Visitor Agreement.
For conicity, which is the most repeatable of the forces to measure.
The studies I have seen show a disturbing tendency for the Hunter machines to show some tires with high radial forces (and some with low forces), that regular uniformity machines show the opposite. These outliers throw the correlation all out of wack.
I agree the Hunter machines are marvels of modern affordable technology (If you can call $10,000 affordable, which it is compared to $600,000 which is the last figure I heard for a new Akron Standard machine). My only purpose in pointing out its flaws is to ask its users to exercise caution when drawing conclusions.
But, let's not lose sight of the fact that one needs such sophistication in a balancer only when the tire is a POS (maybe over stated). Then the balancer can do only so much to compensate.
What do your experiences say about the tires that need the GPS9700? (i.e. brands, sizes, cheap tires, etc.)
Joes230 mentioned low profile, hi-performance tires as more prone to have balancing problems. Can a correlation to rim size be made? I remember when 13" radial tires became common and they were awful for roundness. 14" were better as a population but 15" were the best. No 16" back then. Now 16" tires seem the most common with 18" at the population edge.
I'm just trying to feel out what kind of tires display the problems that need a GPS9700 and to stay away from them.
Although Michelins (for example) are very good, even the best tires sometimes have anomalies. Not sure a list of good/bad tire brands/sizes is possible.
Also a wheel problem can cause vibrations, even if the tire is perfect. The Hunter machine can pinpoint whether the problem is wheel or tire.
If you don't have vibration problems and are satisfied with your ride, then regular spin balancing is probably OK. Trucks are usually less sensitive to balance problems than cars, so if you have a truck, maybe less need for this machine.
If you have a vibration problem your shop can't fix, then go to a shop with this machine.
Alternatively if you're buying new tires and if you have a high-perf car (stiff suspension, low-profile tires), and/or have previously had vibration problems on that car, consider buying at a shop with this machine. Ask them for a price break on match-mounting your new tires with this machine; often they'll give you one.
Just last week I had a vibration problem on my BMW 330i, yet a spin balancer showed all tires *perfectly* balanced. The GSP9700 showed the right front had 29 lbs radial force variation and couldn't be compensated since the wheel was perfectly round. I had the full-size spare put on there, which only had 5 lbs RFV. The ride was then glassy smooth.
capriracer, thanks again for the feedback and insight.
-- Joe
Being a little disturbed, I wondered at that result as I still had the vibration. Mind you the person who performed the balance appeared to be around 18 years old. What would you think?
Since the shop didn't charge me, I called around and found another who came up with the same result. Not satisfied with the results of the balancing done by both shops. I negotiated a set of Michelins by agreeing to pay $25 each tire. Tires were balanced on a Snap On spin balancer and surprisingly, no vibrations.
Regarding tire types, etc, that have vibration problems. From a manufacturer's point of view it's the overall diameter that seems to have the most effect. SUV's, being trucks that are gussied up and expected to ride and handle like cars, are especially difficult to deal with because of this.
Hope this helps.
First, a 30 mph vibration is probably not a tire speed rotating component - tires, wheels, hubs, brake rotors - which generally come in at 50 to 70 mph.
Second, the Hunter machine, while not infallable, seems to confirm that the tire/ wheel is not the source.
It helps when trying to deal with vibrations to be able to tell when it occurrs and when it doesn't. Example: If you get this when you press on the accelerator and not when you are coasting, I'd look at the pinion angle. If you get this only on braking - warped rotors.
It would also be helpful to make sure your air pressures are correct. Look for the placard on your vehicle. The placard, among many things, tells the original tire size, the original wheel size, and the proper inflation pressure for that tire size. The placard is usually located on a doorpost or in the glove box.
Also make sure there isn't any irregular wear by rubbing your hand over the tread face, especially the front tires. A little edge to the tread elements is OK, but an overall roughness, like hills and valleys, can cause vibrations. BTW, you did rotate your tires every 6,000 to 8,000 miles like you are supposed to? This helps minimize position specific wear patterns and on RWD vehicles, its the front tires that are prone to irregular wear.
Hope this helps.
Also the GSP9700 is itself a regular balancing machine, albeit with road force capability. Once I requested to have my tires balanced on a GSP9700, and they said "sure". I started to turn away, but then asked does that include road force balancing? They said "no, you have to specifically request that for an extra charge".
So maybe it's possible your tires weren't road force balanced, despite a Hunter machine being employed. Just a thought.
joes230
It was the GSP9700. I had used the Hunter site to find a tire dealer that had that specific balancer. As far as the qualifications of that young man who said everything checked out ok, well that's another story. The tech did note that it was a brand new vehicle.
Did you know that Hunter also makes excellent alignment equipment? Perhaps when having the vehicle aligned you'd want to keep that in consideration.
This sounds like 2 tires which are going in and out of phase due to slight differences in diameter. Since there are a lot of rotating components in a vehicle there is a lot of vibration and the old tires pushed the vehicle's resonance past the threshold of preception. I have encountered this phenomenon only a few times and I can understand why a regular shop foreman would be willing to dismiss this as a "characteristic" so he doesn't have to deal with it.
Where's Bretfraz these days anyway? I thought I read somewhere that the shelf life of tires was around 7 years, whether on the car or in the warehouse.
Hmmmm... I didn't know that 700 miles on a tire would make it old.
This is the second time I have encountered the word " Tramlining". This time I think I understand its meaning - following the grooves in the road like a tram (train) follows the tracks. (If I have the meaning wrong, let me know).
The technical term is "Groove Wander". It is caused by the circumferential grooves in the tire lining up with the grooves cut in the road bed and causing the tire to "follow" the grooves in the road. To prevent this, the tire mold must be designed so that the tire grooves are spaced differently than the road grooves. Unfortunately, there is no standardization of road grooving and the spacing has quite a few common widths.
Ordinarily, a given tread design can be magnified up or down to fit the particular size it is going on. But if it lines up with one of the known road groove patterns, then it has to be adjusted. A new tire design with 30 different sizes requires each one to be examined, quite a task!
"... including the tendency to pull L and R on crowned roads?"
I may have the meaning of tramlining wrong, but I think the "pull on crowned roads" is a different phenomenon, more related to conicity.
Background on conicity - From the word "Cone", it is a tire property that causes a sideways (lateral) force in the tire. It derives its name because a cone rolled on a flat surface will not roll straight ahead. The dimension is a force dimension (Pounds or Newtons) and it has direction (left or right, but this is called positive or negative).
If a pair of tires on an axle has a large enough difference, it will cause the vehicle to "drift" or "pull" to the side with the higher force. This means that it isn't one tire that is "bad", it's the combination and changing one tire of the combination will change the value of the pair.
Each vehicle has a different threshold where the sum of the conicity values will cause a "drift" or a "pull". Part of this threshold is the amount of "slop" in the steering system, and some is due to the amount of camber.
So when you have a vehicle that seems OK on flat roads, but "pulls" on crowned roads, what is happening is the sum of the conicity values has exceeded the threshold.
If I remember correctly, conicity values change with deflection (which is either load or inflation). A highly crowned road will cause one tire to unload and the other to be more loaded, causing the pair of tires to change in conicity value. And a large amount of camber would aggravate this situation. I should mention at this point that too much toe in will also cause this, particularly on vehicles with "bump steer".
A simple fix would be to change the inflation pressure, but you run the risk of exceeding the threshold on flat surfaces - fixing one problem and creating another.
There are a couple of other causes for this pull on crowned roads: If a tire is mounted on a rim that is too narrow, this will cause the tread to "arch" and be more sensitive to changes in camber, which is what a highly crowned road is. A similar thing can happen with too wide a rim.
And there are vehicles that are extremely sensitive. I had a Mustang that would follow the ruts made by trucks in the blacktop - very disturbing. I fixed by taking off the "Too wide" tires and putting the proper size back on. I also fixed the alignment.
Hope this helps.
This is waaaay too technical stuff for moi.
Holy Moly! (I guess it is fun, if that's what you're into...)
I was just looking into this from a consumer point of view.
There have been several Subaru owners who've posted their new tire choices so you may want to look at those as well. The Wilderness is a light truck tire that Subaru uses mostly for that SUV look on the Outback. Personally, I kinda like the look. You can put another LT tire on it to maintain the image or go with your typical all-season radial if you don't.
The sky is the limit in 225/60-16 so if you tell us what you want/need in a tire (prioritise them for us) we can make some specific suggestions.
One question - Do you have Sams Club or Costco near by? That will expand your choices.
Check out: http://www.tirerack.com/tires/surveyresults/index.jsp for a good overview of tires. And check out the reviews other people have written on specific tires you might be interested in, photos of the various tires, etc.
The Toyo's will look like a normal all-season radial you will find on small cars like Civics, Corollas, Jettas, etc. Nothing special in their appearance.
That Michelin Select LT is a good choice. It's basically the same tire as the LTX M/S which is very popular. And you can get servicing at any WalMart that sells tires. A friend bought some for an older Suburban and he's very happy.
Not too many tires are gonna offer a quiet ride, good wet handling, and long tread life. These are mutually exclusive. About the only LT tire I can think of that can do most of this is the Michelin Cross Terrain, which might be the ideal tire for you. Locate a local Michelin dealer and price them. Also check out Tire Rack and 1010 Tires.com.
Best of luck.
I agree, finding a long wearing, quiet, nice riding tire that also provides some level of cornering and wet and dry traction seems like an impossible task. Yet these Bridgestones are getting high marks in these catagories. I'm about 3,000 miles away from giving them a spin.
I've been looking at them closely as I too need new tires and the Turanza LS would be a great OE replacement tire for me. I only wish they would offer them in a greater range of sizes; both the V and Z rated models are very limited on choice.
One clear positive note is that they seem to be priced right. I was quoted $99.99/tire in my size at my local Firestone dealer. Much cheaper than the Michelin Energy MXV4 Plus which they compete with.
Anyone looking for a grand touring tire should have the Turanza LS series on their short list.
Check the Turanza prices on tirerack.com Mounting only cost $12/tire and the shipping is less than taxes. My savings will be $100.
Have 74K on my X-One's now and they are still in almost perfect balance-hope the BStone Turanza's do as well. They supposedly are much better in rain and quieter than X-One's-they are certainally cheaper.
I currently have two sets of Dunlop SP 5000's. (The third set sold a few weeks ago on a spare set of wheels for my SVT Contour) and the set on my Buick are at about 2.0002/32nds tread. I've tried to sell the Caddy Deville wheels on E-Bay, but didn't get enough to make the sale worth my effort so, here is what I was thinking.
Putting my Michelins back on for the winter in the 205/75-14 flavor, getting my wife the Goodyear Regatta2's in the 215/60-16 flavor for her MPV and taking the 225/55-16's currently on there and putting them on the Caddy wheels for next spring.
I feel the Dunlops are probably overkill for the MPV and the way my DW drives. However, they do a fine job at enabling the Buick to take most exit ramps at twice the recommended speed.
So what experiences do the participants here have with the Regatta 2. The reviews on the Tire Rack as well as the UTQG info look very promising.
BTW, the van's original size is the 215/60-16, so I'm considering moving out of the +0 it currently has.
TB
Good luck on the Caddy wheels; kind of a narrow niche for them so I hope you find a buyer. Best to offer either brand new tires or completely worn out ones on the wheels.
One thought on MPV tires: Most all minivans are terribly under-tired and can really use a good quality performance tire to improve all aspects of driveability. Yeah, they eat tires like candy but minivan's really seem to respond to tire upgrades. Something to consider before stepping down to the Regatta2's.
Hope this helps. Let us know what you decide.
The firehawk line of tires weren't that impressive back then (owned a set of the FTXs) and certainly don't compare to newer premium tires today (my opinion).
about tireguy - last I heard he was busy in a new career
I've seen the Spectra floor stacked at one local Sams selling for $35 each for various sizes. I checked their DOT codes and found they were made at Goodyear plants. That's all I know about them. They seem like cheapo models.
I've never seen or heard of a Concorde. They're not on Sams website as in-stock or special order tires. Sams does offer the Conquest as a special order item; you can read about that tire at Goodyear.com.
The only car tires I see Sams stock is the Allegra and the Eagle GPH. But you can order almost any Goodyear tire from them.
Grand High Poobah
The Fraternal Order of Procrastinators
I would never have thought that there would be a treadwear difference within the same tire line with different speed ratings. Always thought that was just a measure of sidewall rigidity and strength. Makes you wonder why a lower rated tire would have a longer projected tread life though. .... Maybe they are just counting on the more agressive drivers going for the Vs and Zs?
I think the choice between H, V and Z is my last decision on these tires. I like the H-rated price. That's for sure. Using Tire Rack as a comparision, my 225/55-16s are about $100 in the H-rated and about $150-160 in the V and Z rated. That is a big difference.
It was interesting to me to note that their survey results rated the Z-rated tire better all around in performance, comfort and quietness. I just don't really have a handle on whether I would notice the difference.
"...warranty them for two years and 24,000 miles..."
