Ford Ranger Radiator Issues
traci1962traci1962 Member Posts: 3
edited June 2017 in Ford
Hey there. I have a 2002 Ranger xlt 2.3 5speed and in the spring i ended up replacing the thermostat, housing and hoses. The truck has run like a champ. The past couple of weeks I have the issue with the temp guaging rising until it nearly hits the overheating mark but before it does, it mysteriously drops down rapidly to the normal level and this process keeps repeating itself every time i drive it.
    bolivarbolivar Member Posts: 2,316
    Thermostat sticking closed, then opening. I've had a new one do exactly this same thing.
    Why oh why does everyone on the Ranger area have to start a new thread for their problem???
    My bad on the new thread. I will have to feign "newbieness" to any type of forum like this. I wasnt even aware something like this was avail. online until it was mentioned in passing. Now I know how these forums work. I DO however, appreciate your reply with your experience. :)
    tracy13tracy13 Member Posts: 2
    I find that unlike the repair manuals say the heater hose and lower radiator hose attach to a approx 8" pipe that inserts into the pump body. This pipe runs behind the belt tensioner and through the generator bracket. There is a brace welded to this pipe that bolts to the generator bracket. To remove the pump this pipe must be pulled out of the pump body from underneath the truck OR the generator and everthing assoc with the genrator bracket and belt tensioner must be removed so the pump with the pipe still attached can be removed. The question is "What holds the pipe in the pump body?" Is it just permatex or is it pressed on? HELP before I break something. Thanks
    KCRamKCRam Member Posts: 3,516
    Actually, we didn't have a focused discussion on radiator issues, so this is just as good a place as any (not the new name over the door).
    kcram - Pickups Host
    rangerman1998rangerman1998 Member Posts: 13
    hey guys i have a 1998 ford ranger with 138,000 miles on it and my coolant temp gauge wont go above the cold even after driving for 2 hrs any suggestions would work
    is it something that i should worry about or no :mad:
    Does the heater get warm?
    If so, it's probably just the gauge or it's wiring.
    If no heat from the heater, the themostat is probably stuck open. A new one should fix this.
    For the best milage, and best 'wear' on the motor, the correct, functioning themostat should be in the truck. The motor need to warm up to the expected temperature for the oil to do it's best work, and the best milage. Don't continue to run a vehicle with no themostat or one stuck open. It's not fatal, but does no good to the truck.
    yes the heater does get warm i get really hot heat not right away but like normal so u think its the wiring or something like that. should i have it fixed is it expensive to get it fixed or not worry about it
    06xlt06xlt Member Posts: 7
    the factory thermostat is 160 degree and shows on the gauge as cold ,,, this will allow the engine to run rich which means less mpg I ve ran into this on many ford ranger and mini vans replace the thermostat with a minimum of 180 degree and you will see better mpg and over all performance you may want to check the 02 scencers for proper operation at the same time.
    the factory thermostat is 160 degree and shows on the gauge as cold ,,, this will allow the engine to run rich which means less mpg I've ran into this on many ford ranger and mini vans. replace the thermostat with a minimum of 180 degree and you will see better mpg and over all performance you may want to check the 02 sencers for proper operation at the same time.
    so if i switch the thermostat the gauge should go up to the middle like normal or could it be a problem with the wiring on the gauge
    i looked on the internet the factory setting for the thermostat is 195 does that mean my wiring is bad in the gauge or does it still only havea 160 degree thermostat :confuse:
    tostavotostavo Member Posts: 1
    you should chek the thermostat,i had the same problem ,i repaced the thrnostat and no more problem
    svaciksvacik Member Posts: 1
    I have replace the thermostat, flushed it 3 times, radiator cap, and still the system builds pressure while driving to blow the lid off the reserve tank. The temp gauge will be normal then start going in reverse to the cold side and at that point it blows the lid off the reserve tank and sprays coolant all over. Does anyone have an idea why it is doing this please?
    printman716printman716 Member Posts: 3
    Svacik....Did you find out anything about yout problem???? I'm having the same thing happing to my 98 ranger! Let me know.....Phil @ printman716@aol.com
    This Is happing to my truck too......everybody saying things to do.....and I have done everything they are saying and still the system builds pressure while driving and blowing the lid off the reserve tank. The temp gauge will be normal then start going in reverse to the cold side. I get warm heat. I need someone that had this happen to them and fixed It. I mean no offence to anybody but this in gonna cost me my truck. I'm gonna dump It, but I like it alot. H.E.L.P. Please......Phil @ printman716@aol.com
    I'm at my wits end! Does anybody know what the .... going on with this truck? I replaced everything, the cap, thermostat, control knobs, hoses, flushed 3 times, and still temp gauge goes up and down and no heat, it used to build pressure and back out the tank but that stopped. I found the Consumer Guide Review on this and this is what it says to do. Question Is did anybody have this problem and fixed It!?!?
    Accessory belt: Squealing serpentine drive belt due to faulty water pump pulley on 4.6L V6 engine. (2001)
    Air conditioner: The air-conditioner hose may rub against the radiator hose and one, or both, develop
    leaks. (1998)
    Audio system: The in-tank fuel pump causes a whining or buzzing noise to come through the radio
    speakers. (1998-99)
    Battery: The battery tray may have burrs that cut into the battery causing it to leak and eventually fail.
    (1998)
    Engine misfire: Hesitation or surging when accelerating is caused by a faulty mass airflow sensor. (1998-
    99)
    Engine misfire: The truck may feel like it is thumping or jerking under acceleration due to a problem with
    the driveshaft requiring replacement. (1998-99)
    Heater core: Installing a restrictor in the heater inlet hose may repair heater cores leaks. (1998-2002)
    Timing belt: The timing chain on 4.0-liter V6 may make noise in hard acceleration. A repair kit is available.
    (1999-2000)
    Transmission problems: Transmission flare when shifting from 2nd to 3rd gear is due to shift solenoid
    malfunction. (1998-2001)
    Vehicle noise: A hammering noise occurs due to steam forming in the cooling system requiring a coolant bypass
    retrofit kit. (1998-00)
    Please let me know....Phil
    nipit82nipit82 Member Posts: 2
    Phil.. did you ever figure out what the problem was? I'm having a similar problem. I have 99 ranger 3.0. I had my coolent system flushed and a new thermostat put in about 3 years ago. Nothing wrong with the old one, just wanted a new one put in. I put the same type thermostat in that came out of it.. 195 or 197. Afterwords, my temp gauge would not get up to normal operating temperature like it used to and would fluctuate about a third of the way up. My heater still blowed out good heat though. Afterwords I noticed my mpg dropped from an average of 21mpg to 18mpg. Well, It was time to service my truck again and I told the mechanic to go ahead and put another thermostat in to see if that was the problem (195). He did and now the temp gauge runs even lower than what it did before, just above cold. I still have good heat though. He said it could possible be something with the Temp Sending Unit or the Temp Sensor. According to Haynes Repair manual, the Sending Unit controls the temp gauge and check engine light on the instrument panel. The Temp Sensor is used by the computer to determine engine coolant temp and adjust fuel/air mixture. Both sensor and sending unit are screwed in on the thermostat housing. This is why I think my gas millage is suffering because of a cold reading. A cold engine or a cold reading makes the computer stay in Open Loop (Rich Mixture) output that can hurt mpg and emissions. But I don't understand how can replacing the same temp thermostat that came out of it cause the temp gauge to show a colder reading? My theory is that an air bubble gets lodged in the housing after replacing the thermostat and refilling the coolant causing an inaccurate reading from the sending unit... That's all I can figure out. I'm gonna have to do something because my mpg is sucking big time! I'm gonna replace the temp sending unit and temp sensor and see if that does it. I don't know what else to do.
    ritchie21ritchie21 Member Posts: 1
    Mycoolant backs into the reserve tank and will not return into the radiator.I think some of the coolant blows out of the top of the reserve tank as well. I removed the thremostat and nothing changed. Can any one help me? my email is : inspect@sonic.net
    spillmkl1spillmkl1 Member Posts: 1
    Did Ford program all the Rangers to have this exact same problem at the same time??
    Anybody figured it out yet?
    Could it be a clogged heater core? I don't think my 1999 Ranger has a bypass. If the heater core gets clogged, would that cause this weird problem with the guage,
    overflow tank, and cold/hot heating?
    HELP!!!!
    1) Blowing coolant into overflow tank. I assume it's overheating, right? If so, you need to fix overheating problem - stuck thermostat, clogged (inside or outside) radiator, head gasket leak, etc.
    2) To get coolant back into the radiator from the overflow tank, the rubber line from the top of the radiator to the overflow has to be air tight. No cracks, etc. If it is not airtight, air is pulled back into the radiator, not coolant from the tank. Also, the radiator cap has to be working correctly. It basically has a two-way valve in the top of it. If the radiator overheats, the pressure goes up and at a certain pressure the valve opens and coolant flow thru the rad cap, thru the rubber tube, into the overflow. When the rad cools down, the creates a partial vacumn in the rad which opens the valve in the cap in the opposite direction, allowing coolant to be 'sucked' back into the radiator from the overflow tank.
    So, you can see that the radiator cap, it's valve, must be working correctly and there can be no air leaks in the rad cap seal to the radiator and in the rubber hose to the overflow tank. And, in the overflow tank, there is a tube that goes almost to the bottom of the tank. It must be in place, and the hose connection to the top of this tube must not leak, so the coolant will be pulled back into the radiator.
    Oh, and all the other rubber lines in the cooling system must be air tight. If you have a small leak in any of them, rad hoses, heater hoses, etc, then when a motor cools down, air will be pulled into the system at the leak, and it will not form the vacumn to pull coolant back from the overflow tank.
    As a matter of fact, you might have a head gasket leak. This causes a motor to overheat significantly, which would blow coolant into overflow. But with a bad gasket leak, air could be pulled back thru the gasket and coolant not be pulled out of the overflow.
    Basically, if the truck is overheating, you need to work on that first. If it's a head gasket, this is big money to fix.
    tiny43tiny43 Member Posts: 1
    I have a 96 2.3 4 cyl and i cannot find the sending unit my temp gauge pegs out hot always but the truck never runs hot so I am assuming sending unit gauge or connection is bad but I cannot find the sending unit. All suggestions and info will be appreciated.
    lacrossesoakedlacrossesoaked Member Posts: 87
    check at or very near the thermostat. it is not part of multiwire harness. should be a single wire lead to the sending unit. once you "think" you have it located, disconnect it and see if the temp gauge goes to zero.
    delwooddelwood Member Posts: 1
    We are having the same problem described with the overflow tank blowing open and spraying coolant all over, We tried replacing the temp sending unit and sensor but still having the same problem. We are going to try replacing the waterpump next, Has anyone found a solution to this problem? delwood96@yahoo.com
    kschimpflekschimpfle Member Posts: 3
    i have an 98 ranger with a 4.0 when i turn on the heater my temp gauge will go up and down.i have redone the heads and clean the radiater to and a new t-stat.my heater valve is leaking a little and i belive its pulling in air with the heater on.the truck never gets hot.with the heater off its fine.
    Replace the valve, it's a known problem, with the symptoms you've described.
    im going to next payday.this has been a good truck.it has 115000 miles on it.it had 32000 on it when i got it 3 years ago. :shades:
    chuck140chuck140 Member Posts: 1
    did replacing the water pump work cause thats the only thing i havent done
    my truck has a plastic heater valve ,it was leaking a little around the shaft with tthe heater on.it was sucking air and making air pockets and when the air would hit the sencer for the gauge it would go down and when it passed and the nwater came back the gauge would go up.i replaced the heater valve and since i did that it has been ok.
    taco1967taco1967 Member Posts: 1
    I have a 1998 3.0l Ranger and cannot figure the coolant problem out. The heating system worked fine until I flushed it last year. SInce then, I have replaced the thermostat twice, the second time with a quality replacement part, bled the air out of the system, replaced the rad cap, and that hasn't worked.
    The symptoms are: coolant goes to reservoir but will not return. When I tried to get the air out, I followed protocol, but upon opening the throttle to 2000 rpm and completing the fill, the rad fluid just gushes out the open rad neck. I get heat upon initially running the engine, but once the fluid is kicked into the reservoir, heat ceases. The temperature gauge never goes above 1/2 way, and it is not over heating. I do smell coolant in the cab, but not sure if it's just from the top popping off the reservoir. The exhaust has been noticeably thicker and whiter, and no coolant leaks can be detected other than the reservoir overflow.
    Both upper and lower hoses are warm when running, and the water pump does make a ticking noise when running. Please tell me it is either a water pump or even a heater core, not a head gasket. I'm not sure........
    THANKS!
    Bad radiator cap? It get hot and pushes coolant to the overflow reservoir, but the little valve in the cap is not working right. It's not opening up when it cools down and pulling the coolant back into the radiator.
    Or, the rubber hose from the cap to the reservoir is bad. Somewhat same problem, it pushes coolant to the reservoir when hot, but when cooled down the hose allows air to be pulled in rather than coolant from the resevoir.
    Or, it there is a leak in any of the hoses - radiator or heater - the same thing happens. When the coolant cools down, air is pulled into the system rather than coolant being pulled back from the reservior.
    In general, the cooling system has to be air tight everywhere or there will be problems.
    heck44heck44 Member Posts: 1
    i have a 1998 ranger xlt and the temp guage goes crazy when you start the truck it goes from cold to hot but does not overheat. Also when going from park to drive it dies but does not when shifting any other time. thanks
    tinlingtinling Member Posts: 2
    I have a 2000 ranger 3.0 and my thermostat was stuck temp got hot and the pipe fitting for the heater sprung a leak. I managed to remove the broken fitting. It is a brass elbow with a temp sensor that threads on the top and the nipple protrudes from the bottom at an angle. My problem is I have not been able to find a exact fitting but have found one with the nipple coming straight out the back. But the air conditioner rigid pipe is right in the way any suggestions
    DISREGARD***
    Looks like I'll have to find a hose fitting just like the one that came out. There is absolutely no clearance in any other direction.
    ghouldenghoulden Member Posts: 1
    Hi. I'm new to this, so I hope I'm doing this correctly.  I have a 1996 Ford Ranger. I have a coolant leak. It is from the driver side facing the engine. On that side the cap is on top. Going down there is a metal line, down a little there is another metal line, under that there is something that resembles a valve handle, them the house at the bottom. The leak is somewhere above the hose. What is that thing between the hose and metal line? could it be leaking there? Is that something that could be tightened or changed? Or could the leak be from around the line? Thank You for your help.
