Visitor Agreement.
http://makeashorterlink.com/?F23B318A1
Don't know if it's specific to a trim level, or is standard or a dealer acce$$ory.
If it's a front, quite a few folks have purchased the FormFit Air Deflector. I know hondacuraworld.com sells them and so do a number of other retailers. FormFit's fans think it's more attractive than the Acura OEM unit; slightly lower profile, a bit more angular, and without the green look to it. Folks have installed it on their own without any problems.
Honda has said in an official announcement that XM Radio is also available...
Other changes that have leaked out through the magazines (and will be confirmed ONLY when the factory feels all 02s are gone...) are a power boost to 260Hp, addition of VSC (electronic stability) "enhanced" transmission, and drive-by-wire throttle. These are all things that should make the 03s even more reliable/desirable than the 02s BUT the competitive products from Volvo, Volkswagen, BMW and others should make it hard for Acura to move prices higher...
Bob
I'm assuming you are looking for it in the SUVs topic list and not just trying to find it "the old way"? Getting Started in Town Hall
Try this link and see if it helps (especially if you have the topic list bookmarked in your favorites):
/direct/view/.ee92034
Hope this helps!
Steve
Steve
(shouldn't you be watching the UofM/UofM game instead of hanging out here anyway? ;-))
Steve
Wilson
Trust me I know!
Real Hid kits start at around $500 and can be as much as a $800
They have a ballast with an HID bulb to create the arc for the light it produces
There will be an estimate of a 3-4 month waiting list for the 2003 MDX
The MDX has tied first with the BMX X3 in an all around mid-sized luxury SUV category and it $20,000 less!!
Wilson
eautoworks.com
autotoys.com
sigmaautomotive.com
autodynamic.com
All vary in price depending on manufacturer and kelvin rating
Hope this helps!
Gray Area What You Need to Know About Canadian Cars in the U.S.
Steve
The recent problem with the water pump (requiring its replacement as well as replacement of the timing belt) would EASILY be several thousand dollars out of pocket!
The Acura transmissions have logged a small but significant number of claims too (far more in the CL/TL lines) and that could be another KILO-sized chunk of cash...
Factor in all the things that could go wrong in four years and it seems clear to me that Acura really, really does not any cross boarder sales--
Looking out further, I suspect that even AFTER the warranty is expired you will see substantial reluctance on the part of dealers to give you a fair price on trade for an MDX that was originally sold in MapleLeafLand. The logical reasons would be that a) it original DID cost less b) it may never have benefited from any factroy service/TSBs c) they do come with a Canadian set of options BUT don't forget that dealers work on emotions and they would try to blame/shame you for the 'shady dealings' of having s gray market vehicle (even though it is 99% the same as those destined for the USA...)
Many of the complaints are probably people seeing the aftermarket kits, poor aiming, etc. A lot of kits use a vehicle's existing reflector housing that was never designed for HID's in the first place. Not to mention that well-executed HID's on an SUV need an auto-leveling feature. It's no surprise that many of those installations will cause complaints.
Though it's quite true that some folks really want HID's for the "cool" factor rather than the safety reasons. That's one of the things feeding the aftermarket kits and bulbs, some of which are really poor.
http://makeashorterlink.com/?K559111C1
"Of 1 million vehicles sold in the U.S. with those transmissions ... Honda has replaced the transmissions in about 16,000, or 1.6%."
"The five-speed models typically were damaged by premature wear of the third-gear clutch pack. As the clutch friction material abraded, it scattered bits inside the transmission case, clogging fluid lines and causing erratic shifting."
Be interesting to see if Honda learned from Toyota's mishandling of their nightmare.
At this point, it is unclear from the comments from the Honda spokesperson about whether the current MDX transmission is affected. Someone in another forum called the Acura client services number and was told that the current (2002, as well as the 2001) MDX does not have the same issues because there are differences in its design. It's hard to say if that is true, because people have been told some strange things at the 800-number. I guess more information will eventually come out.
While there have been some reports of MDX transmission failures or at least issues, there don't seem to be as many as the 1.6% number would indicate. Though Internet experiences provide poor statistical samples. For now, being on the pessimistic side, I'd presume that the MDX is affected by these issues.
Also MDX has a different transmission than the ones mentioned in the article.
And yes, they probably included many fixes in the new transmission (and all new transmissions) so they can get closer to 100% success rate.
They at least are on the ball with having answers ready to what they call independent internet sources making data look the way they want it to, not a direct quote but the overall gist.
And anybody that tells you that a 1.6% failure rate (or probably higher) on a million units of relatively new hardware is insignificant must work for the marketing department - they sure never took a statistics class!
1.6% catastrophic transmission failure for all manufacturers? Or do they really mean 1.6% transmission problems of any kind (not necessarily catastrophic)? We are talking about 1.6% transmission problem so significant that it requires replacement.
The Honda spokesperson in the same article is said to say that the 1.6% exceeds Honda's tolerance. That enough says how bad it is. The number of failures has surprised Honda and they were backlogged for parts to fix the issue. That is NOT a good success rate, especially for a Honda/Acura.
Sounds like spin to me.
"Also MDX has a different transmission than the ones mentioned in the article."
Sure it's got to have some differences. But how different is it? The two Honda-admitted problematic transmissions are significantly different, yet both suffer from issues. The real question is, are the same design flaws in the MDX's "different" transmission?
"New model with a new tranny = Potentially new problems" But the '02 tranny's already got a problem! I'll bet you money it has the same tranny as '02 Odyssey, which is on the problem list. They may be tuned differently, but mechanically they are the same. Same platform, same engine, a different transmission? Come on. Even the v6 Accord and old Ody shared transmissions.
Will the 260hp be matched by torque too?
Steve
Unless the Pilot already has a redesign?
Anyone know what mileage usually the transmission decides to go on that vacation?
However I am not sure I am going to take 1 article as the final word. It is an interesting piece and since Acura acknowlegdes it, it lends credence to it. '02 vs. '03 I am not going to lose sleep over it...at least it isn't a ford, which might have something like 75% of transmissions fail. :0
Spencer
