2001 olds alero flooding and rough idle
nagad2012nagad2012 Member Posts: 3
edited April 2014 in Oldsmobile
I have a 2001 2.4l oldsmobile alero it was running fine. Then all of a sudden going up a hill the car started to lose power. I just recently changed the plugs and coil, I put new ones in last night since the old ones was covered in carbon. It is using a unreal amount if fuel and it only runs decent at higher rpms.
Best Answers
Answers
  • nagad2012nagad2012 Member Posts: 3
    Got it thanks for the info the fuel pressure regulator was cause the car to flood and one of the coil packs went back
    Fuel was in the vacuum line
    Your original post contained good facts about what you saw and what happened. That helped give clues to potential problems--over rich mixture due to carbon on plugs.
