Visitor Agreement.
Also, when does the 2002 model come out? Considering the reliability problems the Ody has had, would it make sense to wait till next year's mdx comes out? Any advice would be appreciated.
Please note that you can fold half of the third-row seat and get some cargo room there.
If the space is not sufficient, full-size SUV's like the Sequoia, or a number of minivans, have more room behind the third-row seat.
The only SUV on the planet that will seat adults comfortably in the 3rd seat AND carry lots of cargo is the Surburban. Period.
Excursion (bigger than the Surburban)
Then period.
"Years ago Fram was a quality filter manufacturer. Now their standard filter (the radioactive-orange cans) is one of the worst out there. It features cardboard end caps for the filter element that are glued in place. The rubber anti-drainback valve seals against the cardboard and frequently leaks, causing dirty oil to drain back into the pan. The bypass valves are plastic and are sometimes not molded correctly, which allows them to leak all the time. The stamped-metal threaded end is weakly constructed and it has smaller and fewer oil inlet holes, which may restrict flow. I had one of these filters fail in my previous car. The filter element collapsed and bits of filter and glue were circuilating through my system. The oil passge to the head became blocked and the head got so hot from oil starvation that it actually melted the vacuum lines connected to it as well as the wires near it."
Here's the source article:
http://members.nbci.com/minimopar/oilfilters.html
What are you talking about. Premium fuel serves one purpose it allows for higher compression pressures in the combustion cylinder. If a vehicle requires premium fuel the pistons are compressing the air/fuel mixture to a point where the fuel would detonate on pressure only. Higher Octane (ie Premium) fuel allows a higher compression ratio.
If the fuel air mixture detonates before the spark plug fires you will have knocking which will eventually cause engine damage. Lucky for you the MDX and most engines that require high octane fuels have a knock sensor that will cause the CPU to retard timing (i.e. reduce piston travel) and thereby compression.
But here's the trade less compression equals less power + more pollution + less gas mileage (this all a fact). The ten cents you save per gallon will more than be consumed by less gas mileage...so in fact you are wasting more money burning 87 octane.
The problem is some people equate the word premium in premium fuel to being higher quality. Premium (or better stated, high octane) fuel allows for higher compression ratios. Higher compression ratios are a good thing...as long as the engine is designed for the higher pressure.
High Octane (again premium) is of no benefit for a car designed for lower Octane fuel.
Bottom line for the MDX there is NO negative to using premium fuel. There is no reason to use low octane fuel
I recommend you do some reading on engine theory. Using 87 octane fuel you will be reducing compression by approximately 7-10% as opposed to 91 octane (no need for 93). Because of the variables involved in day to day driving (ie temperature, traffic, route, your daily driving technique, and a thousand other minute variables) there is no way you can judge by your fuel usage or seat of the paints acceleration. But rest assured your engine (all other things equal) is substantally less power on 87 octane as opposed to 91 octane. All things being equal you WILL develop less horsepower, less gass mileage, and generate more pollution. Why do you think Honda engineered this engine to run on high octane fuel? (Here's the answer...it's more efficient. It costs a little more to build an engine to withstand the higher compression ratios, but the result is better performance.) If you want to run your engine with retarded timing that's your choice...but don't state that performance is equal.
From what I can tell, it seems that the base carrier (roof rack) adds some wind noise to the cabin at highway speeds. I've noticed some posts from Oct thru Dec in this forum that complained about MDX wind noise, and they all seemed to have the Touring Package (with roof rack). I remember not seeing much of any complaints from owners who had the base model. Maybe a couple...
I have a base MDX, and I can't complain much about the wind noise. I think I notice more tire/road noise than wind noise.
Probably the best source I have available is from Ann Job, a professional auto reviewer who has a review of the MDX posted at the Acura MDX page at Carpoint (carpoint.msn.com). She gave the MDX a final score of "9 out of 10", but she also noted the following:
"I noticed, in back-to-back drives of vehicles with and without roof racks, that the MDX with roof rack has more wind noise."
If you look at the design of the base carrier from the front of the MDX, you can definitely see the potential for it to generate some air drag. It doesn't appear as aerodynamic as the roof rack on the M-Class or X5.
Here's the timeline as well as the financials:
Price w/tax & accessories: $40k
Truck:
MDX ($34,850)
Accessories:
Wheel Locks ($99)
Rear Mudflaps ($99)
Tailgate Deflector ($495)
Running Boards ($995)
Full Size Spare ($389)
Moonroof Visor ($169)
Burlwood Shiftknob ($199)
Miscellaneous:
Registration Transfer ($50)
Documantation Fee ($20)
If you negotiate, you can get some of the option prices shaved.... but I would wait until you get your VIN before doing that. Some of my accessory prices were a little high (Shift knob, mudflaps), but some of the more expensive ones were shaved when I said that I wanted a better price (Full size spare @ dealer cost).
I have ordered the following from Tim at Hondacuraworld because they require little or no labor on my part:
All Season Mats: $91
Cargo Cover: $104
Cargo Tray: $89.70
Cargo Net: $37.70
Wood Meter Panel: $99
I leased as I didn't want the hassle of selling my car when I upgraded to my next car or got a new MDX. They were able to residualize $400 from the Running Boards, however.
I ordered on November 15, 2000 (I got bumped up from someone who had ordered in October) I got my VIN# on December 22, 2000. I drove my car away on January 11, 2000.
The original build date for my car was Dec 5 - 9. This got changed because the factory was running behind. My pickup changed, also, because of the snowstorm we had in the Northeast. In any case, I totally forgot how excrutiating the wait was once I drove off!!!!
Hope this helps anyone.
Is there anyone who has the same experience? I read some of your comments long time ago and did see someone had experienced the same problem. Did you go to the dealer? What solution did you get? I've made an appointment with dealer already, but I want to get some info from here first. The people here are the real expert of MDX.
Thanks all.
albert123, there is no rocks or bump at all while I make turn (from central exp east, exit on South Lawrence and right turn to merge to Lawrence). You can give a try if you don't mind to test your MDX. Anyway thanks for your posting. I appreciate it.
If you check my message (#914 or #915?), I described the same problem. My dealer, Cush Acura of San Diego, CA, is attempting to diagnose the problem right now. They have been "stumped" so far, but the service advisor has said they are applying "chassis ears" to try to pinpoint the problem.
These problems have been a real nuisance so far (I also bought my MDX last month), but I must admit the service at the dealer has been excellent and the MDX otherwise has been impressive.
When I get my baby back, I will post what the dealer has fixed and also post the last 6 digits of my VIN and date of build, to compare it to others having the same problem, I'm curious to learn if maybe it was a certain batch of MDXs, it would probably be beneficial to Acura and other owners.
Talk to you later.
ucsdtriton, when you had your MDX in dealer to check, did they rent you a car to drive or not? I am just curious to ask and see if any warranty covers the rental car.
If it's what kids do w/ BMW/MB emblems, some kid swiped it and stuck it on his backpack.
Do you have any scratch marks? They're usually just attached via adhesive, so it could have fallen off if there are no marks...
I am wondering if using one of those clay waxing products will help?
dkly
Update: I brought my MDX in Monday morning, I checked with them today (Wednesday 4pm), they still have NOT cured the sound. (For those of you not keeping up, it's a knock, pop coming from the front somewhere, in my case directly under the left footwell, when making a right turn, conditions vary) They have tried loosening and then retightening all pertinent chassis bolts, they say the sound has decreased but is still not gone. They are coordinating with Acura Tech to find a solution.
THEY HAVE TESTED 3 OTHER MDXs JUST OFF THE TRUCK, AND THEY ALL MAKE THE SAME SOUND! SOME LOUDER.
Personally, I "love" this car, it's utility, luxury, looks, etc., I even think the service department is first rate, but if they cannot cure this problem, as "dkly" is suggesting, I will do everything in my power to utilize the California Lemon Laws (which I will learn more about if need be, hopefully not), to get my money back or another car.
Will keep you all posted...
RC from San Diego
PS - "always49" and "mdxed", my VIN's last six digits are "508535" (I don't know the build date or if it's even on the MDX, because the dealer still has mine, also if either of you don't want to provide your VIN or whatever, its fine). But this may not matter if this is a problem for all MDXs, based on what the service department has just told me about the 3 MDXs they just got.
And, yes, my dealer has always provided a rental car for me when my MDX has been in for warranty service, via an in house Enterprise Rent-A-Car satellite office. My service advisor has just told me that if they can't fix it by tomorrow, they will give me an Acura "loaner" car so they don't have to continue paying Enterprise.
Have you added anything to your MDX that may have screwed up the electrical systems, ie. extra alarm, siren, etc.?
Canada though!
is mediocre and the Touring Edition stereo is barely better; the best thing you can do is
buy the base system and replace the speakers.
Can anyone with listening experience with both systems comment? Is the system really
that poor? Is the Touring Ed version really that little better (not a problem for me, as I didn't
get the Touring Ed in order to get the SUV within a month)?
Hopefully, this will at least sound better than that piece of $$!@! in my '99 Subaru Outback.
Whaddapieceof... I'd hope it would at least sound as good as the Alpine/Honda stereo
in my old '91 Honda Accord...
Cargo space: Is essentially the same as old Explorer, with the 3rd row down.
Brake Hiss: Yes, I did notice this initially. It is still there, but I don't really "notice it" anymore. Not a real biggy.
THUD: Yes, once in a while I do notice a thud, from below, toward the rear. Have read some posts indicating it might be the torque converter locking and then unclocking. Not a real biggy ... will wait to see what Acura says downline.
Tailgate noise: Yes, this was a biggy to me. When I would go over a bump/and kind of turn sideways, I would hear a noise. THought it was the tailgate. Took it in. THey worked with Acura techs, and found it to be something related to the spirals around the pillars. Anyway, it took an afternoon ... and it is gone.
Cargo cover: FIrst one I had ... kind of rattled, had it replaced. No longer hear it kind of jump and down after each bump. I do find it a bit of a nuisance to have to take it out CAREFULLY (squeeze the ends in) as to not scratch the inside of the car ... and it doesn't really fit horizontally if you just want to place it behind the 3rd rows. Sometimes at carpool, I pick up a few extra kids, need the back seat. BUt, I kind of need to know in advance, to take the cargo cover off and kind of place in my garage. Will look into the $13 vinyl cargo cover at COstco .... but I don't think this would easily come up/fold etc. I currently have an old clear shower curtain down, which can easily be picked up and placed in the storage bin. But, this is under the cargo "cover" ... can't be seen by and large. Think the Acura liner is several hundred ... and has to be "installed" ...????? Any info on this item would be appreciated.
Do really enjoy the navigation system. Have used quite a bit. But for the most part, I drive around with the clock setting ... in large print. I need this all the time!!
Did get the mats. Love them. Can only get them for first and second rows from Acura. At the carwash, I bought some cheapy beige ones, and turned them over so the black side shows ... actually got 3 small ones ... for the back row. TUrned one vertically ... for where kids step in from outside.
It's wider than my Explorer .... do notice the width going into garage, but have gotten used to it. Not a situation where windows have to be folded in. THe tailgate also goes up, it's close, but does not hit the garage top door. I had looked seriously at Tahoe .... but found its size to be unappealing .... in real life ... day to day driving in school carpools, grocery store lots, etc. etc..... This MDX is very maneuverable.
Only had one outing in snow ... and it was great.
In the D.C. area .... have now seen about 4 or 5 locally (some from Virginia) (I am in Maryland) .... other drivers wave!
Really love my MDX!!!!
For those of you comparing Mdx to Highlander; Here's the Difference:MDX is a better value. It's sturdier, wider, longer,better quality materials and 2 most important things are1> it's priced just $1600. more than a HL 2. MDX comes with a better warranty 4yr/50,000 miles as opposed to HL 3yr/36000.miles. The Hl is way overpriced. It may feel like a Lexus, a cousin of Lexus but it's not a Lexus.I hope people resist paying MSRP for HL.
Regarding THUD sound: I am still experiencing daily the strange THUD sound under my left footwell when making a right turn. My appointment is next Wed. (24th) and will post what they diagnose.
Thanks a lot for ncsdtriton of the whole updating posting. You are the lead and pioneer of THUD issue. You and we will get more support from more MDX owners. My last 6 digits VIN is 507977. I live in Sunnyvale, north California. Let's do it together, if we have to "...get money back or another car."
BTW, ncsdtriton: I saw another MDX owner complaining the same problem in acuramdx.ord. His/her name is losangshopper. Is that you ?
1) Your item #1 said the MDX was just $1600 more than the Highlander. Are you using the Base or Touring Model as the reference?
2) Sorry about the wind noise, but you helped confirm my suspicions that the cross-members making up the roof rack add some definite wind noise at highway speeds. I saw a post in here a couple weeks ago from someone who said he was going to remove the roof rack on his Touring MDX. You might consider that option if you find no functional value to it. I have a Base MDX without a roof rack, and although it isn't as quiet as a Lexus, I don't have a problem with the wind noise. I would venture to say that I hear just as much road/tire noise as wind noise.
I forgot one thing. Yesterday I called ACURA Client Service 24x7 phone line and did talked with a tech support engineer. Based on what he said, so far there is no record of this THUD sound problem. But in your posting, you said that your dealer talked to the ACURA engineering headquarter and change your car's strud tower... Do you think that ACURA is really aware of the issue?
Thanks for the advice about third party roof rack. MDX rack is not much to brag about. Do you have any contacts for third party rack?
One behind the second seat
One behind the third seat.
Both are identical in how the cover "snaps" or compresses into a little detent. There are four plastic covers which pop off with a screwdriver for the two positions.
Perhaps whoever installed it didn't pop off all four, but just got the front two? (can't imagine the dealership messing this up, being as they are the experts on this vehicle...)
Once you get used to it, it is a snap to compress the whole thinh with one hand and pull it up to the window, release, them turn it to get it out.
To my knowledge, both the cargo tray and Cargo liner are user-installed.
Ard
Most vehicles which carry Thule/Yakima/etc are NOT "adjustable", nor is adjustment necessary for any of the carrier accessories made by these manufacturers. All these accessories are made with the assumption that the distance between bars on different installations will vary, and they will fit on any spacing within reason.
Go ahead and justify the base model, but give me the factory rack any day over the tubular contraptions from yak/thule.... Plus, if you think they will be quieter than the factory, I doubt it.
Any specific issues?
Lets discuss.
Ard
What are you comparing to when you say it has a lot of wind noise? A car? :-)
You're pushing a giant box against the wind. ;-)
I bought my MDX from the same place you did (Rallye Acura). I got the base, however. I drove mine on the Grand Central Parkway (Northern State) and the LIE. I have the moonroof visor and the wind noise is comparable to a midsize sedan from Toyota or Mitsubishi. Maybe you should get the visor.
If you know of anyone that has an MDX with the visor, ask them if you can ride in it when they go on the highway. See if there is a difference.
Some of the earlier posts indicate that there is a marked difference with the roof rack on it, also. I suspect that the rack is causing most of the noise. It is not very aerodynamic....... that is one of the major reasons why I didn't get it.
