Acura MDX (pre-2007)
i have recorded over 300 miles in past 3 days (it's snowy here!). Good experience. Good performance and powerful engine. smooth handling. love its third row seat. excellent work from acura! (i have compared it to other SUVs such as BMX X5, RX 300, ML 320 etc). also like silver/quartz color.
one simple safety feature i think acura should add is the automatical door locks after the speed reaches 10 or 15 MPH.
Yes, Northeast Acura is on Rt 9 in Latham.
Am buying a new 2003 MDX-Tour+Nav - Sage/Quartz...on order....to arrive in 1-2 months...
my 2 cents on my path to buying the MDX
1) BMW = a bit pricey after all the options to equate to the MDX
2) MB 320ML = too boxy + not much room + a bit rough while on city streets
3) Volvo XC90 = a bit pricey as well...+ 2nd row middle seat = not very comfy & seats high up + 3rd row = quite tight = I think the MDX is a bit roomier 3rd row
The Sage = excellent color
Quartz interior color = similar to our current Honda Accord interior = greyish/silver color leather interior.
Thanks for all your inputs & info = excellent message board
Also, does MDX have thicker glass windows than the comparable Pilot?
Thanks for any input specifically or in general on cabin quietness.
I don't know how it compares to the Pilot, however. And I'm not sure what the net effect is on the MDX. Hondas/Acuras tend to let in somewhat more road noise than, say, Toyota/Lexuses). But it's definitely improved over the first year.
Any comments on Synthetic Oil vs Conventional(Honda). I am planning to change it every 6000km as per the owner's manual.
Acura had a service information bulletin nearly a year ago that showed a corrected picture for the owner's manual. It stated that 5W-30 is the correct viscosity for 2002 MDX engines.
I called Acura they sent a FAX with the information.
It is interesting to note that the nearly identical engine in the Honda Pilot calls for 5W-20
I checked with three different Acura dealers and received three different answers to the question you asked, then I called Acura and got the fax (no pun intended).
The quote below is from the March 2002 S/N:
"Owner's Manual Fix:'02 MDX Oil Specs
Owner's manual: The oil specification on pages 261, 262, and the rear cover page are wrong. The correct oil for the '02 MDX is 5W-30 not 5W-20. The chart on page 262 should look like this:"
I can't reproduce the chart here, but it shows 5W-30 preferred for all ambient temperatures, with 10W-30 okay for temperatures above 20 degrees F.
"For a complete and accurate oil recommendation chart, see the January '02 issue of S/N."
5w20 is thin stuff. Do not think for a moment the pilot has a different engine that thrives on 5w20. For best world of economy and wear protection I like Mobil 0w30. I use 5w20 in my 03 Accord since it says so. My 02 MDX has been using 5w20 Amsoil soon to be replaced by Mobil 0w30 synthetic.
INKY
Viscosity is NOT, NOT, NOT a measure of "wear protection".
Viscosity is ONLY, ONLY, ONLY a measure of "resistance to flow"!
Given that MOST MECHANICAL WEAR occurs on INITIAL START UP, as the oil is pumped back onto surfaces that is has drained off, REDUCED WEAR CAN RESULT FROM THE INCREASED PUMPABILTY OF LOWER VISCOSITY OILS! In fact, the "ideal lubricant" would have extremely LOW viscosity, so that it would have near zero resistance to flow.
The INGREDIENTS in MODERN motor oils (both mineral based & synthetic) are what protect against both mechanical wear and 'chemical wear'/corrosion...
Here's a link that covers some of this:
http://www.fammllc.com/htmlpub/PDF%20Files/LUBE_Bulletin12.pdf
You can find TONS of info from Amsoil dealers on the web that also back this up...
I've seen posts elsewhere claiming excellent snow driving in that awful snowstorm that hit the Carolinas / Virginias / etc.
comments from others?
thx.
But again, I only had my MDX since Oct. 31.
I have no problem with the front as of yet but the rear is hard to gauge. But like any vehicle, I will learn the size as I drive it more.
The vehicle drives like an expensive sedan but only higher but of course, you can not make abrupt turns.
Does anyone know if the Acura DVD Entertainment system can read a DVD-R ?
I would like to know if I should start converting all our VHS tapes onto DVD-R so that we can watch them on the road.
To be technically correct, I am asking if the Acura system can play a "DVD Video" that was written on a "DVD-R" disk.
Nearly all consumer home DVD players, $79 and up, support this. But considering the Acura audio system doesn't read MP3, I'll ask...
INKY
For the 2002 MDX keep in mind there is an error in the owner's manual with respect to oil viscosity. See Acura ServiceNews for March 2002 for corrected owner's manual picture. Preferred viscosity is 5W-30, not 5W-20.
I have talked to a few technicians and they are recommending that I should wait before switching the oil to Syn as the vehicle needs at least 20000km to properly breakin. Now as I knew, it was only first 1000km for breakin and then it's good.
Also, is it me or am I just seeing things. Is there more legroom in the 2002 than the 2003 (between a 02 base and an 03 base, or a Touring and a base)? When I drove a 2002 earlier in the year, it seems I had more driver side legroom than I have in my 2003.
I use "swiffer sweeps" on the dashboard and plastic areas to clean them up. For the leather I bought a container of ArmorAll Leather wipes. My preferred wax for my cars is Meguiars Wax/Cleaner.
After three test drives of each, the above is almost true. The Murano is definitely more fun to drive, smoother and quieter (the wind noise of MDX at > 60MPH is still quite a bit). Both engines are powerful (the 260hp vs. 245hp/~500 pound weight difference) although Murano is more responsive and smooth (CVT cut in here) at moving speed and MDX is stronger at low RPM. Due to the adjustable pedals and a much better headrest, I feel much more comfortable in Murano's driver seat. The Murano's second row seat is also better, IMO, especially the middle one (the one in MDX is so hard to sit on).
On the value side, with a price tag difference of ~$7000 (MDX Touring Nav. based on what we paid, Murano AWD fully loaded Nav based on what is offered by Nissan dealer, $400 over invoice), the MDX still lacks: xenon headlight, head airbags, adjustable pedals, tire monitoring system, emergency braking assist, UV tinted windshield and front window, active driver headrest, and small things like one touch sunroof, auto up/down front passenger window, retained accessory power, window down from keyfob, etc. Including MDX's intangibles of luxury name, slightly beter warranty, proven reliability vs. Murano's first year model, I still think Murano is a better value.
Sound like I should have purchased Murano. Well, if not for that stupid small reargate window and wide D-pillar that creates huge blind spot. Even the internet sales manager of one Nissan dealer thinks Nissan had over-done it. I think I can get used to that. But my wife just can't accept that.
I fell great about the MDX purchase (this thing finally settled). It is a great overall package. I actually used the MDX, as a feature benchmark to dismiss honda Pilot, as a performance benchmark to dismiss RX300, as a value benchmark to dismiss overvalued offerings from Volvo and BMW. Only the Murano have come close nearly beating it. I think Acura should improve the interiors and add some of the things that a luxury vehicle should have, even that means increasing the price. I will definitely own it for at least 4 years. Maybe my next vehicle will be Murano-like, great value, yet a bit more fun to drive.
Don't forget that Nissan never wanted to use Murano to compete with MDX because they are not in the same class ! The infiniti FX45 will do this job later in 2003.
I can not believe you said that:
- The Murano is smoother and quieter
- The Murano second row offers more leg room
- The MDX wind noise is quite a bit ! Frankly, I drive 03 MDX everyday at 75 MPH on the highway and I can tell you that the wind noise is negligeable.
You said you decided to buy the MDX because "Sound like I should have purchased Murano. Well, if not for that stupid small reargate window and wide D-pillar that creates huge blind spot. Even the internet sales manager of one Nissan dealer thinks Nissan had over-done it. I think I can get used to that. But my wife just can't accept that.". Frankly, when you buy a car in this range ($35K-$42K), well I don't think that "small things" can influence much your decision.
Regards
The MDX is not unattractive, but neither is it a looker in the vein of an X5. It is BIG and looks BIG, especially WIDE.
And mike_platini, I respectfully disagree that small things don't matter. What's small for one man may be huge for another (alright, no jokes, OK?
