The three holes are already drilled on the splash guard itself. There are two pre-drilled holes (that already have screws in them) on the vehicle itself. You remove those two screws and then use them to attach the splash guards. The third hole is not pre-drilled but is dimpled, and you have to punch through on them. That area is actually plastic and not metal so it's not particularly difficult.
Again, the tricky part is getting a screw fastened (along with a little retainer clip) because the rear wheel gets in the way. A lot of do-it-yourselfers have found it easier to remove the rear wheel while doing it.
Resale value on all the models should be quite good. While the MB will be higher, it's not markedly more so than the RX300 from what I've seen (a few or several hundred rather than a few thousand -- I'm sure Tony has researched this very well). On www.acuramdx.org, there were some referrals to web sites that gave very high projected resale values to MDX's but I'd take those with a grain of salt since it's way too early to get an accurate number.
No doubt the RX300 is everywhere, but if Honda doesn't differentiate its version of the MDX sufficiently enough from Acura's, then you'll see a lot of MDX-like vehicles floating around too. The RX300 is a very pleasant vehicle and of the three that may fit your needs, will probably give you the best reliability. Please note that a "SilverSport Edition" is out or is coming out, basically a cosmetic trim with a supposedly more "Euro-tuned" suspension. The RX300 forum can give you more info on this.
As Drew said, you can't deactivate the rear side airbags in the M-class. Some people don't mind, some people are concerned about it. Since it's a child's safety, I couldn't and wouldn't say with absolute certainty over whether or not it's something that should be part of your purchase decision -- it's up to you and your own judgement.
If it helps, there have been no documented cases of injuries from these rear side airbags.
If a child is properly restrained with a five-point harness, he or she should never get dangerously close to the side airbag. That said, children are remarkable in their Houdini-like ability to wrest themselves free of any restraint, and could possibly find themselves leaning dangerously close to the airbag.
MB obviously feels that the benefits outweighs any risks, while BMW feels otherwise when it comes to rear side airbags and children. In your case, I'd still recommend placing the childseat in the middle of the second row, whether you get the MB and its side airbags or not. (Unless outrun can show us some new information that can enlighten us.)
One item that'll help are the newer car seats for post-toddler-size children. It used to be that when the child outgrew their forward-facing convertible seat (usually at around 40lbs), they went straight to belt-positioning boosters. Fischer-Price has the Futura, which can hold a child in a five-point harness for up to 60lbs. And Britax is about to release the (probably very expensive) Super Elite, which will employ a five-point harness for up to 80lbs! (Unfortunately, the seat will be large enough that it won't be airline-compatible.)
Those seats have the advantage of a better restraint system (5-point harness) than using a re-positioned seat belt. Though this is tempered by the fact that some children won't tolerate being in a 5-point harness past a certain age and/or size.
As far as accessories go, you'll have a number of options for installation. Items like the cargo tray and cargo cover are no-brainers even if one isn't mechanically inclined. For something like side steps, a lot of service shops would be able to give you a labor estimate for installation.
If some of your local Acura dealer service departments are on the up-and-up, their service departments should be able to quote a "fair" labor estimate for installation without being "spiteful." The key is to contact the service department directly and get a labor-installation quote. Of course, the labor rate they charge will be higher than a neighborhood service station, however.
Okay, we went out looking at the vehicles today. First we looked at the Lexus. I hate to say it, but when I looked at the cargo space, we had to pass. We decided not to test drive because it just seemed too small. One of our primary goals is space, so we just crossed the RX off our list.
Luckily, a MB dealership was right down the street. We decided to peek at the ML. It did have more space than the RX, but probably not as much as the MDX. We took it for a test drive and were pleasantly surprised. It did have somewhat of a bumpy ride, but it really just reminded us of our BMW. I guess it's the German construction. Are MB salesman very non-pushy? Or did he not think we were interested? He didn't hard sell us and he pretty much let us walk us off the lot.
So, now we are in somewhat of a quandary. I need to do more research on the ML, but it still seems like the MDX is still more for us - on paper. However, we just can't seem to test drive the darned thing. It is hard to make a decision based on faith. At the same time, we don't want to just decide on the ML only to find we would have preferred the MDX. The wait time is unbelievable on the MDX, and the ML is definitely an acceptable choice, and we can have that NOW.
Thanks for all the input because I was dead set against the ML until you guys gave me some more information. I am still not too excited about the exterior and the interior controls seem a bit awkward. Also, no separate climate control, and the CD changer in the trunk. I had that in my Accord, and it wasn't too bad, but it sure would be nice to have an in-dash CD. Also, the ride isn't the most luxurious, but it's not a Pathfinder, either. Safety is important, too. It does seem like a more heavy-duty car.
All that said, I still think we need to drive the MDX, but I don't know how that will ever happen. Know anyone in Sacramento who'll let me drive theirs? HaHa
FYI, an in-dash CD player is optional, and can be added to supplement the trunk mounted CD changer (which is partly located there so that it is not obvious; anti-theft protection). The GPS navigation system's CD drive can play audio CDs.
It depends on what you consider a luxurious ride. Some like to feel like their riding on a cloud, and others don't. FWIW, some dealerships don't air down the tires to the proper specs (29psi) and hence the ride may be bumpier than necessary. The ML's ride is definitely firmer than the MDX's though, partly since it is designed to go off-road and you don't want the vehicle to bottom out easily on bumps. German vehicles are also usually firmer than Japanese vehicles. The MDX is designed for only light off-roading.
You should also check out the dealerships you'll go to. Some have horrid service departments. Some are awesome. Do it for all the models you're thinking of including the Acura one. I know one or two folks have only a single MB dealer in their area and they qualify for Service From Hell. Your dealer's salesfolks probably were the better ones; in my area, one dealership had salespeople that were pushy, ex-Tweeter salesmen, and another had more mellow salespeople that tried to make your experience enjoyable w/o pushing all sorts of addons and packages on you during sale or signing. Guess which one I ended at? ;-)
The "German feel" I think has a lot to do w/ the "heavy" steering. Some people like it. Some hate it for not being "luxy" enough. I know some people hate this year's BMWs because BMW tried making the steering too light to accomodate the average American driver :-)
Climate control for the ML will be in MY2002. You can get an in-dash single CD (probably get them to throw it in) as an option. No CD changer in dash unfortunately. You also may want to test the ML430. Focus on the road feel and not the engine power. The difference is in the bigger wheels and thinner rubber, so it feels *much* sportier and less trucky. If you like it, you may also want to think about the Sport pkg or upgrading the tires to Michelin Cross Terrains.
Definitely test drive the MDX. I also drove one to make sure I wasn't making a mistake w/ the ML. You don't want to make a mistake w/ a 40K purchase. You shouldn't have that hard a problem finding an MDX in the L.A. area if you want to take a day trip. Enjoy the shopping. It's a fun experience as long as the salespeople don't pester you or give you the horrid "what can I do to get you in this TODAY" shoving...
I'm glad you looked at some vehicles today, it's always refreshing to get away from paper research of vehicles and actually get out and look at them.
I figured that coming off the 3-series, you'd like the ML320's steering and handling and wouldn't mind its ride as much. As I mentioned before, Rob (cotmc) can share his experiences too, and he was driving a 3-series as one of his vehicles when he made a purchase decision.
One key question for you to consider is whether to buy a 2001 ML320 like the one you drove today, or wait for a 2002 and the various upgrades to standard and optional equipment. The M-class discussion board will provide a lot of insight into the differences between them. You'll likely be able to get a good discount on a 2001 ML320, especially as the 2002's get near. In past years, MB has offered their dealers an incentive so they could cut the price further, since the spread between invoice and MSRP is not much, compared with the MDX and the RX300.
You'll also need to decide if you want to buy the ML's extra-cost third-row seat option, as you have to get it at the time you get the vehicle, and can't add it on later.
It sounds like Acura dealerships in your area aren't forthcoming with test drives. Some dealerships make it a policy to always keep a demo or two around, it may take some calling around to find one. Obviously you wouldn't make your decision based on a paper assessment of the MDX alone. You may test drive it and really hate it, or dislike it, or love it. We had test-driven the ML320 months before we test-drove the MDX, but we made sure to test-drive the ML320 again the same day we finally got to test-drive the MDX.
And please don't forget Ken's suggestion to check on MB and Acura service departments in your area. You can ask on message boards about the service departments in your respective areas. Where I live, there's one conveniently-located MB dealership, and one that's less so, and one that's a bit of a distance. We had already had excellent dealings with the nearby Acura dealership's service department, they have always responded well to my wife and have never patronized her. Unfortunately in my case, I got back some lukewarm and negative feedback from a few M-class owners in my area about the service at both local MB dealerships.
And also, when you're asking, please make sure commenters differentiate between their sales esperiences and their experiences with the service department. They can be two very, very different things!
I noticed that my steering wheel is slightly off center. By that I mean that going straight, it's actually "aimed" slightly to the left. Another way of saying this is that the horizontal part is not level, probably off about 1 inch...lower on the left than on the right. I've always been under the impression that means that the vehicle is out of line. Since I only had a few hundred miles on it when I noticed, I was pretty sure that I hadn't hit a pothole or curb and that it was delivered to me out of line. So I took it back. They set it up on the alignment machine and it was perfect. The service manager told me that they could reset the steering wheel, but that the spline that it sits on only has eight teeth (think of it as gear-shaped). Because of that he felt that it would likely end up being tilted off center to the right and that getting it in the middle was unlikely.
If this is true, then Acura engineered this wrong. And if they did, then all of us must have this problem. So before I get it done or insist that they recheck the alignment, I thought it best to check if any of you have this same problem. I vaguely remember that someone was talking about their steering wheel being offcenter several months ago, but that was before I took delivery and I didn't pay much attention. I tried to find the discussion, but couldn't. Any help greatly appreciated. __________________
I think was the one who mentioned that the MDX's steering wheel is off-centre. By off-centre though, I meant that when you sit down in the driver's seat, the steering wheel is more to your right, than being perfectly centered with the driver. I had a picture somewhere, but I can't find it right now. Note that the Honda CR-V also has this off-centre position.
Drew Host Vans, SUVs, and Aftermarket & Accessories message boards
Pretty sure, LOL! The steering wheel is both offset and off-centre, but not by much. Maybe 2 inches at most, if I recall correctly. Personally, I would much prefer if it's directly centred and not offset. As mentioned, the Honda CR-V has a similar odd steering wheel position as the MDX.
I don't own an MDX but I know something about steering alignment. Steering wheels that are not level when the wheels are pointed straight ahead is a common problem and is easily corrected. The Alignment technician simply needs to clamp the steering wheel in the proper "level" position and then tweak the tie rod adjusters on both wheels to be pointed straight ahead using the alignment machine so that proper toe-in is maintained. I think they just don't want to go to the trouble.
Well, I'm back from the garage after looking @ Drew's pic. The Acura Logo on the wheel, the CENTER of the speedo, and my belly button (also centered, I believe, like Drew's) all line up. I don't see any offset @ all ?????
BTW I answered ghotie's Q over on acuramdx.org -- the dealer should be able to align the steering wheel to 12 o'clock no problem. The car COULD be in alignment, which he (and the dealer) says it is, but the steering wheel just needs to be centered.
My wife and I had put a deposit down on a mahogany MDX w touring during November. We were told by Sunnyside Acura of Nashua, NH that it would be in during March, then April, then late April most likely May now it will not be in until June. Is the Mahogany w/touring a rare type? or is Sunnyside blowing smoke? If the SUV ever comes in should we try to negotiate? Are we purchasing a devalued SUV. (I suspect it won't come in.)
Has anyone had a similar experience with Sunnyside or with acquiring a Mahogany/touring from any other dealer?
I have driven both the MDX and the Mercedes ML, and I have been reading the Town Hall messages on both but can't decide (It seems that this is a common problem). I do not want to consider other luxury SUVs because I am interested in the 3rd row seat, although I will use it only occasionally. I keep seeing messages (rumors) from Kenyee about the changes on the ML 2002, but I could not find any other information about it, even on the ML message board. Could anyone direct me to a website or post pictures of the ML 2002 ?. Is there going to be a significant change on the exterior body appearence ?. Thank you.
Anyone have an opinion on the utility / need for running boards on the MDX? I am taking delivery next week and I am investigating the dealer options. I have two small children (ages 2 and 5). Will running boards help them climb in? Thanks for any feedback.
Not only will it help them climb in but will help you, too, when you have to use your overhead rack, unless you're tall enough that you can reach the top.
With the 8 inch ground clearance..and 2 little ones..would be a good consideration..enhancement of appearance is an individual thing..another idea is resale value, there is always an "add" for running boards ,whichever sport ute you look up in the blue book..in short..you could recoup part of your investment later if you trade or sell, all the while you get to use those babies.
I believe that I stand corrected. I've talked to a few people about car seats in the past, and they've said that the left or right is better because of the reason I stated originally.
But it seems to be the overwhelming majority of experts (as noted in the http://www.carseat.org web site) that the rear-middle is the best position for a baby car seat (if you have one child). This was my original theory until I was told otherwise.
Now I'm going to move the car seat back into the middle.
I'm glad to know that there isn't some new recommendation out there that I wasn't aware of. I really think there should be more of an effort (maybe by the AAP, I don't know) to disseminate *accurate* car safety info -- I hear all the time about people being instructed incorrectly even by hospitals or pediatricians, and the rules on what size/age child needs what seat in what configuration are so arcane, there really is a need for a strong voice to get the info out there - if it's confusing for people like us, who have access to the net and know how to do research, it must be almost incomprehensible for people without those capabilities.
Just my rant for the day! Thanks for following up.
I asked this question before and didn't receive any feedback so I ask again. There is no side bar for MDX roof rack, is there any accessory option to go with the roof rack? If not, how do you tie the car top tightly to your roof rack ?
Bought mine in Mississippi and drove it back to Michigan while stopping only for gas. Found that my fuel economy got as high as 24+ on the first tank and then started falling to where it is today and 1,000 miles later @ 20 mpg. Called Acura service and they didn't have a clue why it would fall off like that. What have you experienced? I was looking forward to seeing it go above 24 not below.
I have been wracking my brain to figure out the MDX roof rack-- why on earth did they place the rear bar so far forward?? Certainly it can't be because of the antenna, since that can be placed almost anywhere (certainly FORWARD of the front bar !) Any ideas why?? And I likewise agree with above post questioning lack of side bar, esp with MDX's decent ability to generate "lateral G's" ( .74 by C&D's Dec. 2000 test) By the way, overall rankings on that 7-"Designer SUV" test, with comparative points given in 11 different categories were: MDX- 1st/91 points BMW X5 3.0- 2nd/89 Lexus RX- 3rd/86 Mitsub. Montero 4th/84 M-B ML320- 5th/80 Infinity QX4 5th/80 LandRover Disc'y 7th/72 VERY GOOD statistics on space, performance, load capacity, and seating comfort, in the magazine! www.caranddriver.com only has the text, unfortunately !
I live in San Jose CA and am planning to buy a MDX. How long is the wait in the Norcal area especially now (with all the layoffs and dotcom money gone). Any recent experiences? Can I get it within a month or rightaway Thanks
That all depends on how much you want to pay. Some people have received their MDX pretty quickly, but had to pay over MSRP. Most Bay Area dealers are charging over MSRP and/or forcing accessories. As far as I know, the wait is pretty substantial just about anywhere.
I am on a waiting list that is about 7 months long in Sacramento, but it is at MSRP w/o forced accessories. If I were you, I would just start calling around, and if you are willing to pay extra, you might get lucky.
fastfingers - Looks like your dealership sold you a bill of goods. I checked around all the Boston areas dealers in February when we first started looking. The color didn't seem to matter much as far as delivery, but they were all talking June/July. My wife had the idea to try Rhode Island dealers. We ordered our MDX from Inskip in Warwick. Just confirmed with our contact Brian Farrington that our GG MDX has shipped & we should see it a week or two. So, our wait will be about 3 mos. I know Inskip's backlog is out til September now, but you might want to give Brian a call (401-821-1510).
On highway with average speed about 70, my mpg is about 22-23. This is strictly highway driving and it seems to be affected by the wind condition also. The best mpg based on the trip computer seems to be between 35-40 mph which consistently goes above 25. Over the last 6000+ miles, my average is about 16.5 mpg, mostly in suburban traffic.
Enjoy your new MDX, it's never going get the mileage of, say, a Honda Accord.
I think this was discussed here before. Could someone let me know how to decipher the VIN#? Can you tell make date/month/year, location, etc... Thanks.
Just came back from test driving an MDX - touring model. I really like this vehicle. It looks great and handles beautifully. But, I did not like the stiff ride. Within the city it was okay, but on the highway I felt every tar strip and imperfection in the payment. My question is, does the ride soften with time? Or is there a way to make the ride a little softer without compromising handling/performance?
Ride comfort is highly subjective. Some people think one vehicle is stiffer, while the others feel it's comfortable. Have you tried an RX300? It provides relatively more isolation from road imperfections than the MDX.
I haven't noticed a softening of the ride over time, and we've had ours since early October. We're fine with the ride comfort, however.
I'd imagine that some tires might make the ride a bit softer, but there'd be some compromise. This is assuming that the Michelin Cross Terrain SUV's in the Touring model you drove ride a bit more comfortably than the Goodyear Integrity's that come with the base.
Thanks for your response. I like the cargo room in the MDX so that leaves out the RX300. I've been driving a 97 Explorer for the past 4 1/2 years and the MDX is light years better than the the Explorer. I test drove a Highlander the other day. The Highlander is quiet and has a nice ride, but I like the MDX better. Life would be much simpler if there weren't so many choices. But then it wouldn't be as much fun.
I believe the Touring model you drove came with the Michelin CTs. The MDX base model comes with the GY Integritys which have a thinner sidewall and a more compliant ride. But as William pointed out, there is a tradeoff with every choice, and the tradeoff here is that the Michelins handle better than the GYs.
See if you can test drive a MDX base, I'm positve you will feel a difference.
We have the touring/nav...Michellins as tonychrys points out. I'd like to say it's loosened up a bit since we got it -- about 3k miles ago -- but maybe I'm just used to it now...
What made the biggest difference was lowering the tire pressure from 40-42psi on delivery to Acura's recommended 32psi. Overinflated tires will make the ride pretty harsh, and Acura dealers overinflating was noted on numerous occassions @ acuramdx.org.
Excellent, excellent point, which I overlooked. You'd be suprised at how many dealers, of every car brand, don't bother to lower the tire pressure after the cars come off the delivery truck. This can definitely ruin the customer experience when someone is test driving and give them a false impression of how the car truly handles.
You might want to look at the 2002 Explorer or Blazer. The latest Motor Trend thinks the handling has gotten a lot better. If it's not the tire pressure (test drive at another dealer to confirm), it might be a result of Acura/Honda being "stiffer" (more handling oriented) than American cars. You should have heard my comments after one of my coworkers w/ an Expedition gave us a ride to lunch...I was used to driving an Integra...it totally freaked me out :-)
That's funny... the Expedition (and Jeep Grand Cherokee) is the choice of SUV amongst my fellow execs at work. Whenever I ride in one it feels like a boat cruising on land. To me it feels like totally floating handling, but my buddy at work swears by it .
I remember back when I mentioned that I was shopping for a new SUV and mentioned that I was looking at Acura, Lexus, and MB. They gave me a hard time and said "why do you want to over pay for those pieces of junk?" To each their own ;-)
Exactly my feeling. It feels really sluggish. Leaned like crazy when merging w/ traffic. It had an awesome rear climate system though :-) He bought it to tow his wife's horse trailer which she never got. He also gives me unending crap about my "snooty" ML -: I just shrug and tell him I push it as hard as my old Integra (with extra safety gap for stopping distance) and it doesn't squeal or lean much when I push it. :-)
I have just spent about 45 minutes catching up on what's been "said" here the past few days and I'd like to comment on a few things. First, I think that pricing and wait vary greatly from state to state....even dealer to dealer. I live in Minnesota and I'm on a 4-month wait for my MDX, which I should get next month (I can't wait!!!). I spoke to a woman who waited just 6 weeks for hers (I'm jealous)! All three dealerships in the Twin Cities have one on hand to test drive. You may have to wait to get your turn, but it's there. I can't believe that any dealership would expect someone to buy a car from them without being able to test drive it! As far as pricing goes, I saw Tony's comment that right now the RX is the best value out there. Not in Minnesota!!!! I have been on the lookout for the past 6 months comparing the two vehicles because I love them both. It came down to more bang for my buck and I chose the MDX. The extra room was also a huge added bonus. I recently got a call from a Lexus salesguy about a used RX (2001) with around 9,000 miles on it for $40,000. OR I can wait for a new MDX and pay $35,000. Pretty much a no-brainer for me. The benefit of the RX would have been a 6 CD changer and memory seating. Not worth it. My husband has test drove both the RX and the MDX and favors the MDX. He's 6'2 and likes the extra room in the MDX. The ride is smoother in the RX, but the MDX's ride is still very nice. Also,we live in Minnesota and one of the reasons I'm getting an SUV is because I actually will utilize the AWD. Here, there are no such things as discounts on RX's, or do I doubt there will be on the MDX's. People NEED them here and they will always be in high demand. Why give us a break when we'll by them without one??? Another thing Tony said too (not picking on you Tony) is about people commenting on "wasting" money on the MDX, RX, MB... I priced out a 2001 Explorer - Eddie Bauer with the extras on the MDX, and it came out to be just under $40,000! That's no bargain!!! Anyway, I've done extensive research and am very comfortable with my choice of the MDX. I will be happy, my husband is already asking me when HE can drive it, and the dog will be very happy to have all that room in the back! I am looking forward to posting a message when I take delivery so I can give you my opinion of my purchase when I'm really an owner! Thanks to everyone for their thoughts and opinions!
For what it's worth, I believe there were two articles where the authors claimed that the MDX Touring with the Michelins not only handled better than the Base with the Goodyears, but the ride was also smoother and quieter. One described the Base as "harsher." Go figure.
You're right about tire inflation, though. It's amazing how many dealers have it off.
Picked up my MDX yesterday. Love it. Without my knowledge or approval the dealer added $399 First Place Finish (interior and exterior protection). I didn't learn about this till I was in the Controller's office about to write a check. It was either pay the $399 or walk out so I paid. What a way to run a railroad.
I would definitely write to the manager at the dealership and find out who the regional or national manager is and copy them. I think you can go on line to acura.com and there is contact information there. I would even copy the BBB. That is plain wrong. Now that you've taken possession, demand that money back. Happen to have a friend that's an attorney? Ask if there's some recourse. DO SOMETHING!!!! If you don't, then it's going to happen to the next guy who can't wait to FINALLY pick up his (or hers, as in my case) MDX. My last suggestion is to print the name of that dealership here as well, so others know to go elsewhere, or buyer beware.
Hope this helps!
Well, I'm off to research the ML a bit more.
Again, if you have any questions, feel free to ask in the M-class topic. For MB dealership recommendations, have a look here:
sshowitt "MB M-Class Owners: Dealers & Service Experiences" Jan 30, 2001 12:32pm
Drew
__________________
Drew
Drew
Fastfingers
Sorry for the confusion...
-Craig
and
http://216.122.199.143/forums/w163/vthread.asp?messid=1818
Going back to the MDX, any expected changes/improvements for 2002 ?
MDX- 1st/91 points
BMW X5 3.0- 2nd/89
Lexus RX- 3rd/86
M-B ML320- 5th/80
Infinity QX4 5th/80
Good luck to you.
Scott
-hl
Digits 1-3: 19U = Honda of America Manufacturing, Passenger Car
Digits 4-6: UA5 = TL/Inspire 4-door, 3.2L SOHC VTEC V6
Digits 7-8: 64 = 4-speed automatic, non-NAV
65 = 4-speed automatic, NAV
66 = 5-speed automatic, non-NAV
67 = 5-speed automatic, NAV
68 = Type S, 5-speed automatic, non-NAV
69 = Type S, 5-speed automatic, NAV
9th digit is a check digit
10th digit is the model year designator
X = 1999, Y=2000, 1=2001, 2=2002
11th digit is the manufacturing plant code. In this case, A = Marysville, Ohio plant.
12-17th digits are production sequence numbers. Canadian models may or may not begin with an 8 versus a 0 for U.S. models.
