2004 Sienna Exhaust Noise
my sienna has a noise originating from the exhaust that sounds like a belt squeaking. the dealer has replaced the gasket 3 times. each time, the squeak goes away for several weeks to months, but then comes back. has anyone else had this problem and what is the final fix?
I replaced mine on my own. The dealership kept re adjusting the belts at my expense. As you said, it solved the problem for a few months but it's back again. I would love to hear if you solved this.
I just did mine a second time, and the noise returned two weeks later. Toyota had a service bulletin about this problem, but the revised gasket they offer doesn't actually fix the problem. Any updates would be appreciated.
