Most of what I've read over in the CR-V board tells me that everyone is buying them for more than $1000 less than sticker.
Never had the stalling problem with my very reliable Escape. 16,000 trouble free wonderful miles. Used it to tow my watercraft, find my fishing spots, skii.. and the Escape purrs right along. Upgrade?? I would not call a RAV4 an upgrade.. nor a CRV...
We don't have to, Ford has a TSB to address that issue.
Perhaps you could provide baggs with the name of the newspaper and the page number to convince him.
tidester
SUVs; Aftermarket & Accessories
Odie
Are they still putting roof racks on backwards at dealerships??? Mine was on backwards also and made a terrible howling noise when I reached about 50MPH. turned them around and walla! noise gone.... This is an old problem from when the Escape was first released in 01....
mechanical problems. I also have leather interior, sunroof and MACH-6 and
frankly enjoy the extra cost items immensely.
Roughly 65% urban and 35% rural miles, tough Texas summers,
and the like. I must admit that the Escape for me has been just a solid though not as
well put together as some foreign makes I've owned.
I'm going to get the 30K service done at about 25K. I will probably foot the extra cost
and have a complete transmission flush, complete coolant flush, fuel induction service,
and brake fluid flush. The 30K total services including the extra stuff is going to run about
$400.00. Most all of the good private mechanics are recommending these services
anyway, at least in this region of the country. The brakes are wearing o.k. so far, but I
do anticipate a complete brake job at 30K or so. The ContiTrac SUV tires have a rough
ride, but seem to wear well, though I expect to have them changed out in about another
10K miles.
I would rate the Escape at least an 8.0/10 in most vehicular categories. It's been that good.
I had a Ford Escort that I kept for 95K miles with little to no trouble. With maintenance
and some TLC I expect the Escape to go longer and farther, particularly with the V-6.
General driving:
The Escape wins hands down. Its quicker, more maneuverable, more fun to drive, easier to drive, and gets better MPGs then the Windstar.
Safety: The Escape has all 5 or 4star ratings. No problem with safety there.
Roominess: With the Windstars we never had to use the roof rack. With the Escape when our family of 4 goes on the long vacations we sometimes have to use the roof rack for just 2 or 3 small suitcases at most. (have a roof bag). The main occasions we use the roof rack was over the x-mas holidays where alot of room was taken up with packages for all the in-laws and out-laws.
Winter Driving: The 4x2 Escape does even better than the Windstar. The slighly higher ground clearance and more aggressive tires help here. So you probably don't even need the 4x4 Escape unless thats what you really want. Remember the Escape 4x2 is front wheel drive, compared to the rear wheel drive 4x2 Explorer.
The kids (ages 3 and 6) have no problem with the Escape, and things are even better because I installed a drop-down LCD and wireless headphones entertainment system for videos (and soon dvd's).
As far as safety.. the Escape gets 5 stars in all categories but 1... Some crash test sites rate it worse however, some better.... who do you believe??
Our Escape stalled once, we took it in and they did the TSB. So I don't think the stalling should be a concern.
Driving wise, I very much prefer the handling of the Escape vs its larger SUV brothers. Much tighter and precise. After 60k miles, I would bet the Escape is still better, unless the shocks/struts are starting to wear a bit.. (Which may be what your feeling on the Explorer/Expy).
I've noticed that the larger vehicles seem to be more sensitive to shocks wearing that smaller ones. (Either more sensitive, or just wear them out faster).
This stalling thing has gotten blown way out of proportion. Get out on the net visit other chat rooms/groups and you will see there are many more satisfied Escape/Tribute owners out here than unsatisfied.
As you said the CRV has its strong points as does the Escape. The V6 is wonderful, powerful, and pulls the vehicle/passengers/gear around with confidence.. Good luck..
Have you looked at the Tribute too?
I actually found the Tribute's suspension to be a little too tight if that means anything to you.
Ford 3yr/36K
mazda 4yr/50K
Rich
Mazda's options come in packages. Something like, if you want the moon roof, you have to get the tow package...
Fewer dealers around (and I live in a large metro area). If you have a bad service experience, you may have to travel afar to find a good one. With Ford, you'll probably only have to go an extra couple of miles to the next service depot..
The Mazda does have it's benefits too, but they weren't enough to sway us. Appearance and material quality, to name a couple.
Odie
For the Escape XLT--all cars to be produced starting early next month--it means:
* raised white letter tires are no available even as an option
* the rear security/privacy shade will no longer be available
* the overhead console is being removed as standard equipment and not available as an option
* lumbar support on the driver's seat being eliminated
* even the cheap, plastic coathooks where you hang your jacket in the rear seat area are being removed
There may be other deletions...I have not received a complete list and would appreciate a more-detailed post on "Job 2" from any insider who knows.
Bottom line: if you're thinking about an Escape XLT, find what you want on a lot near you NOW...the ones that are coming are going to be much, much "cheaper"...cheaper MADE, not cheaper priced!
Turned just over 17,000 miles on the Escape. First snow fall! yah hoo! Skiing here I come!...
Odie
When the car sits outside at work all day, or in the garage all night, and I start it up, I notice that the battery light goes on for about the first 3-5 minutes. It always goes off after 3-5 minutes or the first 2-3 blocks of driving. The vehicle starts right up; no problem there. Why does the light go on, and what does it mean?
Love.. get it in to the shop and have it checked out before your warranty expires....
Odie
Http://www.autoanything.com/images/waag_pg/enlarged/Mazda_Tribute-Front01_enlarged.jpg
Http://www.autoanything.com/images/waag_pg/enlarged/Mazda_Tribute-Rear01_enlarged.jpg
Odie
Odie, this looks a little like a deer guard, except it doesn't go all the way across. Sharp looking.
I am also considering a CRV EX AWD. A similarly equiped Escape would have to be significantly cheaper given lower residuals/resale. Thanks!
We bought ours with the X-Plan too. I believe the deal is actually 3% above dealer invoice. The A-Plan, for the actual Ford employees, is something like 1% below dealer invoice.
Deals on SUV's in this region are going to be few and far between for the next month or two. We're just entering the big SUV selling season.
Also, one of my speakers was fading in and out and they replaced that too. Had one in stock and they seemed surprised that they did.
Odie
