Acura MDX (pre-2007)
My only remaining concern is that none of the dealers I spoke to, including Newport Acura, would give me any indication on what they would give me for the car I plan to trade in. They said any quote they could give me for my trade in was only good for 30 days, which is longer than my waiting period. It seems that with the purchase of the new car all set and many buyers willing to step in my shoes if I balk, that the dealer has the cards on that. Any advise on how to handle the trade-in negotiation?
Also what's the latest on the Alabama plant? How will it add capacity for Odyssey, MDX, and/or Honda's MDX version? I think the existing line does 120k Odyssey & 40k MDX; If the new plant has similar capacity (?) might we see an additonal 40k Odyssey, 30k MDX, & then 90k Honda MDX? Thinking one plant might produce Odyssey exclusively, with the other splitting SUV production? If I worked in Detroit I would be very, very scared.
In the Ratings sections, CR says "We top-rated the Explorer in this group, but if you don't plan any serious off-roading--and can afford to pay more--consider the spacious and more-refined Acura MDX, with seven-passenger seating, typically $37,500, or the Lexus RX300, with room for five, typically $40000."
CR ranks the Acura MDX tops, with the Lexus RX300 and MB ML320 following. The 2002 Explorer is right behind the Benz. Only four models are checkmarked (meaning "the model is recommended"): the MDX, the RX300, the Pathfinder, and the 4Runner.
Transpower
Curiously, though, if you yank out the MDX, RX300, and ML320, the Explorer tops the list though it's not marked "recommended" yet (promising). That distinction came up in a network news report I noticed the other day, saying that Consumer Reports had put it at the top of "its class". Go figure; someone probably decided to create another SUV class of "non-luxury" vehicles to exclude out the MDX, RX, and ML (which is a bit strange since you can buy some of them for a price similar to a loaded-up Explorer).
Does anyone know what happens for sure?
Yes, it's a bit late for me for the MDX. Like I said, I was totally turn off by the L.A. area Acura dealers that I decided to purchase a Toyota Sequoia Limited instead. Two of the dealers, one in Santa Monica and one in Montclair (Greater L.A. area) didn't even bother to call me back for the availability of the car assigned to them. Downey Acura (in Downey, CA) asked me to shell out about $4,000 in accessories. Thomas Acura in Covina charges $99 for the undercoating spray on the brand new car and $985 for the chrome wheel on top of wood panel around the instrument and shift knob and many other options (total aorund $3,500 extra). The only decent dealer in L.A. I experienced with is Acura of Pasadena. They're willing to sell me the MDX at sticker price. No add-on. Unfortunately, they don't have any car available for delivery until late September. I'm tired of waiting!!! I'm tired of being hussling!!
Unfortunately, even though you did find an apparently honest dealer in L.A. (thank goodness as it sounded like all of them are crooks), one can't get away from the wait. Late September is actually pretty good as some wait lists are out into next year.
Sadly, this is another example of Honda/Acura's production limitations. The new Alabama plant will eventually produce all Odyssey's, leaving the Ontario plant to build MDX's and probably the Honda version of the MDX's. Only then will there be enough supply to help discourage the greedy dealerships (since Acura seems to have no capability of doing it themselves).
It'll happen eventually, though too late for a number of buyers who either can't wait or are disgusted with the bad dealerships. The 3.2TL was similarly hot but nowadays you can get a non-Type-S one for a relatively small profit over invoice. Since the MDX has a fairly sizable difference between invoice and MSRP, there will be a LOT of room for big discounts, sooner or later. Unfortunately I don't think something that drastic will happen until the third model year, with some weakening perhaps late in the second model year. It's a shame because an MDX discounted to, say, $32k for the Premium, $34k for the Touring (without nav) is very attractive. Though I'd bet that Acura will improve the content of the MDX and keep its selling price relatively high and leave the low-$30's range to the up-level trims of the upcoming Honda mid-sized SUV.
However, there are several pictures of MB M-classes with the 3rd row seats that have been rear-ended, that you can see here. Everyone of them turned out fine from what I've learnt:
http://albums.photopoint.com/j/AlbumIndex?u=137587&a=10126395&f=0
BTW, which part of Canada do you live in?
Drew
http://www.acuramdx.org/forums/showthread.php?threadid=2667
Unfortunately it doesn't specify the speed of the driver or the exact vehicle (just a small GM). But MDX damage was minimal while the other vehicle was totaled.
In the dump truck collision, it probably wasn't 30mph, but you have to consider against the damage the size and strength of the vehicle that hit that particular MDX. At the same speed, a collision with a more conventional, modern passenger sedan would have probably caused a lot less damage.
In any vehicle the third row is going to be closer to the point of a rear-end collision. Spacing will help, vehicle structure will help, lots of variables here. There's more room behind the third row in an Odyssey than an MDX (the Odyssey is noticeably longer, and is a large minivan period).
According to Jedlicka's review of the MDX, Acura supposedly designed the MDX "to withstand a 35-mph rear impact with no intrusion into the third-row seating area." I assume that means relative speed (e.g. you're going 50mph and someone going at 85 hits you), but I don't know how that compares with other vehicles.
Bottom line to me is that if you're not comfortable with it, don't get it, no sense worrying about it unnecessarily.
wmquan: I do understand the if anybody does get into an accident, there's always the chance of injuries. That's why I almost memorize all the safety features of the MDX to understand the vehicle better before I plunk down the money. I'm driving a 93 Camry now and that I find the car extremely reliable and easy to drive. That's why I lean towards Janpanese made cars. MB and BMWs are not really within my budget range. But I really, I mean really like the MDX. For some reason, it's just love at first sight.
Yes you're right, I miss that one that your link point to that involves an accident with a smaller car. Thanks for that too.
I'm glad the pictures helped you one way or the other, even though the MDX is actually very different than the MB M-class; the underlying structures are very different.
Good luck with your decision and if you have any questions, I'm sure that the owners here will be happy to help out.
Drew
If you can tolerate waiting longer, it probably doesn't hurt financially to wait for a 2002. Even though the improvements will be modest, Acura will probably fix one of the bugs in the 2001. While price will go up slightly, no dealers are offering discounts on 2001's so you take a depreciation hit just by changing the model year, probably more than the price increase.
IIHS crash test results for the MDX may be coming out late this month (the bumper test was released last month), so that may answer some questions on the MDX's performance in a offset front collision. It should do "good", though I'm not sure if it'll earn "best pick" status as the X5, RX300, and ML320 have done. We'll see. While the frontal collision test won't be a direct indication of the rear performance, you'd hope that if Acura paid some design attention to the front, they're truthful about their claims about the back and designed it well.
The ML320, having been around for significantly longer, does have some documented proof of rear collision performance, as Drew's photos show. I'm not familiar with Canadian pricing of the MDX and ML320, but, depending on how you option out each vehicle, the price gap isn't necessarily really large, especially since 2001 ML320's are being cleared out with dealer incentives (you can find an ML320 below invoice). However, quantities of 2001's are probably limited, especially ones with third-row seats (you can't add them after-the-fact), and 2002 models will sell initially at MSRP with a very modest price increase (in exchange for good upgrades). So perhaps a look at an ML320 wouldn't hurt, especially since it has some features the MDX doesn't have (namely stability control) that may be more suitable for your Calgary weather, which I assume is quite severe (pardon my geographic ignorance of Alberta). The X5 will be significantly more expensive, though.
Good luck, and please let us know if we can help.
Steve
Steve
Jamie S.
I have had my MDX since November of last year. I have been pleased with every aspect of the vehicle except these small annoyances.
Acura has issued a TSB for the thud, so your dealer should be able to take care of it, under warranty:
http://www.acuramdx.org/forums/showthread.php?threadid=2811
No TSB yet for the weeping mirrors.
I _think_ that the newer vehicles have the fix already in (certainly the 2002's will). Reason is because the TSB mentions a certain range of VIN's for each cause of the thud, implying that each cause has been fixed in VIN's after that range. You can check the VIN number of the vehicle you're getting against the TSB to be sure, however, and take whatever action you deem appropriate.
Good luck, and congratulations on your pending MDX!
http://www.hondacuraworld.com/bulletins/bulletins.html
Steve
Drew
WORST THEFT LOSSES
I did kinda wonder if anyone ever clicked on stuff in the Additional Resources box :-)
Steve
A similar technology exists with a cell phone. Cell phones are rarely stolen, because the thief could not use it after it is deactivated. I guess the analogy to a Nav is that perhaps a thief could use the car, but not the Nav if it was stolen. Then again, maybe I’m totally off base.
One reason I am asking, other than being slightly paranoid, is does this influence the decision as to whether to buy a Lo-Jack antitheft system. If the police can track the vehicle via the Nav system, is Lo-Jack necessary. The recent discussion of the popularity of Acura theft also prompted this question.
If you ever drive around and see a television studio or office building with a large dish antenna, note the size. An uplink antenna is much larger than even a home DSS dish and requires pinpoint precision in order to "beam" information to a satellite with any reliability. While I am certain this technology will improve (look at the satellite phones, large antenna plus having to "aim" it but still promising) there is just no way your GPS antenna can send information. Besides, the GPS system is broadcast only, it was never designed to receive, process and relay information other than GPS programming updates.
LoJack is about the only system that uses radio signals broadcast from an on board antenna and detected and "triangulated" by satellites to determine the vehicles position. Ground-based receivers (ie; police department) can also detect the signal but they need the satellite information to know where to start looking...
Jfetter
I guess my confusion has to do with all the recent articles I’ve read in the newspaper about the automobile rental company (it might be a truck rental company) that was able to track and issue speeding tickets to the renters based on information it received from the vehicle's satellite navigation system. At least that is my understanding from reading the articles. They could have been written by someone who doesn't really understand the technology involved and who inaccurately reported how this occurred. There have been several lawsuits filed over these incidents, which took place in Connecticut.
Though this may be an unpopular opinion, if it were MY car and I loaded it to you and found you drove 90+ MPH the entire time, I would want some reimbursement for extra wear and tear. I think (though not sure) that there was even a clause in the rental agreement (which seems to make it fully legal) stating they did not permit excess speed (didn't he wonder how they could tell?)...
Jfetter
I guess it really shouldn't be surprising that the transmitter is not powerful enough to be picked up by a commercial satellite, after all, the antenna would have to be fairly large and directed up for the most part. I am not sure ANY system uses the satellite to actually communicate bi-directionally with the ground unit. It seems even the high-end equipment used by trucking agencies uses cellular for transmission from the client (vehicle) back to the tracking company and only downloads information from the satellite, never uploads.
It would be interesting to hear from someone with a background in this technology to see if even the high-end systems are completely reliant on only an orbiting satellite...
Jfetter
INKY
