Visitor Agreement.
Pocahontas,
Edmunds.com/Roving Host
I then went back into the restaurant to use the rest-room since I knew we were going to be standing by for a while. As I came out of the restaurant, I noticed another Silver MDX parked in front. I also noticed that my wife was in the drivers seat. She was able to start it? Yes! She said that when I left the car, she put the key in the ignition and left it there for about a minute. She tried it and it started. The car now accepted the key.
I do not know what caused the problem on my 5 day old MDX. I am very nervous though. I will call my dealer tomorrow and post what he says.
Be careful folks. Please post if you had a similar experience.
Later.
Good luck!
Drew/aling
Townhall Community Leader/Vans Conference
William, FWIW, full resolution pictures were available in Photopoint before September.
Drew/aling
Basically - you may have too many keys or a large metal object on your key ring which interferes with the immobilizer signal in the key.
Rail
I HAD a few close ups too, but the file transfer software apparently over wrote them since I had two copies of two pictures. I swear I am not really that technically challenged, but there is nothing like learning something new to make you feel like a complete rookie!
railr, that explains it. Though it's pretty stupid. I think about the fancy Acura keychain that comes with the owner's manual and snicker that it's not to be used with your Acura car key.
Congratulations.
You have just created a new $500 option for Acura dealers!
Looks great.
Am I missing something, or does Acura reference the wrong service procedure in the Service Manual for the VTM fluid change?
For both the VTM differential service AND the automatic transmission service, they reference page 14-138.
I found the VTM-4 procedure on page 15-39
Also, anybody know off hand what size driver this takes? Looks like a 6 point hex driver.(I'm being lazy.)
Found the circuit for keeping the power outlet in the center console on always- can't easily do it without the audio and display being live. I believe I need to get at the splice where all the circuits attach to the accessory relay. (The rear outlet can be "hot-wired" by getting at a relay. If I was travelling on a multi-day/multi-stop trip with an electric cooler, I'd consider this.)
Also, someone asked where the EXTERNAL temperature sensor was located. It is just in front of the radiators on the rear of the front bumper. It is NOT below the windshield.
Ard
As far as your non-start problem and what causes it, I'm glad it wasn't something in need of a fix. I'd freak if my 5-day old car wouldn't start up. Sure am glad I'm learning all this stuff now.
P.S. Yeah, lighthouses are pretty cool, aren't they?
The ML320 won the test when the cases were stacked with the second and third row seats down or out of the way (only the MDX and Montero had the third rows in the test, though the ML320 is available with a very flexible third row, at extra cost). It stacked 36 cases. The MDX was a close second with 34. Only the RX300 (!) had at least 30 (exactly 30).
The MDX finished first when the cases were stacked behind the second row, with the third row (if any) folded down. It fit 20 cases, significantly more than the others (X5 with 13, QX4 with 16, Disco II with 13, RX300 with 13, ML320 with 15, and Montero with 16).
Behind the third row, the MDX fit 5 cases, the Montero 2; don't know how many the ML320 would have fit if it had the third row, probably not many.
What always makes these type of measurements interesting is how they compare to cargo room measured in cubic feet. E.g. the QX4 boasts 85 cubic feet but could only accommodate 27 cases behind the first row. The Montero 96 cubic feet, but only 24 cases (this one seems weird to me).
According to the Acura Installation Instructions, no ball is included. (As someone pointed out, how could they, there are many different sizes.)
What is included is as follows:
A ball mount. (This has a square end for the hitch and a hole for the ball.) A pin and cotter key also.
A square "receiver cover", rubber, which is used when the ball mount is not in.
Also, the heavy-duty tow hook which is removed from the chassis should be returned to you or placed into the storage area. The instructions state; "save the tow hook for the customer." (If I didn't have a hitch, a hock on both the left and right side might be nice...a market for spare tow hitches?)
If you are going to leave in the ball mount, pick up a cheap lock to keep the pin in place. Too easy for somebody to swipe. (I've never locked wheels, tires or pins, but then again I'm a little out of town...)
Someone was asking about horse trailers with an MDX... Few horse trailers are 3500lbs loaded. Heck, two horses plus tack are almost 25-2800. (A horse trailer is not a boat and doesn't qualify for the 4500lb rating- no aerodynamics.) Again, don't wanna be towing near any vehicle's capacity...(But i've seen folks pulling 3 horse trailers with Durangos, albeit at 40 mph)
Ard
Nice job! How did you make it so straight? Did you use a hair-dryer/heat gun to make sure that it sicks well?
We are picking up our MDX (mb touring- no nav in hawaii) tomorrow at the harbor (it's been sitting there for 2 1/2 days due to rough seas) at Kahului, Maui. Our salesman called and said there is a NEW servce bulletin from Acura re: the VTR fluid change. He says the new change interval is every 7500 miles. I don't have the manual so I don't know the differential.
Terrified that the car will have many more than the 22 miles we left it with over a week ago. We flew to Oahu 3x's before we found (through the luck of the original buyer "...not being ready for it.")ours. Would have bought the Lexus 470 except we scanned these forums and found out about the MDX. Good Luck.
Luvsuv: I put the molding on in my garage...it is supposed to be 55 degrees or higher to stick properly; my experience has been that, once it sticks and you press on it, it sticks.
I used a torpedo level on a fairly thick piece of string. I stuck the string to masking tape just beyond the rear bumper/body line. My wife held it with her finger while I pulled the string as tight as I could get it, then put masking tape on the other end of the string, just behind the front wheel well. I took the level off the string (so it would not sag when my wife let go of the rear piece of tape)and put a few pieces of masking tape along the doors (using the string as a guide). I removed the string and stretched a piece of masking tape from the rear to the front, using the guide pieces. I made sure it looked level, then I gently pressed the edge of the masking tape down along the entire side.
Next, measure and cut the pieces (I used a Craftsman tool - name escapes me, but it looks like a pruning shear). Make sure to cut the molding at a 45 degree angle for the front part of both doors, or it will rub when you open the door) Take the tape off the molding about 1 foot at a time, stick the front edge of the molding on (using the masking tape bottom as the guide), bend the rest of the molding back so you can see the tape line and just slowly peel and stick and press. The Prostripe web site has a few tips also (Prostripe.com)
I am sure this is probably more than you wanted to know! I took my time and it took me a little more than 1 hour - the molding only cost $60. A good trim person can do it less than 30 minutes.
1600 miles , no complaints
just drove in about 0.5 inch of fresh snow today
mdx did wonderful. I even tested its limits safely
very sure footed. love this vehicle!
Just when I was thinking dropping my deposit and wait for 6 months. My sales at Sunnyvale called me and said a someone gave up his order and the markup is negotiable. I showed up. The color(Mahogany) is not mine(beige) and the package(navi) is not mine(touring) either. But I still went directly to the price and pointed out for my case Sunnyvale has been dishonest and this will damage their reputation on the net. Surprise! They accepted it. Well, I had to buy $1200 goodies from them(steps, racks, mud guards and wheel locks).
BTW, the sales(Matt) convinced me navi is worth it and I got what I wanted from the touring(rack). He's the nicest sales I've ever met.
It's a great SUV in every way.
I am most certainly not a Yahoo rah-rah, but I can't take scrolling through all these messages, linking to other websites to see photos and trying to remember which section of the MDX board (now on topic V and going strong) that someone posted some useful info.
There is now a club on yahoo. You can reach it from here:
http://clubs.yahoo.com/clubs/acuramdxownersclub
You can receive messages via e-mail, you can search the entire list, you can search for members, you can see who is online, and you can even chat with members. There are even photo albums for those who want to show off their babies....
Anyway, check it out and hopefully we can have a continuous useful discussion.
I guess overpriced options are better than paying over MSRP for nothing. I'd still consider it a rip, especially for jerking you around like that and not getting you the color combo you wanted. Hmmm. Oops. This was supposed to be a post of moral support. Guess I get ticked when car salesmen do this...not that you wouldn't get the same treatment at other valley dealers..
The vehicle is outstanding. The engine and nimbleness is very car-like; the space is certainly not (in a good sense). The wood steering wheel makes the interior look amazingly rich. I am still considering other accessories to prevent other vehicles from rubbing against me. In this regard, does the tow hitch help? Also, are there any metal trimmings I can put in the front? What about running boards or side steps, do they help? I am especially concerned about New Yorkers squeezing into parking spaces and rubbing bumpers.
The dead foot pedal and the driver's seat were a little uncomfortable over the weekend. I hope that I can find better seating positions. The Climate Control takes some getting used to, especially in the back. It was not intuitive to get the right temperature to my 18-month old in the back and my wife and I in the front.
These are minor issues that I am sure that I will resolve.
By the way, if you are having trouble using memory seats with your key fob, here is what I found out. This was not working when I asked the salesman to show me how it works. When the technician came out, he said that the factory settings on the fob are to NOT send the seat command. In order for the fob to send the extra signal to set the seat position (to 1 or 2 corresponding to the number on the fob), you should hold the lock and unlock buttons on your fob for a few seconds. This is NOT in the owner's manual!!
Called Acura Client Services to ask them about the requirement to have coolers installed. They played a little song and dance about how the bulletin that coolers were required was sent out BEFORE any MDX actually shipped. Too bad my dealer knew nothing of it, and the original owner's manual also did not indicate this.
I pointedly told them how they've fixed this situation for others, but they insisted that I work through my dealership's service department to resolve this. They were very polite but kept saying that Acura dealers are now required to install both coolers with the tow hitch (I guess this is why they have this "promotion" to get the steering cooler free, which they would only semi-acknowledge in saying that there has been some "agreements" but I could only resolve that through my dealership). And that this was known before MDX's shipped!
I asked to speak to a field rep but they referred me to my dealership.
Anyway, looks like I'll have to see how this game works. Called my dealership's service department, explained the situation, and they're supposed to do some research and call me back. We'll see.
First visit is Oil change (29.95) plus VTM-4 change ($55.00). Figure $90 out the door.
Claims the VTM-4 is a half hour, and requires "hand filling". It's only 2.9 quarts, how long can that take? Plus 2 new filler/check plug seals.
Turns out it is easier for me to do it one evening (instead of logging in with you folks) than it is to drive the 100 miles for two round trips. I may let them do the first, but I really don't have a valid reason for this...probably let them look at the "hissy brake pedal" and they can replace the bumper trim the other dealer (Solano) trashed when Solano installed the trailer hitch.
Anybody else get quotes on the VTM fluid change?
I asked about any revised schedule, he wasn't aware of any, but would check.
Ard
PS. The "special hitch deal" really requires some work and attitude on the owner's part. Acura and the dealership will not just fold, especially if it looks like you're prepared to spend the $$$ either way.
Sorry to see you leave.
I was so looking forward to you wise input on travel tips in Asia.
Don't write-
Ard
The requirement to change the VTM-4 fluid every 7500 miles is for severe service only (unless the Owner's and Service Manuals have been overridden by a service bulletin--which would certainly be disconcerting.) Both the filler plug and the drain plug are torqued to 35 lbf-ft. No size is indicated (but plug shape is circular not hexagonal), so just go through your tool box until you find the right 12-point socket. As the Service Manual says, be sure to use a new sealing washer.
Some good news: my dealer rep called me today with my VIN! ETA is Saturday, so I should be able to pick up my prepped MDX on Tuesday next week. I've ordered some accessories (discussed in a previous post) from A & H Motors, so I may be able to get them installed the same afternoon.
Also, on the review front, the WSJ had a piece called "Acura SUV: Late to the Party, Ready to Rock" last Friday. Nothing new, but the author closed with "There's no mistaking it for a minivan." So, take that C & D! The MDX is not a m*n*v*n.
Transpower
From the drawing it looked like the drain plug has a hex indentation, indicating I'd need a hex driver, not a socket. I'll check it out when I'm under it.
Congrats on the impending new arrival. Have fun.
Ard
I noticed that Speedvision is airing Motor Trend TV on Wednesday at 7:30pm EST. Does anyone know if this is a re-broadcast of the SUV of the Year show?
My MDX owner's manual originally came with an updated service interval page (self-adhesive update page stuck on top of the original). I can't tell what changed, but obviously there was an update right after the manual was printed but before I took delivery on Oct. 6th. Maybe that reflected an early service bulletin changing "severe condition" replacement to every 7,500 miles, who knows. When I got the manual binder over a week later, it had update pages for the towing coolers.
As far as the MDX looking like a minivan, let's face it, anyone who hears that the MDX is based on a minivan's platform is going to automatically look for any resemblance to a minivan. And the MDX looks a lot less like a minivan than some other SUV's.
Ard, I figured the tow hitch business wouldn't be as simple as Acura doing the right thing the first time. Looks like this will take a while. As it is, I'm not sure how much I'd end up saving buying just the originally (horribly inflated) priced hitch and getting (maybe) coolers added gratis, vs. buying the complete tow package from a discounter and just paying the dealership the labor charges (apparently it's not that simple to buy just the hitch now). Or just saying the hell with it, I don't tow anyway (bike for our baby when he gets older might be a reason, but he won't be old enough for a while as it is).
barenboimo, anything goes in New York. Only way to practically keep people from playing bumper-tag with you is to get some kind of aftermarket brush guard for the nose, and getting not just a tow hitch but the hitch-mounted bike rack for the back (I don't think just the tow hitch itself would be enough of a deterrent). As for the sides, maybe jdford's side molding treatment might help. The running boards and side steps don't stick out far enough to guarantee no dings, though they'll help in some situations.
dagill, hey, congratulations on the brilliant deduction that the MDX is car-like. That must have taken a lot of research, we are very impressed.
I hope your feelings won't be hurt too badly when you have to "smell an MDX's fumes," just because you screwed up and didn't buy the ML430.Transpower, a preliminary congratulations on the impending arrival. As far as the VTM-4 fluid goes, it will be interesting whether or not the current every-30k interval (except for the first one at 7,500) changes.
I guess you have to make a (weak) attempt to make fun of your vehicle's competitors, just because you screwed up and didn't buy the right vehicle for yourself. Hope your feelings won't be too hurt when a "gal" (your terminology, not mine) in an MDX leaves you smelling her fumes.
The M-class is a fine vehicle, don't get me wrong. The message wasn't intended to put down his ML320 (he put down his ML320).
I disagree with you on the MDX not having good resale value, but come back in five years. If there are really so many Southern Cal MDX's sitting on dealer's lots, those dealers wouldn't be getting $2k over MSRP for them. Maybe you could be helpful and name some of those dealers so some of the would-be MDX buyers from Southern Cal can check them out. Thanks.
P.S. I think I remember you now; didn't you have a BMW X5 on order? Great vehicle.
I could get one from Honda-acura world for $390. How hard is the installation? Has anyone done it? Thanks.
MotorWeek #2012
With Host John Davis
PBS Broadcast Window Begins November 25, 2000
Episode Title: 2012/Acura MDX
Roadtest of the 2001 Acura MDX
Roadtest of the 2001 Porsche 911 Turbo
Goss' Garage: Home Garage Sweet Home Garage
Two-Wheelin': New Generation Harley Davidson
MotorNews: 1st Drive: Ford Ranger Edge 4X4
Long Term Roadtest Update: Ford Excursion & Oldsmobile Alero
Most replacement steering wheels are expensive, even if the wood is really plood. $634 seems excessive though, so check with H.A.W or A.H.M.
Drew/aling
1. Dealer insisted on charging sales tax on MSRP+destination+documentation fee. I thought when you lease you only pay sales tax on payments.
2. Dealer insisted on capitalizing all fee and taxes.
3. Luxary tax was calculated on capitalized price means I was paying luxary tax on sales tax and fee like acquisition etc
4. Dealer constantly reminded me that if this deal didnt go through he can sell it for above MSRP no problem.
5. Finance manager was reluctant to go over the lease agreement in detail.
Has anyone else experience this kind of arrogance and greed?
There is no need to give in to the nasty, rude dealers when you can find a reasonable one that perhaps you deal with.
This is my first post. My dad wants tog et my mom a Luxo SUV for Cristmas. we are looking at the ML320, the 3.0i X5, RX300, and of Course the tricked out MDX. My dad is wary of buying the MDX because this is it's first year on the market. But isn;t it true that the MDX is based on the reliable and somewaht proven Honda Ody platform? Has anyone who owns an MDX seen any build quality problems or other issues on there vehicle? I looked at the Lexus, and I thought the interior was of much higher quality than the MDX. Am I right in thinking this? It's not even the Faux woood trim that bothers me... just the leather quality and overall look of plastics in the cabin. I stll like the Acura though... also the Lexus dealer seemed more pretentious... less inviting and more stuffy. Well I'd ove to here your experiences with your new MDX, bad or good. Anyone who has the 6 CD 8 speaker Bose system I'd like to here your opinions on that to.
Brent
We bought the car a week ago but we have no paperwork from the dealer, just FAXes (they keep saying the woman who handles the paperwork is "out today"). The insurance company doesn't seem to know how to handle an out-of-state purchase and insists they need to see a title to insure the car. The bank holds the title since we have a loan -- which we keep explaining, but we can't get anyone from the insurance company with a brain on the phone. The registry won't register the car without proof of insurance. DelRay Acura seems to be clueless when we appeal to them for help.
So ... the car arrives tomorrow but we have no insurance, no registration and no plates. How are we supposed to get it home?
Can anyone explain how this is supposed to work? People must buy cars out of state all the time -- there must be an orderly process to go through.
Given our experience with Del Ray so far, we're really worried about what the car will be like. What if the mileage doesn't match what's on the sales agreement? What if something else is wrong? We didn't want to wait until March to get the MDX from a local dealer but if we'd know how awful this would be, I think we would have waited.
Laurie
1. Sales tax - this differs from state-to-state, but, in general, you're right - tax is usually paid monthly on top of your payment amount, not on the unpaid residual. Of course, if you buy the vehicle at end-of-lease, then you're going to be hit with the additional sales tax. Your DMV should be able to answer this question or maybe a CPA.
taxes. Clever - this allows dealer to bundle everything into hidden calculations so he can charge all kinds of ridiculous fees that might not be disclosed in the final paperwork - they just might result in a higher lease cap cost, on top of which the dealer will get a "rebate" (more commonly called a "kickback") from the leasing company.
3. Luxury tax was calculated on capitalized price
means I was paying luxury tax on sales tax and fee
like acquisition etc. I'm not sure what amount the luxury percentage is applied against but I doubt it's factored on sales tax and garbage fees; again, check the federal government website on this tax.
problem. Then why is he wasting his time with you at a lower price? Simple - the lease he's quoting has MORE PROFIT than $2K over MSRP!
lease agreement in detail. I'll bet! I believe that additional Fed Government disclosure requirements on lease agreements will take effect 1-1-2001 but that won't help you now. Your best bet is to calculate your lease from the acura.com website: Select Acquire, Cost Comparison, Lease Calculator, Your MDX Model, term of lease, # miles per year (12k or 15k), $$ money or trade-in value - and, presto! Reasonable lease numbers from American Honda Finance Corp. Last time I checked, their money factor was .00370 - to get the real interest rate, just multiply a money factor X 2400 - or 8.88% in this case.
If you need some additional help, email me at jeffmust@aol.com.
1. You DO pay sales tax on the whole amount (cap cost), not just the monthly payment amount.
2. Even Worse Department: If you buy the vehicle off for the residual after the lease expires - you get to pay sales tax AGAIN!!!
Now who in their right mind would lease a vehicle in those two states? Why not drive to a different state for a MDX lease deal?
Check out this site for some good tips on leasing and regular purchase deals:
http://www.carbuyingtips.com/lease.htm
JM
Acura has had outstanding reliability across their entire line of vehicles after dumping the SLX and the Vigor. They appear to be on the right track now with improving the value, performance, and resale values of their cars, with the RL possibly being the exception to that trend for resale value. We can only guess about the MDX, but with production on the MDX being low, initial customer feedback being very positive, and the MDX winning almost every luxury SUV comparison, there is some optimism that the MDX will have good resale value. The one characteristic that may adversely affect MDX resale value is that Acura does not have quite the marquee luxury image already associated with BMW, Benz, or Lexus.
By the way, I agree with wmquan. If you see MDX's sitting on dealer lots, why don't you post the names of the dealers in here to help out other prospective MDX buyers?
1. Paid cash , completed paperwork at dealer
2. Took the papers to my insurance agent for stamping with an effective date of next business day
3. Took the papers to DMV and paid taxes and rgn fees. Gor the plates
4. DMV sent the TITLE to my home address 2-3 weeks later
Hope this helps.
I though: "Here is someone who ought to be sticking with the MB or RX if he felt the need to be like his negihbors."
I purchased a 90 Q45 for two reasons: It was an awesome machine, and NOBODY else was driving them (they were all buying LS400s)
I LIKE the fact that the MDX is rare. I like the fact that it will be limited in volume. I DON'T want to drive a vehicle I see all over. It does not make me feel "safe" or conforming to be like other consumers.
I believe that, in part, the "higher resale" percentages and popularity of the ML is due to this human (lemming) desire to be part of the "in" crowd and to conform.
I also think that this human emotion is at the root of why some folks feel the need to insult and belittle others not in their club. (Auto-centric?)
Ard
