1996 Ford Taurus GL 3.0 Fuel problem
jth1234jth1234 Member Posts: 2
edited July 2014 in Ford
fuel pump runs, no fuel at inlet side of fuel pump. Any ideas on the cause of this.
Answers
  • jth1234jth1234 Member Posts: 2
    no fuel at inlet side of fuel filter.
  • if fuel filter has not been swapped, it is probably clogged, please consider to replace it? if fuel filter has been swapped, issue could be clog in fuel line from fuel tank, or clog on fuel intake/screen inside fuel tank? also while testing possibly consider to remove/loosen/retighten fuel filler cap to equalize/vary pressure within the fuel tank.
