Auto Restoration for Beginners
Okay, hopefully we can have a good conversation
here about Auto Restoration from engines to bodies.
I'm hoping that this will put to pro's and
amateurs together for some honest and insightful
discussion.
discussion.
I recently dug it out of the garage under a tarp covered in dust and found it in excellent shape, no rust, no puddles from any fluid.
Now, I want to get this thing on the road again. The tires have to be replaced, I will replace all hoses, drain and replace all fluids, check all seals.
My question is this: What would you strongly suggest I do to ensure that the motor doesn't blow up when I try to start it? Should I take the whole thing apart? Should the gaskets be replaced?
Any insight would be greatly appreciated.
But if the engine isn't stuck when you try to wiggle it (DON'T DO IT YET!), you may come out okay.
Here's what I'd do....remove the spark plugs, squirt Marvel Mystery oil (about 2-3 tablespoons)into each cylinder, let it sit overnight. Next day, squirt some spray lube in each cylinder (NOT WD-40...WD is not a lubricant, oddly enough---go find the word lubricant on the can if you don't believe me!)...anything, chain lube, silicone lube, whatever...then try to turn the engine by hand...if that works, next step is to disconnect the ignition coil wire (on some cars with electronic ignition, it may be best to ground this wire before cranking) and then spin the engine on the starter for 10-15 second bursts. Assuming you've checked for a clean fuel supply already, you can then reconnect the ignition and give it a try. Once it starts, just let it idle until you have some oil pressure and it starts to warm up. Then rev it a little bit for 5-10 minutes altogether. Then shut it off and drain the oil and refill with clean oil and filter.
That should do it....oh, and while the engine is running, check for leaks....you can run without water for some time, but not without oil of course.
I've brought back many engines from the dead. Be optimistic. The only engines I had bad luck with were flat ones (like VW and Porsche)...they seem to suffer mightily from storage.
It sounds like the car wasn't jacked under that tarp so is there not a risk of suspension damage? I always thought thatif the vehicle wasn't moved for a prolonged period of time the weight of the vehicle would cause the car to 'settle' (for wont of a better term).
Remember the first rule of Auto resto though. "Don't force it...Use a bigger hammer.
Sometimes the suspension comes back to life with some driving around, sometimes not. Tires and brakes are usually shot, though.
The trucklet was fully serviced (I'm talking engine overhaul, body work and fresh paint) and then put to rest for some unknown reason, so who know's what it's like?
I've bought all the replacement hoses (downright cheap for this sucker). Drained the gas tank and replaced the fuel hose and filter and will probably change the oil and filter this weekend before I try to start the engine since I don't know what the oil is like after 13 years.
Rad's been flushed and pressure tested with no leaks.
Found an grease stain on the right rear axle so I'll assume I have a leaking axle seal which I'll get the dealer to fix.
Oh yeah, forgot, drained and replaced the oil in the differentials (front and rear) and the transfer case.
My goal is to get it running well enough that I can get it to the dealer for a full systems check on the brakes.
Hope I've done enough.
Oh, Marvel Mystery oil is just a light oil...you can use automatic transmission fluid, which is like a 10 weight very high detergent oil...any light oil will do.
Ls1v8 feeling mighty old right now. "What is Marvel Mystery Oil?" Heaven help us, and pass the STP, please.....
Look on the bright side, I'm jumping in with eyes wide open 8-)
By the way, the tire size on this thing is nothing I have ever seen before. Must be an old way of doing tire sizes. I'll post it later and maybe someone can help me convert it.
Hate to do this to you there buddy, but believe me, no intent to make you feel olf. The tire size believe it or not is FR78-15.
Can anybody tell me what size tire I should be looking for???
Suzuki LJ80 Update:
Suzuki Canada was kind enough to track down a service manual in Japan and get it to me, what a godsend!!!
Spent the weekend taking the engine apart and draining replacing all fluids. The oil filter was a bugger, ended up getting one from Canadian Tire after making the parts guy go through his tech library. Not the same, but it will due for now.
Replaced all of the rad hoses and pressure tested it, good to go.
Took the valve cover off and lubed the valves, lifters, camshaft, rocker shaft et al., new gasket, and closed her up.
Used an air hose to get oil in the cylinders and turned the crank a number of times to get it lubed and moving.
Wiring, distributor, rotor are in A1 shape. Replaced the plugs after
Got a new battery and will install it next weekend.
NOW A QUESTION:
Should I replace the timing belt since it hasn't moved in 13 years?
Now, next step is to clean and replace the airfilter (replaceable foam) get gas in it (I drained close to 3 gallons 13 year old gas), and fire it up.
My goal is to get the engine running, warm it up and check for leaks. If no leaks, get it towed to the dealer for brake work (I don't trust myself on the brakes) and check the axle seals and such.
Any thoughts from the folks with experience out there????
HELP !!!! :-)
I know of a couple of engine cleaning systems - Motorvac and another whose name escapes me from the North East, but does anyone know if they work.
What about some of the bottle systems, anyone know?
Anyway, I took apart the brakes and guess what I found? Rust, crud, leaking wheel cylinders and lot's of fluid. But the most exciting find was that the beast has drums on all wheels plus an "emergency" drum brake (now called a parking brake) on the driveshaft behind the transfer case.
The brakes are NOT self adjusting. You actually have to periodically go through a hole in the drum and spin the star wheel to adjust the shoe clearance.
Man, talk about freakin' STONE AGE !!!!
Could it be an alternator? Can an alternator go bad just sitting in a dry garage??? Could it be the relay? Could it be anything else?
Also, the roughness in the engine. Should I have taken the carb apart knowing that the gas in the fuel system before I drained it was old leaded gas, or could it just need a tuneup after 13 years in hibernation?
Thanks in advance.
How old is this battery...if more than 4 years old, throw it out and start with that.
Anyway, the battery is brand new. I'm going to take a voltmeter to the alternator tonite.
As for Italian tune-up's, a friend also suggested blowing the crap out of the cylinders by using measured amounts of distilled water and a hot high reving engine by putting the water in through the carb. Apparently the explosiveness of the steam as it hits the cylinder will blow the heck out of the crap in there like the carbon deposits and blow it out the exhaust. Just becareful not to use too much water at a time since you could blow the engine.
Thoughts?
You could also check for VACUUM LEAKS...this can be done (carefully) by spraying a small amount of carburator cleaner on any hose, clamp, connection, or at the base of the carburator (stay away from spark plug wires and distributor cap!!!)...if there's a vacuum leak, the engine will abruptly change idle speed as it sucks up the carb cleaner.
Wonder how many people have screwed their engines trying this?
rea98d,
You'd have to come all the way up to Canada to do that, and coming from Texas, you'd probably end up freezing your behind off in my garage, catch pneumonia, and end up in the hospital near death making me feel really guilty, so thanks anyway. :-)
2: I will replace the brake fluids and have to replace the wheel cylinders and pads since the sucker leaked, but what about the brake lines? Should they be replaced?
3: The body has VERY little rust except on the inside of the wheel wells. My intent is to bring the car in during the winter, jack it up, grind the rust spots downs to bare metal, prime, rust proof and paint it. Is their anything else I should do or look for to protect the body?
4: If the dealer can't get parts, where is the best place for me to start looking? I checked out UAP which is limited and left a message for Suzuki Canada. What about scrap yards or other sources for a '79 Suzuki LJ80??? What about the yellow pages? Where should I check? Canadian sources would be great, but other sources are also appreciated.
Finding parts is all about persistence. You can find just about any part for any car in the world if you are dogged enough. Salvage yards are great if they let you retrieve your own parts or if they are at least well organized. A lot of them are lazy or won't bother to fetch a small part for you.
After much problems with the electrical system, I went back to the basics, cleaned the battery connections/cables with a soda paste and sand paper, and low a behold, it works !!! Battery is charged and my voltage regulator isn't freaking out.
I got a can of carb cleaner and pretty much emptied it and she runs a lot smoother now.
Still no leaks, but I'm going to shampoo the engine (she's just caked in grime) to be sure.
One thing I would recommend to everyone is that if you take something apart, clean it. Inside and out, every nook and cranny.
The brakes are next and will be worked on this weekend.
Body Work:
Can anybody give me the name of a good book or video on bodywork? The body has no visible rust, but the inside wheel wells and underside are starting to show signs. No dents or dings, but I do want to be proactive on the rust. Since I have no roof, I'll probably store it in the garage over the winter and work on it then.
Roof:
Is there anyone in the Toronto Canada area who knows a place where I can get a soft top roof for this thing fixed??? All the plastic windows are toast and have to be replaced.
Leaded Fuel:
This is a leaded gas engine. Does using unleaded gas have any effect good or bad? Should I use a lead supplement???
Ta ta for now !!!!
Not sure what it would cost, but you would get a good job.
I didn't post this sooner because I was trying to find their website which I now have. It is:
http://www.guildautomotive.on.ca/
Others may want to check it out, they have some truly fantastic cars for sale - have a look at the sales page.
I just might take a day trip this weekend and go up there.
FYI, though very much a nostalgia thing for me, restoring the Suzuki is kind of like going to kindergarten. Hopefully, as I learn more, I can move up the ranks into real classics, and just bgetting to know things like this site and the Guild will all help out in the long run.
FYI, I'm in Mississauga, work downtown King and Bay.
Thanks a bunch.
Used to work at King & York - Exchange Tower - now out at the airport (off Matheson). Currently living in Stouffville, but probably headed north in the not too distant future - long drive, but worth it for the country.
As I am sure you know classics can be addictive (as well as hard work), but very rewarding.
Say hi to the Lister XJ-S if you go out there - I think it would look nice in my garage - I'd even let them have my current XJ-S in return.
More seriously, let me know what the set up is like - I am bound to need their services before too long.
Andy
We shut the motor down and noticed more smoke still coming out of the exhaust... burnt leaves.
Anyway, we ripped the exhaust off and checked inside. It was jammed up with a mouse nest and still smoldering... no more Mickey. :-(
Anyway, thing works fine now. Goes to show that you better check everything before you fire her up. We didn't. Could've been a lot worse.
Amazing what you can find...
Also, I had to rebuild the old wheel cylinders. Replacements are + or - $100 each and the car has 6 (2 for each front wheel and one in each of the back wheels). Has anybody ever converted a front drum system to a frontdisc? Just a thought.
Thanks !!!
Question: Should I get the underside oiled for the summer to prevent the rust from spreading?
Question 2: Should I consider just rust proofing it as is and forget about taking it apart this winter?
You can't really "stop" rust...it is relentless...either cut it out or let it go, would be my advice.
For the short term, you can use a rust neutralizer or neutralizer/primer, but don't expect miracles.
Point is taken. I think I'll leave it until the fall when I can store it in the garage and do some work on the underbody since they use salt during the winter here for the roads.
I also just wanted to say thanks for all the insite. This being the first car I've ever worked on, your insight and everyone elses has been greatly appreciated. Now maybe it's time for me to save up and get a "real" classic to work on.
BTW, the car has passed the emissions test that the goverment has up here with flying colours. I had it on the highway and it tops out at about 62 MPH or just under 100 kmph, but what do you expect for a 41 hp 4 wheel drive Tonka Toy????
Other than that, all you have left is a court case, which doesn't sound very feasible cost wise.
Given that it sounds like your car wasn't in very good shape cosmetically, and that you didn't already have an appraisal on file, I'd have to say that your chances aren't all that good for getting a decent settlement. The 280ZX doesn't bring much on the market, and you can buy decent ones pretty cheaply.
What are you being offered?
currently working on a 64 220 SEb, and having a real hard time finding the exterior rubber/weather strips. dealer is asking way too much.
thanks,
answered you in another topic. Try hemmings motor news and the new EBay Motors on Ebay Auction's site.
www.hemmings.com
www.ebay.com
Dealer's prices are nuts for these cars, but for certain small items that you don't want to buy used, they may have the only game in town.
