C6 Shock replacement
bust_itbust_it Member Posts: 26
edited March 2014 in Chevrolet
My 2007 C-6 has 92,000 miles on it. How often should the shocks be replaced?
  • ndmike88ndmike88 Member Posts: 155
    How does it ride??? Are they leaking??
    Worth checking for leaks at this mileage. Sometimes your car may need shocks but not so badly that you would notice it, until you actually replaced them. If you are satisfied with the ride and handlling, and no leakage is detected, or any noises over bumps, or creaks and moans while turning, then you are probably still okay. Short answer: Your shocks definitely have wear on them, but may not be "worn out". Maybe you'd like to upgrade, so think about that, too.
  • bust_itbust_it Member Posts: 26
    Haven't been on here in a while. There is a slight rattle when on a bumpy road or parking lot. But it still rides good!
