A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Acura MDX (pre-2007)
If you dealer only gets a larger number of Base model MDX's they're probably a low volume dealer. Most larger dealers can request any Trim level and any color combination in their allocations and get them. If you don't want to wait longer just because you'd like more equipment, you may want to check out a larger dealer.
MHENDERSON1
The other members on here are correct. Speak with your money. Order your MDX through someone you want to do business with. Most dealers have about the same wait periods. Go through someone that makes the process easy. THe MDX is a great vehicle, you should be able to enjoy owning one without worry about what you'll have to go through to get it. Anyone that's worth purchasing through will invest the time to take you out for a full demonstration, discuss your concerns, keep you updated, and won't mind getting calls and emails from you along the way to check up on things.
Jamie S.
I am wondering if anyone knows of any aftermarket Navigation system that would work with the MDX that is good enough now to be recommended -- or whether I should just wait until it's time to give my present car up and order a new one with Nav. Also, I am told that used MDX's with low miles (mine now has 3,800 miles) have been selling at the auctions consistently for sticker price or over -- if so, I may think about selling my present car outright and if I could get sticker or better and find a new one with Nav maybe that's the way to go.
Any thoughts or suggestions would be appreciated.
A lot of it will depend on the widths of the carseats (the Super Elite is of course quite wide).
The MDX seemed easier for me to manage
than the Sequoia although the Sequoia had more interior room. Decisions.Decisions...
Now that it's about here, we are concerned about what gas to use. I know that Acura recommends premium, but some dealers and (I think) someone on this forum say it runs fine on regular (87 octane). Have any of you had good (or bad) experiences running your MDX on regular?
- Conrad
Older cars with distributers would run best at whatever grade they were tuned up with in the tank, electronic timing should alleviate this problem, at least I hope and think it should.
I switched to regular and have not seen a noticeable difference. I know the savings aren't large, but it's hard to resist .899 and pay 20cents more just for a performance boost that may only be noticeable at a test track.
I measured dozens of seats for width and brought along a tape measure to determine 2nd row width from armrest side to the other armrest side in determining contact points on vehicles I was considering before thinning out the list. Keep in mind, although the muscle and fat on your thighs will conform to armrests, plastic will not. There is no squeezing in or deforming of the carseat to make it fit. The MDX being as wide as it is gives the most amount of latitude for seating.
BTW, there's a service bulletin for your weeping mirrors if you haven't had 'em fixed. Works like a charm! Click here to see it:
http://theworm.home.attbi.com/AcuraMDX/mirrortsb-complete.pdf
I have had rear window wind noise in almost every car I have driven, typically when someone puts the rears down, you have to crack the opposite front. Very common, but still annoying.
I purchased it at Pohanka Acura in Virginia great buying experience.
I mentioned to service at 3,500 that there was bumping noise "thud" occurs from the front end when going over a speed bump. They installed "silencer tubes" to front springs S/B 01-023 this did the Job.
While Waxing (4500 miles)noticed "rubber powder" on the edge of the roof where the front and back door meet. The Back Door Seals, top front corners, door and frame seals are eating each other up. This is on the driver and passanger side. It eat clean thru the frame "D seal". Dealer replaced all four seals and adjusted doors.
At the 7,500 service I noticed this happening again. Dealer keep the vehicle overnight and replaced the frame seal. I have to take it back and complain because the door seal outer, rubber is eroded and black foam center is visible. The dealer put silicon grease on the seals to keep it from eroding.
Has anyone had such a problem? How often do I change the grease on the door seals???????????
It's my first time to post a message here in the town hall.
I would like to know what was the best price anyone got for an MDX with Touring Package and Navigation.
Your inputs are highly appreciated!
My wife and I will have decided to pass since we can't see paying an Acura dealer that amount of money. Plenty of other great SUV choices around....
My wife and I actually feel the same as you. I really like the vehicle. However, I just don't see myself paying full sticker price for it. I also hear that the dealers are very indifferent if not totally arrogant. I feel that if I spend that much money on a vehicle the least I should get is some good service.
I wonder when production is going to catch up with demand? Or is this a marketing "Pull" strategy to inflate prices by deliberately producing less than the market demand?
tidester
SUVs
The fact that a dealer charges more than MSRP or forces an inflated option or two doesn't make the dealer unfair or dishonest. The Additional Dealer Markup would be clearly disclosed on the sticker, as would the options. Readers of this forum or others who do a little research would know the dealer cost of the vehicle and the options.
The last time I bought a new car was '93. The Honda dealer had tacked $1000 onto the sticker of the Civic VX. In just a few minutes he'd dropped that, and we split the difference between sticker and invoice. (The dealer also tried to sell an accessory without disclosing the cost, but promptly removed the item when asked. They've now been bought out by another dealer; looks like an improvement).
Dishonest would be not identifying the cost up front. So long as that's done, we're free to accept the offer, counter, or walk away. I'm just not willing to call a dealer dishonest for trying to take advantage of a hot market. Whether or not I buy from that dealer on the dealer's terms is an entirely different matter. I won't even say that I would never pay sticker, or above., for a vehicle, though right now I don't see that happening.
I actually recommended a dealer in the Philadelphia area to another person in the meet the members forum...because they were charging MSRP and no hassle. I did however point out that this dealer in particular were forcing buyers to pay for 2 options at an inflated price, not dishonest.
That being said, I don't find car salesman to be the most reputable in the world, that is why I do my own research, know what the prices of options, invoice, MSRP, TSB's, recalls and vehicle information, that is why I am here.
Volvo XC90
I am pretty sure the MDX is still the right choice, but it is making me go back to the drawing board for a serious look.
One thing keeping me on track with my original purchase is that the Pilot will be bigger, one of the things about the MDX I like is the driving size of it. 3 inches wider and 5-7 inches longer is more than I am looking for.
- HID lights
- Vehicle Stability Control (which CL and TL has, I think?)
Then, it would still be first on my list. But then again, that new Volvo XC90 is really nice. If only it would get priced right and can be bought via Ford's X-Plan, I'd seriously look into it also.
I already like the MDX, so add those items, and it can only get better.
Right now I'm really re-evaluating and I'm leaning more towards not getting it at all anymore. I know it's a free market out there and if there is a buyer there will be a seller or vice versa. I just choose to use my power as a consumer and not get it. Drewsrx & Sbcooke are right. Volvo XC90 and Honda Pilots are coming up. There's even a new Lexus in the horizon coming up Jan. next year. So the market SUV market is going to be more competitive.
Get it next year, perhaps? When price is a little more flexible.
It's only estimated to get 17 in the city so 14-17 is not surprising. I think your experience is normal - typical mileage in the city is a bit less than the claimed 17. Highway is near or at the claimed 23. Overall, I think that's not bad for a mid-size SUV. Many competitors are worse.
The resale should still be good now, and obviously that's an important factor for this to make sense.
I think it's the older MDX's that will suffer once the Pilot is released, not the 2003/2004 MDX's. They will probably be upgraded to justify their price premium.
Also, it would be a lot more practical for weekend trips to the beach and around town. Less worries about wear and tear.
So my hopes are to get a vehicle that better fits my needs and maybe save $3,000 to $5,000.
I might not be typical of current MDX owners, but I bet there are plenty of people who want the quality, safety, and performance offered by Honda, but aren't interested in the luxury upgrades of an MDX.
Bottom line, I would have bought the Honda in the first place if it was offered in October, 2000.
