Model A Fords
Guess I can't shake the old car bug!
Answered an ad yesterday for a Model A "Tudor".
Had one a long time ago and remember it fondly.
I'll probably go look at it next week. The owner
said it had been "restored", runs and looks good,
no rust etc. He wants 5900.00.
Have I lost my mind?
I plan to only lift the car until the front wheels are just off the ground. With the small amount of suspension travel in the "A" it won't have far to drop.
I will also block the rear wheels so it can't roll.
Does your patent also cover only cutting enough of the head to cut the one remaning stud? ;-)
Mark
I'd go for it, but then I've always been a little partial to cars of that era, not that I was even alive then.
An old guy around the corner from me has an old Model A pickup in his garage. Looks original, as in what a 70 year old car would look like (not at all restored. As far as I know it doesn't run, since I haven't seen it run in 3 years.
That street reminds me of a new topic to start, and something to add to sports wagons. Might be a long night.
I would be embarassed to try to list the cars I've owned in my 52 years. I doubt if anybody would even believe me.
A Model A is a very primitive car and almost impossible to drive on the freeway. Anything over 50MPH is really pushing.
Ford was one of the last to do away with mechinical brakes.
They often didn't stop back in the old days...that's why there was such a slaughter on the roads, compared to now, where the fatalities per mile driven is so much lower. Of course, there are still over 40,000 killed every year in the US and ten times that mangled in one way or another.
So I wouldn't say it's exactly SAFE out there, even with ABS, air bags and all the rest.
It's funny what "restored" means to different people! It had been painted with a brush, the fenders were cracked, had the wrong wheels, etc.
Still, it ran well and would have been a lot of fun I guess...
The basics were intact. I just think that for 3000.00 more I could find one that was finished.
Nice guy selling it and I'm sure it'll sell quickly.
$3,000 sounds about right for that car if it's a good runner...any running, non-rusted, complete and un-botched Model A should be worth about that.
These cars actually look good when they are a bit shabby, I think.
Seriously, it wasn't bad for a sixty year old car. Lots of painted over bondo that scared me/
I agree with you on the shabbiness issue. A perfectly restored one looks better than it did when it left the factory. My idea would be about a condition 3 car.
And I wouldn't micky mouse the brakes either. As you said, enough modifications and it's no longer a Model A.
I'll take a good daily driver. If a truck throws a rock that chips the psint, I won't care.
Oh...a funny thing happened while I was looking at that Model A. We had shut off the engine and were standing about twenty feet away when it started rolling down his driveway!
We both reacted at the same time and ran over to the car. I grabbed a door pillar and held on while he jumped in and re-applied the emergency brake!
Isn't that a typical Model A?
Like a scene from The Three Stooges..!
As far as cars go (cars in general are expensive)
would a Model A be a fairly good car to use to learn to work on cars. Are they (or their parts) hard to find? I came up with the crazy idea of buying an old VW Bug (ugly car IMHO, but simple and cheap), and some service manuals, taking the thing apart and reassembling it, just to learn how it works. Doing that to an A Model sounds much more appealing though. How much would a restorable one cost, and how much on parts?
Can you still buy the skinny tires? (Or is that the T Model I'm thinking of?)
Guess not.
Thanks for that advice Shifty.
Probably not "worth" restoring (you can find a restored mail truck for around $20K), but a rare item of historical interest. I bet not more than a few dozen survive.
I have NO problem with upgrading Model As for safety and reliability. Good for him.
That is a very worthwhile (and undetectable) modification!
I'm not sure what the origianl ratios were but they were stump pulling low.
The head on my '30 Tudor is cracked. I have a new head, but I can't get the old one off.
All the nuts are off the studs, but it won't budge.
I filled the cylinders with oil and cranked the engine by hand. Oil came out all around the
head gasket, but it still won't budge. I put the nuts back on, but with 1/4 inch clearance
and tried starting the engine. There isn't enough compression with the leaking head
gasket to start. Now I have a chain fall holding the front of the car in the air attached to
the head. It's been hanging there for two weeks, with periodic jumping on the front
bumper. It *STILL* won't budge!
Any ideas?
Mark
Maybe you could tap the studs and use lubricant or even some heat and just be patient. Or perhaps you could try pulling or loosening the studs with a double-nut process. But they may break if you twist them too hard.
It's just an ugly brute force job, but sometimes lots of tapping and banging will do it. DON'T try to pry between the head and block (but you knew that!)
I like stock stuff. In another 50 years, the restored Model A will be worth a lot more than the butchered version. And these days, there are enough fiberglass bodies and custom frames out there that nobody should have to butcher an original Model A. Build a kit car instead.
Bolt-in mods are different, particularly if you keep the original parts.
But things like juice brakes aren't just bolt in, if I'm not mistaken. Model A's are marginal for daily drivers anyway, and most people that have them already have a car for transportation. But if you want a daily driver, why not pick up one of the Shay replicas and drive that? I see lots of those for sale.
Also, the mechanical brakes are okay if you keep them in good condition and adjust them frequently. One of the places that I find needs attention but doesn't get it is to replace the plates inside the backing plate that the rollers on the shoes rolls outward on when the rod pushes down (when you push the brake pedal). These wear so the shoes don't travel as far as they should. I replaced mine and they make a world of difference. ...but it still wouldn't hurt to practice grabbing the emergency break quickly from time to time to stay "in shape." And stay out of rush hour traffic!
Oh, I don't agree with you on value, though. I think the rodded or customized Model As will be worth more and more and the originals less and less. There are a tremendous number of Model As still on the road (some estimates say 1/2 million or more), and their prices seem to be dropping again, not appreciating. Rods often have a lot of money put into them and so should be worth more than a stock Model A. You can find a very nice Model A these days for $7,500, but a decent rod will cost you 2 or 3 times that, and a show rod of course even more.
People have been modifying Model As since the day they first made them. Old catalogs abounded with accessories and mechanical add-ons and the pracitice still thrives. I think modification is part of the tradition of the Model A.
I don't mean to say these guys that do the mods aren't doing "good" work. Some are truly works of art. But the pallet seems like it would be a lot more open to innovation with using new parts from square one, rather than trying to accomodate a heavy, powerful engine in a Model A frame through extensive modification.
There's also a big difference between using "original speed equipment" available in the 30's, like counterbalanced cranks, high compression heads and dual carbs, or even complete Model C engines and the modern speed equipment. And though technically not even a true "original speed equipment" modification, I once saw a 1929 A touring car with a mod-30's 60-horse flathead ford V-8 in it. You couldn't tell from the outside at all.
Sure, hot rods are worth a lot because it truly IS more expensive to hot rod a Model A than restore one (I used to hear the opposite argument in the 70's - it never was true and it never will be true). But you can always put far more money into any "upgrade" than you can ever hope to get out of it.
Get a coil of clothsline rope at the hardware store. get 1 to bdc or thereabouts. stuff as much clothesline into 1 & 4 as you can through the plug hole and turn the engine. the clothsline will push up on the ends of the head evenly. Same idea as the oil but it won't run out.
I have to say that the tranny wasn't the reason the car ultimately fell off the road. After several years of reliable if crude motoring I sold it to a friend who promptly blew the head gasket.
Due to other problems and priorities it sat from May until November. I've worked on it a bit more, but it isn't off yet.
I removed almost all the studs. One of the studs that went through the water neck broke about 1/2" above the head surface. One other in the middle couldn't be reached by a stud puller. I'm going to weld a nut on it, then it should come out.
Two others are the rear two. They are very close to the dash panel, and I don't want to damage the sheet metal.
Next is to lift the car by the head and heat around the water neck to try and get the one partial stud to let go. I have an oxy-acetelyne torch, so I can get it very hot. I promise not to use the cutting torch! I should get time to do that this weekend.
Mark
I've been where you are and came up with a method of head removal I patented. Now every time someone uses a rip saw to cut a head off they have to pay me a nickel.
The head is scrap already. I'm removing it because my brother didn't drain the water last winter and there is a long crack in the head. I already have a new head, I just need to get this one off!
Mark
