspect thermal expansion or a rock chip (since it wasn't being driving when the crack happened).
