2008 Honda Civic A/C question
in Honda
I have a 2008 Honda Civic LX 4 door sedan with about 115,000 miles. My problem is that when I am driving, the air conditioning doesnt work. Anyone know what can be the problem.?? Thanks in advance for your help.
I'm assuming that the fan is running OK and that it's just not producing cold air.
MODERATOR /ADMINISTRATOR
Review your vehicle
http://www.thelinlawfirm.com/honda-civic-ac-condenser-problems/
I had that problem.Turned out to be a fuse.
First thing I would do is re charge the system with Freon or the new replacement for it. It will cost you about 10 bucks. If that doesn't work, its the compressor.
Which bad fuse was causing the AC problem in your Honda?
