It comes down to uneven wear of the tread surface.
Any opinions? I'll probably ask the dealer for its opinion on my next visit.
I don't know of anyone who has proven these marks cause a problem, but it is so very difficult to get good, reliable data on the subject. Tires have been tested with these marks and the results have been satisfactory. But these are lab tests and the real world might not be the same.
Hope this helps.
It's a convenience feature, I believe, since I've dropped the spare tires with just the little stopper and cable - a cage would make it easier to control.
With the Sedona, though, blue, you've got roadside assistance - it isn't like you'll have to touch it or use the spare for very long....
What is contributing to the harsh ride is 1) High speed rated tires, 2) Cold weather, and 3) low aspect ratio.
Here what will generally help improve ride - the opposite of the 3 above, AND a larger tire, larger meaning more load carrying capacity so the inflation pressure can be reduced.
The problem is the amount of room in the fender well. Unfortunately, I do not know of a chart or book that lists what the limitations are for every vehicle. You will probably have to do the research yourself. Remember - the worst condition is fully turned, fully compressed.
However, generally you can go one "size" up without problems. That means out in width by 10 (the first number in the size), P225/55R17, or up in aspect ratio 5 (the second number), P215/60R17. Either of these is going to have speedometer error of about 1 1/2%, which is OK so long as you are aware you are going faster than indicated. But be sure to check the clearances.
One additional thought: The Altima also comes with 16" tires, which opens more options.
Hope this helps.
Anyway, the Regatta should do pretty well. Also consider Cooper Lifeliner Touring SLE which has received some good reviews for snow traction. Or you could go with a "4 season specialty" (my terminology) tire from Nokian. The Nokian NRT2 comes in 205/70-15 which I think is your size.
"Ya get caught in a blizzard and your tires are bald - UFF DA"
Thank you guys ... Norbert
If you lose the "key" you're in trouble - no two ways around that. Don't lose they key.
I've never seen any balance problems because the locking lug nuts don't weigh much different than regular lug nuts. Since the lug nuts are so close to the center of the wheels, it won't make much difference, anyway.
A neat way to go is the new "all lock" lug nut systems that use slim nuts with matching patterns inside - all the lugs are locks.
I must say after 5K miles I love these Dunlop Sports - especially in wet weather. They are also quieter in all conditions. I am sure I will not get as many miles with them but only time will tell.
Maybe someone else will comment on these tires in regard to the frozen stuff.
mike1qaz
Mike, I used to live in New Orleans and loved Mardi Gras, great party!
The Sandman :-)
Dry handling is the same, wet traction is better (could just be that they are new), road noise and ride comfort are noticeably better.
They are too new to get any idea of tire wear, but the treadwear rating was a bit higher than the Pilots. In my application, I could get them installed for ~$90 each, compared to ~$190 apiece for the Michelins. I have been very pleased thus far.
But I dunno for sure. Let's see what experts have to say.
And 40K out of a high rolling resistance AT tire? Don't think so. Maybe the new Bridgestone Dueler A/T Revo can get you close. UTQG = 500 on that tire. But most AT tires aren't gonna do 40K. Shop carefully.
How about some details?
Tire size
Placard inflation pressure
Current inflation pressure
How much work are you willing to expend to save the cost of new tires?
How many miles are you going to put on the vehicle this year?
My recommendations for preventing flat spots: (Please see notes at the end!)
A vehicle that is going to sit idle for a month or 2 - just make sure the inflation pressure is set to the placard inflation, before you park it.
A vehicle that is going to sit idle for 3 to 4 months - inflate tires to max inflation on sidewall OR 5 psi above the placard, WHICHEVER IS GREATER. Don't drive on this except the one trip to where it is to be parked.
A vehicle that is going to sit idle for 4 to 6 months - inflate to 15 psi above max inflation on sidewall. Do this in place if at all possible, otherwise just the one SHORT trip!
A vehicle that is going to sit idle for more than 6 months - Remove tires from vehicle and store in a plastic bag filled with nitrogen in a cool, dark place with the tire completely deflated and stacked sidewall to sidewall, and if possible, with spacers between the wheels, so the tires are not in contact with anything except the bag they are in and the wheel they are mounted on. This last recommendation is a bit involved, but the more you can do on the list, the better!
A vehicle that is going to sit for more than 6 years - Don't bother with the tires. Mount new ones before you start it up and throw the old ones away.
If you have any 2 of the following conditions, use the recommendation for the next longer time frame.
Temperatures over 90F
Parking on blacktop or other dark surface
Parking area cooled to more than 20F below outside temperature (like an air conditioned garage)
Vehicle driven more than 30 miles before parking
Vehicle driven faster than 70 mph before parking
Vehicles that are not empty when parked
Hope this helps.
Where is the problem?
1) I hate to quibble, but it takes a few thousand miles for tire wear to manifest itself, unless the alignment is WAY off. Perhaps a better explanation of what was noticed in the early stages would help in the diagnosis.
2) IMHO, vehicle manufacturer's specs for alignment are too wide by a factor of 2. I know this to be true for toe, but it is hard for me to get reliable data for camber and caster. Modern radial tires need to be aligned for toe within 1/32 of an inch of the nominal PER SIDE (that's about 0.15 degrees.) This is the tolerance, not the target value.
3) Once a wear pattern is developed on a tire, it can sometimes take quite a bit of time for the "old" wear pattern to wear away. Sometimes you will never get rid of it.
Since you are apparently still on the original tires, I wonder...
a) Is it a vibration that is leading you to believe that tire wear is the issue?
b) Perhaps a new set of tires will "fix" the problem.
c) What is different between your '92 Sub and your '02? Driver? Load capacity? - these things came with quite a wide variety of tire sizes depending on the GVW of the vehicle. How about the basic usage for each one - grocery getter vs work truck - that kind of thing?
Hope this helps.
The article seems to imply that performance all seasons are good on snow. I find that to be a bit of a joke that most owners of performance 'all seasons' will also find funny. See how far you get on 250mm wide perf [non-permissible content removed] tires with 4" of snow and ice on the road!
Bret, if you're out there, some feedback please!
The Sandman :-)
http://www.bridgestone-firestone.com/news/consumer/news/2002/0211- 11a.html
http://www.bridgestone-firestone.com/news/consumer/news/010207a.h- tml
Seems like a Bridgestone version to your Continentals. Sounds a like good choice for the Corolla.
I guess now that's 2 dinners I owe you when you get down to South Florida, u da man!
Thanks again bud.
The Sandman :-)
Just returned from a trip to New Orleans and Florida and spent more than 1000 miles at speed in rain and then 100 miles in yesterday's snow storm in NJ, NY, and Conn. On Yokohama's Avid V4 tires with approx. 12,000 miles of wear. Awesome in the rain and usable in the snow. I was passing many 4-wheel drive SUV's @ 40 MPH in snow on the insterstates with a rear wheel drive car. Excellent tires..
Bret, you live in Florida? I was in Ft. Myers and Cocoa Beach; was I close?
So who's the pro, Bret or Capriracer? What's your opinion on Sumitomo HTR+ tires?
I think the HTR+ is a fine tire for the price. Strong rumor has it that its casing is the same as the Dunlop SP5000. So it has the foundation of a very good tire.
Not only do I love the Mini's in the Italian Job but I loved that bus transporter they had. Great car flick!!
The Tire Rack has the Dunlop SP40 A/S, Yokohama Avid T4 and Avid Touring, all great tires for under $40 each (in 185/70-13), just for info. I'm a Sam's Club and Costco member, too, but I've yet to beat the Tire Rack on prices.
