A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Acura MDX (pre-2007)
I don't think the temp light has anything to do with concealing a problem. I believe there is a "check engine" light in the '02...does the '03 have one? Maybe the '02 has some hidden engine problem?
Seriously though the temp light is probably for towing and realistically the MDX is not the best tow vehicle. The typical profile of someone who tows with the MDX is probably the 1 or 2 timer on vacation or something. Less likely to pay attention to loads, tongue weight, etc. and overload the truck. The light to me seems like a good feature.
Anyways, I very much like the '03. The ride is great compared to the larger SUV. But it's still different than my Honda Accord ride thought.
Dealers do seem to be having an easy time getting the color and style(prem vs touring) available which tells me something.
Plus, I haven't seen that many MDXs driving around my area with temp tags so maybe sales aren't as high as before.
Thanks for the feedback. I suspected the fuel probably wouldn't make much difference in normal driving, but your experience would confirm that. I do agree though that for long trips it definitely makes sense to give it the good stuff.
I called quite a few places and I can only get MSRP at best. Some still even gouge at $2000-$3000 above MSRP with and w/o DIO.
Well if you can hold off long enough eventually the market will dicate below MSRP (not sure when) but the GMs, Fords, Chryslers are feeling the pinch of lesser interest from autobuyers.
I did hear that Navi and DVD is a big hit with some buyers so some are waiting for those to arrive. I just got the Touring one and I am very happy with it.
I was offered a 6 year/100,000 mile/$100 deductible warranty for my '01 MDX with 39,000 miles on it for less at the dealer than from Warranty direct, so that's the way I'll go. I need to see the paperwork, but the salesman told me it covers everything except normal wear and tear.
what did you pay?
INKY
http://acuradriver.safeshopper.com/10/cat10.htm?345
and State?
We get lots of use in carrying 4 - 5 kids friends and the 3rd row was one of the primary reasons we went with the MDX and have never regretted it given that it was on our short list of available SUVs in 2001 when we bought ours.
But as they say, ya really gotta try it yourself.
But if you notch back the second row too much then the third row is for storage only.
Will4271: I keep the driver side backrest in the full up position when the third row seat is in use. My small passenger side second row back rest, the part that moves to give access to the third row, is more vertical, when in the full up position, than the larger driver side back rest. I usually recline the small side to match the large side (one notch).
Comment: Rear seat passengers (both rows) like the ability to recline the seats, especially on long rides.
Also does anyone know where i can get the clear film headlight protectors?
It is probably something simple. At worst they just have to replace the thermometer? Keep us posted.
you shouldn't. I do appreciate the price infomation.
I think you made a good decision. I have looked at XC90 recently and will stick to buying a MDX.
Britax probably makes the best convertible and forward-facing seats out there. Expensive but worth it IMHO. They uses features like EPS foam (same as in bike helmets) to protect the back and sides of the child's head with their convertible seats. There is a LATCH version of the ubiquitous Roundabout now available.
The new Britax Marathon, which is sold at Babies'R'Us, is essentially a big Roundabout that goes to 65 lbs instead of 40 lbs (though a child is more likely to outgrow it in height rather than weight). Beware that mounting it rear-facing will take up more room than a Roundabout, though. The Marathon also supports LATCH, but since LATCH has a weight limit, Britax recommends belt installation past 48 lbs. Not Britax's fault, just that LATCH came out before these newer seats that permit 5-point harnesses to well beyond 40 lbs.
See NHTSA's FAQ on LATCH
VEHICLE-RELATED QUESTIONS:
5Q. Why aren't LATCH lower anchors provided for the rear center seat?
A. Two pairs of LATCH lower anchors are required in the back seat of vehicles manufactured after September 1, 2002, and those anchors are required to be a specified distance apart for safety protection in a crash. Because of this required spacing between the lower anchorages, most vehicles do not have a rear seat that is wide enough to accommodate anchorages in the center seating position and in an adjacent outboard position. While lower anchorages are typically installed at outboard seating positions, most vehicles that have a center rear seating position without lower anchors also provide a top tether for additional safety benefit.
6Q. Can I use the two inboard lower anchors (of the outboard LATCH seating positions) to install my child seat in the rear center seating position?
A. No, unless both the child restraint manufacturer's instructions and the vehicle owner's manual specifically state that this is acceptable. A child restraint can be installed using the rear-center seat belt and, if forward-facing, the top tether anchor.
There was an article where the chef engineer at Honda (Paluch) said it was okay to use the inner LATCH anchors, though if someone plans to do this they should contact Acura client services to verify, as well as their seat manufacturer.
Doing this may prevent an outboard LATCH attachment, depending on the nature of the clips.
Of course, this is not empirical evidence one way or another. There is NO test for roof crush resistance out there.
Acura claims there is some strengthening but they don't talk about it much.
I would think the XC90's roll cage is significantly stronger, but that's just my opinion. It could well be the strongest on the market, with the M-class in second place.
It is an individual thing and therefore what others say may not apply to you. The longest I have been in my MDX driver's seat is six hours (non-stop). No complaints. However, I find the seat back for the driver does not go vertical enough and the lumbar adjustment ineffective. Keep in mind, having lots of wiggle room in the MDX helps a lot during long rides. I'm wider than average and being able to shift my position significantly may be the reason I find the MDX seats quite comfortable.
I have yet to get a comfort complaint from anyone in the middle row either (also six hours non-stop). But I have received comments of how comfortable it was. So far, high schoolers that have used the third row have not complained either, but they were only back there for short rides
Anyway, I think the seats are decent, and I liked the seat warmer during a few long drives.
