A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Acura MDX (pre-2007)
The center position is much easier to use with a rear facing seat. I also find that with the handle in the correct position, you cannot move the front seat back very far with it installed on the side. However the latch system makes it so much easier to get a seat installed and tight, under 2 minutes. With multiple kids it is hard to get away from using the side position...the latch system makes the install seem 100 times more secure than the standard belt install. It is too bad there isn't a center latch position.
There is no transmission spacing requirement as far as I know in the MDX? or one in SUVs that would effect latch positioning? The MDX doesn't have much of a transmission in the rear being FWD based with the type of rear differential it has.
I heard you. I got 2003 MDX and found leaking at the similar location. It freaked me out since I got it not longer ago and it got leaked on the first heavy rain here in SC right onto the driver seat. I had done some exams and on/off a few times with cleaning up around the area making sure it was fully closed. Next time around, there was no leakage observed (the rain wasn't that heavy then). I suggest you cleaned around the contact area and make sure it is fully closed, especially during rainy days. Let me know what you find out from the dealer. Cheers!
I have the same doubt about the gas mileage. I have a 2003 MDX and my wife drives it mainly on local. We got around 13-14 mpg and it came as a shock especially with that kind of gas price in SC. The spec. actually calls out 17-23 mpg, so we got below what's rated. I am not sure it will improve over the time beside driving on freeway. I am as curious as you are. Cheers!
From what I've read from the lengthy NHTSA specifications for the lower anchorages, there is no spacing requirement between pairs of anchors. For an anchor pair, their centers must be 280mm apart (+ or - one mm). But there's nothing on the relationship between the pairs. NHTSA actually says:
A full child restraint anchorage system (consisting of the two rigid bars for the lower anchorages and a top tether anchorage) is not required to be installed in the center rear seating position because it may be difficult to fit the lower anchorages of two child restraint anchorage systems, or two child restraint systems, adjacent to each other in the rear seat of small vehicles. Further, a lap belt at the center rear seating position, together with a tether anchorage at that position, should perform essentially as well as a full child restraint anchorage system. For these reasons, and to minimize the cost of facilitating the use of the new child restraints in the third position, the agency is requiring two, and not three, child restraint anchorage systems.
Obviously, the MDX is not a small vehicle and three pairs would fit without difficulty because the three pairs of 280mm-spaced anchors would not overlap. NHTSA just allows manufacturers to get away with two pairs in the second row.
Thus, unfortunately, it is probably "cost avoidance" on Acura's and other manufacturer's part. Acura didn't even bother installing lower anchors into the 2001 MDX because it wasn't required by federal law yet, even though it was for 2002. Neither did Mercedes-Benz on the M-class, though Volvo began installing lower anchors in advance of federal regulation.
Not as nice as the easy disc loading of the dash changer, but at least you still get a changer when you order the DVD RES.
I have a Touring Navigation model.
The new Volvo has many sophisticated safety features but it will probably be rather unreliable in comparison with an Acura or a Honda, if history is a guide. Also, the 268 bhp turbo version gets only 15/20 mpg, which is considerably less than the MDX's 17/23. Still, for those who insist on safety curtains, the Volvo is worth a look.
Transpower
http://www.swedespeed.com/news/08_02/08_13_02_5/index.shtml
XC90 Advantages:
- Can divert "all power" to the rears as compared to the MDX's max of 50%.
- Has a true center differential.
MDX Advantages:
- Can force power to go to the rears, e.g. for extrication out of a stuck position. XC90 can't do that, it has to let the fronts detect enough slippage first.
- Proactively routes some power to the rears when accelerating.
Volvo's old systems would restrict front differential movement via computer and then a viscous coupling would transfer power to the rear...this was slow in the older XC's. While I think the function is the same (i.e. restricting front vs. simply adding/switching power) it supposedly does it faster now.
http://www.v70xc.com/xc90/articles/081702/volvo_xc90_electronical- ly_controlled_all-wheel_drive.html
Transpower
I had my MDX in with the dealer yesterday. They cleaned out the drains and then sprayed water on it for 15 minutes. They could not duplicate what I had experienced in the rain storm. I parked it out in the rain today for a few hours and it stayed dry. Hopefully the problem is solved. Will keep you up to date on any further developments. Thanks for your suggestions.
Using braking to manage traction on an open axle seems to be the preferred way to go because of weight savings and relative simplicity. Even the 2003 MDX finally addresses the front axle by using braking from VSA to manage the front (traction control). It still uses the VTM-4 torque apportioning to manage power in the rears, however.
Apparently the Volvo can send more than 65% of the power to the rear, at least based on that first article.
That all said, it looks like the MDX's system is more versatile than the XC90's. I don't think that having 5% to the rears during highway cruising provides any significant benefit. The MDX's extrication mode (lock mode) is a very nice feature.
In general, automakers make a lot of these warranty's because often they are not used. The scare is that if you have a major problem 2K miles after the warranty expires...it is then money well spent.
I prefer to keep it myself, and use it if I need it.
OT
Behind the third row (both seats up), there is 14.8 cubic feet. With both second and third rows folded, there is 81.5 cubic feet.
The near-50 cubic feet behind the second row is a good demonstration of SUV capabilities. E.g. in many minivans with five people aboard, you have to use the third row and that compromises cargo room. Whereas in a larger SUV you can sit three people abreast in the back, especially when they're kids or teenagers.
Vehicles like the Volvo XC90, ML320/350/500 and the new Lexus RX330 have very good cargo room with all the rows down, but they don't have comparable cargo room behind the second row.
I followed the instructions for both a standard and rolling code garage door opener and neither works.
When I press the remote close to the homelink transceiver to train the transceiver, it flashes slowly, sometimes stop flashing, sometimes stays solid, but never flashes quickly.
I erased codes 2x and tried to install both the regular and rolling code procedure 2x, to no avail.
The door opener is a Sears Craftsman.
Are there any other tricks to try, or is the homelink just not going to work with this opener?
thanks in advance.
There is no confirmed information about what's going to be in the 2004's.
Congrats on your new purchase!
Make sure that you voice your thoughts when you get a call from the Honda of America Company for a dealer survey. I guess Acura of Denville will not get a 5 rating from you.
Hope has it right - only on touring MDX. My 02 Touring Navi has a memory seat that does not hold the seat memory position well (mirror settings do hold). The settings seem to drift a bit and the memory must be reset every month or so.
It doesn't move off the memory setting very much, but the half inch is enough to notice. My other cars with seat and mirror memory held the settings, so even though the system checks out okay, it may be just my MDX and not generic to the brand.
I do agree that the XC90 is safer than the MDX, but according to most test results, its a real close call. Both SUV rated very high on crash tests, while Volvo may have a slight edge in a few areas. But you are paying alot of money for that slight edge, but then, that is Volvo's claim to fame while Acura spend their money on engineering and design instead.
What test results? What crash tests has the XC90 been rated very highly with? NHTSA has not tested the XC90 for both front and side impact. IIHS has only released the bumper-bash result for the XC90 (and it did poorly, though it's not a true safety test).
IIHS hasn't yet released the results of the offset frontal crash test of the XC90. Though it will really soon. Do you have advance information on the results?
As of this writing, the only publicly available crash tests for the vehicles are the (superb) crash test results for the MDX.
http://www.iihs.org/vehicle_ratings/ce/html/0113.htm
NHTSA is going to re-test the 2003 MDX with the front impact test, though the side-impact scores are carried over from the 2001/2002:
http://www.nhtsa.gov/NCAP/Cars/2022.html
I was using the crash test results from the S60,70,80 as a reference, since the XC90 is basically a modify version of those cars. The test results should be similar.
How can you be using "70" test results when the current V70 has never been tested by IIHS or NHTSA?
I do agree that if the XC90 is anything like the S80, or even an improvement, its test scores should be outstanding.
I wouldn't draw results from the S60 and say it's a close call, however. Fortunately the XC90 should score closer to the larger S80 than the smaller S60. The S60 did get a "Good" in IIHS but not a "Best Pick." The S60 only achieved 4-stars for the driver and passenger in the NHTSA frontal crash test.
Then, THANKS to this wonderful board and the reference of my dealer to my new friend in New York whom also purchased an MDX from my dealer, I was given a THANK YOU gift for the reference! My gift was the wood shift knob, wheel locks, cargo liner and the all-season floor mats!
I am a female that during this SUV shopping experience (and in past purchases) I have dealt with MANY male chauvinistic salesmen but this purchase was totally outstanding and I'm thrilled beyond belief not only about my great deal but the way I was *taken care of*. My dealer and salesman will definitely get more then a 5 STAR rating from me!
If any of you live in Ohio or are interested in working with the awesome dealer in my area... please do email me at L79D@aol.com I will gladly pass along the information.
Lidia
PS... To my New York friend... THANK YOU and I know you will be just as happy with your purchase and ownership as I am with mine
However we often make very short trips, under 5 miles. In that type of driving the mileage drops to 15+.
Is the air cold and just not going where you want? Or is it just not blowing cold air? Did it work last year?
Either way it sounds like a potential trip to the dealer, but I would investigate and try to pinpoint more details first. Dealers aren't always the best at troubleshooting. It might be as simple as a needing a recharge?
I've found it is slow to cool no matter what the temperature setting is. Full auto mode usually produces gale force winds and a lot of noise, but no faster cooling. I checked the outlet temperature of the air and it is actually on the cold end of the specification - once the car is not in stop and go city like traffic. It appears to take a little bit more than a thousand rpm (engine) for the A/C to work well.
I've 35K miles on the car now and the average gas mileage is about 18.5 over the last 5000 miles. I just made a trip to Toronto and the average mileage was about 23. City mileage is awful since car is heavy and is really dependent the kind of 'city' driving you do. I find the MDX gas mileage is comparable to a minivan and I have no complain.
Mpg has been slowly improving. Approaching 15,000 miles and have seen average mpg slowly increase from 15.7 for the first 3500 miles to 18 for the last 3500 miles. Like you, I have no complaints about the mpg.
My V6 MDX gets about the same mpg as my 4 cylinder PT GT and the V8 Jag the PT replaced, but about 25% less than my Avalon.
