i'm lookin' for tires (go fig....:)
i am looking for some good all seasons
and i am considering the following:
yokohama AVID T4/H4
pirelli p3000
toyo 800ultra
bridgestone turanza LSH/T
michelin harmony
anyone know anything about these?
help=appreciated
Recommended pressure is 30 psi. Max for the tire is 51. I've been running 30 or 32 since day 1 and front/rear have always been identical. I have a digital gauge and my own compressor and I check pressure every month or two, so I know they weren't overinflated. And if they were, the fronts should have shown the same wear pattern.
I'm planning to take it back to the dealer to have it checked but I'm sure they'll say it's a problem with overinflation or alignment/suspension. I heard that RWD performance cars sometimes exhibit this kind of wear. Could this possibly be normal? Could it be a defect in the tire? Could more frequent rotation have prevented it (first rotation was at 13K)? I'm more worried about how to prevent it in the future.
Also, make sure you're checking your tires cold or know how to figure the hot pressure readings.
FWD cars wear the front tires much more rapidly than the rears, where a RWD, the wear rate is about the same.
But I think a few extra facts would help clarify the situation. Since you have a compressor and a digital pressure gauge, and seem to know how to use them, it is not too much to ask for tread depth readings across the face of the tread. I call this a profile. I use a digital tread depth gauge from Mitutoyo. It's a bit pricy ($50), but is really accurate. It also has the downside that the measurements are in mm OR thousandths of an inch, not the usual 32nds. You don't need to be that fancy, a simple $5 tread depth measuring to the nearest 32nd or mm will be fine.
In any event, the fact that the rear tires are wearing faster in the center should not be a surprise. While 13K is a bit long between rotations, it is at least a contributing factor to the noise. I think your next step ought to be to do a rotation and see if the wear doesn't even itself out.
If I were the tire dealer, that's what I would tell you to do. I might talk about regular rotations, alignment, etc., but in all honesty, this is just a way to try to get out of the situation, hoping that the situation will correct itself.
However, I don't think you ought to complain about this until you've at least done the right thing by the tires.
But before we get too far down this road, let's see how bad the profile looks. BTW, be sure to avoid the tread wear indicators when you measure the profiles.
Hope this helps.
Never saw this type of wear on my RWD trucks/SUVs. This is my first RWD performance car. If more frequent rotations solves the problem then that's great.
I'm referring especially to toe settings - if there's a .2-.4 range in specs, you can be sure that a 10" wide, 31" tall tire will make the rig wander if it's just "in the range".
Explain to the shop that's doing the alignment that you don't want it just "in specs" - you want it right and they should adjust and drive it until it's closer.
But what is it that makes you think the alignment isn't right? Does the vehicle wander? Does it pull or drift? Vibration?
A little more info will help get you a better answer.
You've replaced tires and had 2 alignments done and you still have a pull?
Just to be sure it isn't tires, swap the 2 front tires - left to right.
If the pull changes direction, then it is tires, if not, try the rears (although I don't ever remember this working). If no change, then it's alignment.
EXCEPT
You might have a brake dragging. After driving for a while, put your hand on the driver's side whell, near the hub. Then try the passenger's side. Be careful, the passenger's side may be quite hot. (the driver's side, too!) Any difference in temperature means a brake is not releasing properly.
Also, if the pull only occurrs when braking, it is definitely the brakes.
Hope this helps.
My suggestion would be to go to the junkyard....er.... auto recycling center.... and buy a set of 6" or even 7" wheels. There have got to be a billion of them by now so they are going to be nice and cheap. Might even be able to get a set of aluminum wheels for a good price.
And don't forget that going to a larger diameter wheel is going to throw the speedometer and odometer off, in this case by 9% meaning your speedometer will say 60 mph but you are really going 65.
Hope this helps.
Personally, I think the SMALLEST tire that ought to be on a standard size pickup is a P235 XL - mostly because of the load carrying capacity. But only you can answer the question of whether it is worth the extra work to get there.
The practice of keeping the tires on the same side during a rotation was a product of the early days of radial tires. These tires had some real problems with belt to belt separations and it was thought that changing the direction of rotation was aggravating the situation - hence the recommendation.
It was learned later what the true problem was, but the recommendation was continued just to be on the safe side.
Today, however, vehicles have become much stiffer and much better put together, but they are also more sensitive to wheel end vibration. The best way to prevent the formation of irregular wear, which will lead to a vibration, is to rotate regularly using a Modified X pattern.
It has been recommended, more than once, that vehicle manufacturers eliminate the front to rear type of rotation pattern from the owners manual. However, the issue of DIRECTIONAL tires is always brought up and, given our litigious society, always prevails.
I was not aware of the article you mentioned, but I will talk with the operators of this web site and see what I can do to get it corrected.
Hope this helps.
My 85 Ford F150 reg cab longbed left the factory with 195-75r15 tires which looked RIDICULOUSLY small so I went to 215-75R15...
The web reveals all... There are a number of web sites with tire diameter calculators. You plug in the numbers and out pops tire diameter.
A quick Google search finds:
http://www.rx7turboturbo.com/robrobinette/tire_diameter.htm
195/75R15 = 26.5" diameter
215/75R15 = 27.7" diameter
Your speedo is already off by more than 5%.
I agree with the suggestion of finding inexpensive used 15"x7" or 16"x7" rims for wider tires. You can always get your speedometer recalibrated.
Good luck with that when you're trying to sell the car!
I don't recommend this unless you plan to run the vehicle down into the ground.
They were showing some cracking on sidewalls, my guess is from low pressure, but good tread. Now with 43K I am replacing them with same tires - not because of treadwear, which still has 20K left, but because of minor sidewall cracking that my state safety inspector will not accept.
I plan to buy an extra set of steel wheels and run the old tires again next winter. New wheels run about $60 each so I'm hoping I can pick up some used ones at local junkyard.
I read mixed reviews on the Mich. Symmetry tires on Tireracks and my tire retailer says, "we don't push these tires". From what I can tell they are decent tires, some buyers may not use them right and, of course, the retailers don't want to sell tires that are going to last you too long;-)
BTW this car gets phenomenal milage with these tires inflated at Max. Recommended pressure: 22mpg day-to-day local driving and consistently over 26mpg on trips - God Bless Electronic Fuel Injection in these days of $1.75/gal gas!
Have a look on e-Bay for used wheels off a GM or Crown Vic. You might score a deal on a nice set of alloys and you won't get dirty in the process.
Any ideas would be appreciated.
In 11/01 Consumer Reports tested LT tires. Ratings were:
#1 - Dayton Timberline AT
#2 - Bridgestone Dueler AT (the one I suggested is a newer version)
#3 - Michelin XCX/APT (Sears only)
#4 - Dunlop Rover AT
#5 - Pirelli Scorpion AT
#6 - The Cooper you mentioned
#7 - Firestone Wilderness ATII
#8 - Goodyear Wrangler ATS
I have my wheels and tires on ebay and I'm buying a new set - tuner wheels and Z-rated 45s.
There is actually a local distributor in St. Louis, FWIW. www.ztire.com
Hope it gets you pointed in the right direction.
TB
google is your friend
Are these the OE tires on the Pathy? If so they may be tires specially produced for Nissan and are not (yet) sold in the aftermarket.
Your supposition of them being all season tires is likely correct. But to get an idea of their winter performance you may get better info if you ask '03 Pathy owners directly. I think there is a Pathy thread in the SUV forum. Yahoo Clubs also has a Pathy club.
I'd be at least at 40psi. And I'd make sure I knew what the max load rating was for my tires and made sure I didn't exceed them. It'll say right on the sidewall or you can check on the tire mfr's website.
The OE wheel is 6.5" wide but I've read that you can go to 8", maybe more, on a Pilot or MDX. I believe the bolt pattern is 5 x 114.3mm (very common).
If you go to 17" tires you have to use 17" wheels; tire and wheel diameters must match.
I see no problems with tires contacting suspension parts so you won't need to lift the body or anything. Its a simple bolt on.
Bigger wheels and tires are primarily for looks. Wider tires can improve handling and steering response.
I think Tire Rack has the Pilot in their online guides so have a look there.
Now simple math
16 + 235 * 0.70 * 2 = 735.4 mm (total diameter of original tires in milimeters)
new tire/wheel
17 + 235 * 0.60 * 2 = 713.8 mm
Difference 3% should be acceptable.
Krzys
PS 1" = 25.4 mm
The 235/60/17 is 28.08 inches tall.
A full inch is NOT acceptable when factoring in things like how the speed sensor reports to the ECM (transmission shifting) and the ABS sensors to the EBCM.
Use a 255/60-17 on an 8" wheel and you're in business - within 2/10 of an inch. Also, the Tire Rack has them in a Pirelli Scorpion Zero (V-rated, cool tire) for $121 each.
http://www.miata.net/garage/tirecalc.html
the tire size recommended by zueslewis has virtually the same diameter. The calculator says that when your speedometer says 60, you will actually be traveling 60.2 mph.. Can't get much closer than that going to a larger rim..
And no, I wouldn't have recommended anything from Pep Boys.
camshaft - right up my alley - have you measured the max width and height (tire allowance) for each wheelwell? I've done literally hundreds of high performance tire and wheel fitments. That's the place to start, the figure out what fits best based on how much you've lowered the car, whether sway bars will interfere, especially in the front, etc.
Feel free to e-mail me - this gets a little more involved than we may want to post here.
