Maintenance Required Soon - 2014 Toyota Highlander Limited Long-Term Road Test
Edmunds.com
With nearly 10,000 miles on the odometer, it's almost time for our 2014 Toyota Highlander to receive its second regular service.
Has Toyota moved to a oil life monitoring system yet? Or is it still simply a timer based on the odometer?
Do oil life monitoring system measure the chemical composition of the used oil or is it just someone's algorithm?
The latter
