2012 Camry LE recommended Tire pressure seems too high
in Toyota
I often rent a 2012 Toyota Camry LE when I fly to other cities.
When I pick up a Camry from the airport they always fill the tires under 30psi (cold), yet the ride and handling seems ok.
I looked in the door jamb and noticed the recommended tire pressure is 35psi (cold). When I fill the tires to this pressure, the ride is always busy on the freeway and hard in city driving (unlike what a Camry LE should be). I'm using a quality guage to measure inflation.
Just wondering if others noticed the same issue.
The vehicle tire placard is required by law and given recent events, what is imprinted there is carefully considered.
I'm going to suggest that your second guessing the vehicle manufacturer on tire pressure is a lot like Russian Roulette.
Yes, I agree with chunt5's post. I have an 12 LE and my tire pressure now is around 35psi. The ride is still very smooth and more composed ride on freeway.
Now, from 2012 to later model, I have noticed Toyota engineer to allow the car to coast much more than older model. So if you guys keep tire pressure at 40 or 45psi with low resistance rolling tires, it is very dangerous and very likely you will "kiss" :@ someone's rear end pretty soon.
A couple of thoughts:
Every vehicle sold in the US has a vehicle tire placard that lists the original tire size and the proper pressure for that size. Starting in 2008, the vehicle tire placard will be on the driver's door frame.
According to Tire Guides, the vehicle tire placard for a 2012 Camry ought to say ..... ah ..... well, it varies so, you'll have to look.
DO NOT ASSUME the vehicle dealer or the tire dealer is going to set the pressures correctly.
I'd rather have a tire that was 2 lbs over than 2 lbs under.
