Hidden Vents - 2015 Jaguar F-Type R Coupe Long-Term Road Test
edited September 2014 in Jaguar
imageHidden Vents - 2015 Jaguar F-Type R Coupe Long-Term Road Test
Our long-term 2015 Jaguar F-Type R Coupe has some pretty cool party tricks, including the dashboard vents.
  • jeepsrtjeepsrt Member Posts: 88
    So when no one is in the car it has a clean sleek look, then when you start it a needlessly complicated vent rises from the dash.
  • nagantnagant Member Posts: 176
    And it does not fit that well when down.
  • schen72schen72 Member Posts: 433
    How much will that cost to fix once it breaks after 5 years of ownership? Maybe for the typical Jag customer this doesn't matter, as they get new cars before the warranty runs out. But for people like me who want/need cars to last 10-15 years, useless gimmickry like this probably doesn't help reliability.
  • legacygtlegacygt Member Posts: 599
    Not only silly but the only purpose is to make the car's interior look better when you're not in it than when you are. Actually, that's not true. The purpose is to give the salesman something to show you when sitting in the car on the showroom floor. You are amazed by trick, buy the car and from then on, these overcomplicated vents are your problem.
  • laurasdadalaurasdada Member Posts: 5,285
    If it's like my XF, you can program the vents to remain open. Which I will do when I'm out of warranty!
