Subaru Outback strong gas smell--can mice be the culprit?
My 2012 Subaru Outback started having a very strong gas odor inside the car and in the closed garage after I filled the tank and left it in my closed garage overnight. There were about 35k miles on the car when this started happening. It was June and not cold. It is now Sept. and I finally took it to my dealer. I had found that if I only filled the tank 3/4 I did not get the odor. When I filled it all the way, the odor came back. The dealer says it looks like mice have chewed on the fuel line(s). He said I can drive it with no worries because it is only "seeping". He has ordered the fuel lines. He says the repair will be minimum of $500, or worst case it could be thousands if they have to remove my fuel tank!
So my question is does this "mice chewing on the line" sound for real? And why do I only smell the odor when the tank is full? Since this is a newer OB and not a cold weather problem I have to post my question!
BTW, I went to the dealer hoping the issue would be covered under warranty -- they said no, it is not. I normally get all of my service and repair work done by my local, trusted mechanic.
Advice, please?
Advice, please?
Best Answer
dcm61
Member Posts: 1,567
Subaru tanks are saddle tanks and have a transfer pump between the two "halves".Mr_Shiftright said:Well that explanation is confusing but happy to hear that whatever it was got fixed (gas tank doesn't have two halves).
5
Answers
She contacted her insurance company and made a claim, and they paid to fix it. Worth a shot in your case too.
One wonders....if they can see where the mice chewed, what's the big deal here?
They quoted $500 for 2 hours labor and the parts for the chewed area. They said could be 10 hours labor if the tank needs to be removed. Based on your response, that is an overpriced quote for the time to remove and replace the tank.
I wonder also if they've tested the EVAP system for leaks? Your analysis about how this odor behaves suggests to me that you are more right than the dealer is. It sounds more like a leak in the venting system, not the fuel delivery system. Perhaps that's what they meant and you heard wrong....
If you are perchance in the San Francisco area, I can hook you up with a good Subaru repair shop.
I did not hear the dealer wrong -- he said he was ordering replacement fuel lines.
My next step is to put out several mousetraps in my garage!
In any event, you evidently have some kind of rodent problem, so maybe some traps are in order to prevent a re-ocurrence.
