Acura MDX (pre-2007)
Overall the MDX is great in the snow. No problem getting through, stopping and handling.
On a side note, some snow got stuck in the passenger side right rim, when I got up on the highway I had a really bad vibration. I had to stop and knock the snow out with my ice scraper to get rid of it.
When I asked for clarification he said he wasn't sure but didn't think it would have detailed street info for medium sized cities in N.California/S.Oregon where I live. He also thought it would only have major highways in rural areas.
Does anyone have any experience with this? I have used a Lexus' navi system extensively and have not found this limitation
The NAV system owner's manual has a list of cities that have extensive coverage and the system for the 2003 models is supposed to have a lot more data. Suggest you ask the dealer to fax you the several pages that show the major metro areas covered by the 2003 system.
I will check with the dealer. I am wondering why he didn't offer to let me see that information when I was there. We talked about my concerns quite a bit. And if what you say is true, it sounds like the Acura NAV is not going to work for me. I know the Lexus covers my area and all the rural areas I usually travel in, so that may be the better option.
Regardless, I'll make the point that if I'm going to be in a roll over accident, I'd much rather be in a modern SUV (choice however would be a Volvo XC90) than any ragtop/convertible.
No word on injuries. Not sure if I agree about the passenger compartment. The roof around the third row is collapsed down to the headrests. The roof above the front passenger is collapsed to about the top of one's head.
Premium per year = full price
Mid grade per year ($0.1 less/gallon) = $71 in savings
Regular grade per year ($0.2 less/gallon) = $142 in savings
Over 10 years if you own the car that long is possibly up to $1400. Not all that much to have the engine perform better (perhaps only slightly), to avoid any possible damage from misfiring due to wrong octane, etc.
This has been discussed before at length...If you are getting into purchasing a MDX (also a $40K vehicle)...you need to be prepared to spend $100-$150 more per year on gas. To me it doesn't seem like that much money to preserve the vehicle and maintain optimum performance. It is good for people to be aware of this residual cost when purchasing a vehicle...however I suggest get your running boards and other accessories from hondacuraworld and save yourself $500-1000 on the purchase price, that should cover the costs. Funny how people will pay $500 too much for running boards/sidesteps/etc. but quible over this cost.
I also maintain that if you are that serious about saving money, don't waste it on dealer installed accessories. The only (MDX) accessory I would consider getting at a dealer would be the DVD player. Check out Hondacuraworld. I added running boards myself, took about 3 hours. I plan on doing the towing package this year too. The instructions seem fairly straight forward.
Another avenue to save money is to have a honda dealership perform your regular maintenance. Over the life of the car, that can add up.
I just wouldn't sacrifice performance and risk possible problems running on regular for the overall costs. Fouling a plug could cost you the same as the cost of premium.
So...good luck with your MDX, don't take it as "snippy". I simply disagree with you.
Of course, these numbers are based on percentage of MSRP rather than percentage of selling price. So a vehicle with a heavily-discounted MSRP and a lower resale percentage may actually be a better deal in terms of resale.
Rather than spin like crazy going through snow drifts and where the plows came through, I used the VTM Lock. I found that by keeping the gas even and not flooring it, the system pulled slowly and confidently. Flooring it didn't add much value and as wheel spin increased the system gives less power to the rear and made it harder to get through.
Still, it'd be nice if the next-gen MDX goes to a permanent AWD split set-up, where the rears always get some level of power (e.g. around 50%). That would provide even better snow performance.
The Michelin Cross-Terrain SUV tires also help a lot here.
Yeah, I doubt if Acura will do anything about the clunky gated shifter until the next-gen, or maybe if they come out with an S-Type.
If the rears got power all the time during city driving, I think Acura would have to basically redesign the AWD system. The current propellor shaft + rear electronic clutch packs (not a true differential) are not "beefy" enough to handle continuous power delivery.
WE just had a big snow storm here in new England, I engaged my VTM lock system for the frist time today, it works great, wish I can use it all the time. Got out of my un-plow driveway with over 2 ft of snow with very little effort and went thru some un-plow streets with 1.5 ft to 2.5 ft of snow. Although when it was in AWD mode, the MDX always slips before the VTM system engages. Another problem I notice was when snow and ice get trap in the alloy wheels of the MDX, it makes a lot of noise. Did not have that problem with my other 2 four by fours.
When you mean that it's in all-wheel-drive mode, do you mean that all 4 wheels are driving the vehicle? This is what I perceive AWD drive to be, like in a Subaru.
From what I gather, the 2 front wheels drive the MDX but when the VTM-4 senses slip, then the rear wheels activate. Now, if the speed is above 18mph and the VTM-4 senses slip, do the rear wheels activate and stay in AWD mode?
I've seen the generic "AWD" usage applied to even vehicles that don't normally power the rears. I've even seen the term "permanent" or "full-time" applied when the rears are not actually driving. The idea is that even if the rears aren't getting powered, the vehicle is still ready to engage the rears at any time (as opposed to "part-time AWD" where one has to manually engage a mode).
VTM-4 has three modes:
1) Under normal cruising only the fronts are powered, with nothing going to the rear. When slippage is detected, some power is routed to the rear, and each rear wheel can get varying amounts of power (no locking between the two rears).
2) When accelerating "under certain conditions," VTM-4 will "proactively" send some level of power to the rears. Acura is pretty vague on exactly how much is sent.
3) When the "Lock" mode is engaged at speeds up to 18mph, in Reverse, First, and Second gear, power is sent to the rears and those wheels are locked together. This of course only for slippery surfaces. Acura says up to 50% goes to the rear, but the percentage decreases as the vehicle goes up to 18mph.
VTM-4's ability to "lock" and to engage on acceleration makes it more versatile than, say, the Honda Realtime AWD on the CR-V. However, some AWD vehicles send at least 20% to the rears all the time (e.g. some Subarus), and some send 50-55% all the time (e.g. Audi quattro). The latter, coupled with traction control to eliminate wheelspin, eliminates the need for the "lock" mode.
I also had another problem and I hope I am not the only one. When driving through the snow storm (before the roads got too bad), I had my front defroster running to melt the snow on the front windshield. I noticed that as the snow melted from the windshield, it refroze on my windshield wipers, to the point where the wipers were not effective in cleaning the windshield. I had to stop numerous times and scrape the wipers to ge the ice off of the wipers. Its funny because i know this does not happen when i am driving my Camry. Did anyone else have this problem? Is this normal and can it be corrected?
The windshield issue is normal also, both my trucks had the same problem. I found the best way to handle it was to have the truck and inside completely warmed up...however not using the defroster, using the dash and floor vents. This way stuff hitting the windshield won't melt and then re-freeze. It was below 20 degrees at my house, so I had the same problem. I found the best way was to not use the wipers, sounds strange but it works. When I did have to use the wipers I had to also use the washer because of the same problem you were having.
Anyone know what type I need and where to get one?
I ordered roof rack, winter mats, cargo mat, running boards and burlwood shifter from hondacuraworld.com. No shipping cost, no tax, had delivery in two days and saved approximately
$1,000.00. Installation is fairly easy for roof rack and running boards.
I have been researching the MDX since it came out. It is a much better product than any Volvo! A comparabley equipped Volvo XC70 (wagon) is $40,400 compared to my base MDX at $36,200.00 and it is much smaller, less reliable and much less powerful.
A comparabley equipped Volvo XC90 (sport ute 268 hp engine with third row seat) is approximately $43,000.00 and it is also smaller and you have to wait. Reliability and maintenance cost with Ford, I mean Volvo, will always be a problem.
My MDX started being built earlier then scheduled (by 5 days!). I don't know how long it takes to build an MDX from start to finish and how long it takes to get shipped to the south. They started building it on 17 February so hopefully the wait will soon come to an end. Thanks for all the pep talks I will let you know when it arrives! Miks
It was only available for 2001 and I've only seen two in my area, which ironically is the Chicago area like yourself.
Unfortunately, these two people still own their MDX's and are not for sale.
Granite Green, Silver, and Black are much more common.
Regards, Jim
"The windshield issue is normal also, both my trucks had the same problem. I found the best way to handle it was to have the truck and inside completely warmed up...however not using the defroster, using the dash and floor vents. This way stuff hitting the windshield won't melt and then re-freeze. It was below 20 degrees at my house, so I had the same problem. I found the best way was to not use the wipers, sounds strange but it works. When I did have to use the wipers I had to also use the washer"
