Turn signal problems
I have a 2005 Yukon denali it kept blowing the left turn signal fuse I put a larger fuse in it and it worked for a while now the fuse is good and the bulbs are good but my left turn signal will not work at all the right side works find. can any one help me so I can fix the problem Thank You
Best Answers
ray80
Member Posts: 1,655
I would guess its likely a short somewhere, could be troublesome to find exactly where but I would start near the light sockets. ( I would also suggest putting a larger fuse in is never a good idea)
5 -
Mr_Shiftright
Member Posts: 64,481
A good technician can track this down If he knows what he's doing he'd start by using a Fuse Buddy:
http://www.esitest.com/fuse_buddy.html
These tools are not expensive. Autozone carries them for about $20 bucks. They help you isolate the circuit that is shorting out.
5
