Toyota Avalon Water Leaks
My 2006 Avalon Ltd has been in shop for 3+ weeks for water leak. Second time water has gotten into car. 1st time was a cracked cowl at windshield, took 3 trips back to get the moldy, smelly carpet replaced. this time the leak is from a disconnected hose at sunroof that let water under carpet behind driver. Toyota is replacing carpet again, cleaned interior metal surfaces with bleach to get rid of mold, and replaced all seat foam. I am worried that once the warranty is up I will continue to have water leaks. Anyone else having water filtration in cabin? And don't get me going on the worthless nav system, for 2500 bucks it doesn't reliably take you anywhere.
I have an 07 avy xls and about 3 months after I bought it I ran into a water leak.. My car was parked in a parking lot during a down pour.. when i got in the car I noticed a little water on the dash.. thought it must have been something I "splashed" in in my haste to get into the car and out of the rain.. but when I started to drive the car, I noticed water coming out of the speakers on both A pillars..... couldn't believeit... took it straight back to the dealer.. turns out drain tubes on the sunroof were not "hooked up".... they hooked em up and havent had a problelm since..
Roland
Thanks for the response. This same drain tube at the sunroof became detached and lead to the water getting under the carpet.
Some people think call it the a frame.
The moon roof does not have any internal drains that i can find.
I can't find and specs or images of moon roof layout.
When closed water runs down the front windsshield side.
So is it leaking inside of moon roof frame or is the windshield leaking.
I just found this.
So moon roof or windshield?
Component Description:
34. STRUCTURE:BODY Bulletin Number: BO03100
Bulletin Date: NOV 2000
Vehicle: 2000 Toyota Avalon
Summary:
PRODUCTION IMPROVEMENTS HAVE BEEN MADE TO MINIMIZE THE GAP BETWEEN ROOF BODY PANELS. A FIELD FIX IS AVAILABLE FOR INSTANCES WHERE THE SEALER UNDER THE ROOF MOLDING MAY BE INCOMPLETE ALLOWING WATER TO ENTER THE VEHICLE. ( NHTSA ITEM NUMBER - 616099 )
And what is the best fix?
Thanks....
I called the dealership it's a about 250.00 to take it apart and clean it.
Way too much.
OK i find these 2.
On another forum a guy said use a air pump to see it it clears and another a guitar string to auger it out.
So if anyone else has a problem hopefully they can fix it.
http://www.toyotanation.com/forum/showthread.php?t=270195
http://www.corrado-club.com/faq/detail_faq.CFM?FAQID=144
I'll try it tomorrow and let y'all know how it goes.
Good Luck to ALL!
2003 Toyota Avalon Water leak on passenger and rear floor boards (more in rear).
1.Sunroof doesn't appear to be clogged or disconnected. Drains outside.
2. Poured water on outside of windows and appears to drain properly outside.
3. Trunk is dry
4. Speakers went erratic with serious static and eventually stopped. After sucking out water and two days, radio worked and static only happened when changing stations.
4. Covered car with tarp during next rain. Some water continued, but not nearly the amount when first discovered.
5. Radio stopped working again.
I'm assuming there might be wiring running trough the floor boards?
Is there anything that could be coming from the engine to check?
What should be checked next?
