has 500.00 lease rebate in N/E section.
Thanks for you time.
But, my question still remains unanswered...
Are there any differences to purchasing a vehicle in Upstate NY versus purchasing the same vehicle in Florida?
I am looking to move to Florida in the next few weeks and I am not sure if I should trade-in my black Dodge Avenger here in Upstate NY for a Ford Escape, or if I should just trade it in down there in Florida for an Escape.
Oh, also, I just spoke with my local dealer and he said that there is a new $1000 rebate available on all new Ford Escapes!
Just some good news to pass along.
I guess its just six of one, half a dozen of the other!
Thanks again!
Carolina_ee
Once the light goes on, it takes a very long time (even after the condition causing fault has been corrected) for the light to 'go out'..
You can reset it manually by disconnecting the battery for 10minutes or so..
If your not suffering any drivability problems I would recommend:
a. check the gas cap, was it loose at any time while the engine was running?
b. reset the computer (battery disconnect/reconnect)
If the light comes on again, then off to a garage to have a computer hooked up to tell you what sensor is throwing the code.
Gas cap is a huge one for the engine light coming on.. Make sure the seal is good. The gas/fuel system vacuums down and keeps any vapors from entering the environment.
Gas cap is a great place to start. If there is a bad seal it will cause engine light to come on probably.
its scheduled to be build this week (April 15th)
with delivery to the dealer scheduled for the week of
5/6/02. the sticker was 26,100 and i got it at the A-Plan price of 23,289. I have been tracking it through the 1-800 ford number where you can track the progress of your order if you have the dealer number and Vin number.
I have been reading this board, and i am hoping i will have many troble free miles with this new truck. i and downsizing from a 2 door explorer sport.
Anyone in this forum experienced anything similar, and if so, were you able to get it fixed ??
Thanks in advance for any help and/or advice you can offer....
Gary
Mechanical items just need adjustment sometimes due to "break-in"...
Moonlight.. it may be to your advantage to get a new Escape. Watch the ads.. In my region you can get new XLS V6's for $18,888.
According to the dealership, Ford engineers are taking another look at the profile of the horizontal rails themselves. Seems that they're claiming their current cross-sectional profile is very akin to an airplane wing....the higher the wind shear over the top, the more the bar wants to 'lift'....but it can't go very far....it can only vibrate.
What ever the 'real' cause is, I can vouch that it's !@#$ annoying, that's for sure.
If I find anything, I'll be sure to post the solution.
Gary
Ericsmith: You may want to try another dealer. It sounds like the mechanic is just guessing about the problem. My F150 was doing poorly after I got it and they kept replacing the ox sensor. After several pathetic trips to the dealer, I went to another one. The mechanic found that I had a bad distributor and ended my woes.
I'm with your wife when it comes to choosing transmissions, but I was willing to sacrifice the manual because of the exceptional power of the V6 w/ auto trans. Make sure she drives both engines before making a decision because it is definintly worth the extra money if you ask me and most other members of these boards.
Happy hunting.
I looked at the 2002 XLT Premium.
Can any one explain the A-Plan price????
I'm a first time buyer so any info on this car can help. I'm located in California.
Thanks again!
-Bonnie
your are describing twice in 18 months on my
wife's 2001 XLT 4x4. The engine shut off and
I was able to restart with no problem. Spoke to
a new 2002 model owner last month and he had the
problem twice in one month. I recently met a Ford
dealer service Mgr. and asked him about the problem. He said Ford just released a fix that requires re-programming the computer. I plan to take my truck in at my convenience to get the fix
installed. Good luck!
Does anyone have experience with larger tires?
I want to change from 235/70SR16 to LT245/75 size.
Diameter increase is 1.5" and tread width goes up
by .3"
Any helpful remarks??
Also, you might get a good answer from Tirerack.com.
Still very happy with the overall performance, as we have had zero problems.
Just a side note, I have seen a couple of the new black Escapes without the plastic side moldings and think they look very good.
Thanks again!
I do however, think the Escape and Tribute are a more attractive vehicle then the similiar ones made by Honda and Toyota.
Now back to dave.. I will be more politically correct.
Dave. What about Honda hiding TSB's, or the Toyota sludge?
The Escape is a reliable vehicle.. get out on the net and find the rooms..
My Escape has been wonderful..
Although it wasn't possible for me to purchase it.
Thanks again,
just had first oil change and all else going great - avg. 23 mpg hwy after 3 mos. on my 02XLT
V6.
Q?? - where do you put the headrests when back seats are down? as of now, thats been my biggest problem so I'm a happy camper.
Thanks for the info! I'm taking my Escape in this week to get an oil change, I'll definitely ask about the "fix" then.
I have a detailed copy brochure that shows all of the changes for the upcoming 2003 Escapes if you would like to have a copy of it just email me and I'll be happy to send it to yah. My address is escape2003KCguy@yahoo.com.
