Acura MDX (pre-2007)
1104105107109110125
  • prijayprijay Member Posts: 26
    Just got my Silver MDX last weekend and wanted to know if there is a way to put on the high beams when using the auto mode for the headlights? When i pull the lever towards myself the hi beams flash for as long as i hold the lever but once i release it goes back to low beams.
  • spfoteyspfotey Member Posts: 131
    Has anybody leased an MDX using a one payment program -- where u pay for the lease up front??
    if so -- who did u work with??
    thx
    scott
  • wantanmdxwantanmdx Member Posts: 2
    I'm looking to place an order on a 2004 MDX. Would appreciate input on the delta between the Premium stereo and the one in the Touring edition.
  • rerenov8rrerenov8r Member Posts: 380
    but unless they made RADICAL changes to the unusually low quality speakers (even compared to other less-than-exceptional Bose stuff) the Touring package sound be considered for anything BUT the sound system.
    The speakers are _J_U_N_K_ -- literally the kind of thinq that you'd expect only in a bottom of the line boombox from a no-name maker. Worse, they use low-impedence voice coils so that they can OVERSTATE the amp power (which means when you DO put quality speakers in you will need to upgrade amps too...).
    Granted, the other features are not earth shattering, but the power passenger seat, memory system, auto wipers and similar trinkets just BELONG in a lux/near-lux vehicle...
  • wmquanwmquan Member Posts: 1,817
    No one knows, and we won't really know until 2004's get on the lot and people can perform some comparisons.
    All we have on paper is that the 2004's Touring System has been "improved." These improvements are all on paper and who knows what the audible result will be:
    225 watts (up from 200)
    "new tweeters"
    new "high power neodymium magnets" in the front and rear doors for "higher output" and a "stronger and deeper bass"
    higher power rear twiddler
    It's still a Bose system ... you know the old saying: "no highs, no lows, it must be Bose!"
  • hopeitsfridayhopeitsfriday Member Posts: 396
    The stereo system in the base model is made by Harman kardon, a very good stereo brand. It is a 100 Watt system compare to the Bose which is 200. To be honest, anything above a 100 watts in a car, you will hear very little difference, unless you like to turn the volume to earth shaking levels. The Bose system comes with a 6 CD changer, not a big deal, since you can burn your own CD anyways. I have a base system which I spend a hundred bucks and an hour to upgrade my speakers. After I upgraded it, it actually sound better than my friend's Bose system in his TL which is similar to the MDX touring model's Bose system. This is the funny part, after he heard my system, he upgraded his speakers a month later and his actually sounds better than mine now, but not by much. In conclusion, the Bose system alone is not a good reason to buy the touring model, at least not at a price tag of $2600. Most people buys the touring package because they wanted the Nav., rear view camera or RES system that Acura do not offer with the base model.
    One of the touring package features I liked was the power memory seats/mirror. My wife is smaller and for her to get a good/safe driving position with the right distance from the airbag, etc. is time consuming, especially with the multiple ways to adjust a power seat (manual seats are easier because they are forwards or back, that's about it). It is great to open the door and have the seat return to your preferred position.
    I think the stereo is good. I haven't spent a lot of time examining it, however I think it sounds decent and covers a pretty good range. Could it be better? Sure, but for a OEM setup it is decent.
  • harjitsharjits Member Posts: 35
  • stnbrntstnbrnt Member Posts: 2
    were can i find aftermarket lighted running running boards for 01 mdx
    But I did seem quite a large number of non-OEM parts for the MDX in the JC Whitney catalog. They've got mats, deflectors, cargo area covers, and more 'stuff' than you would expect for a vehicle that is relatively low volume compared to the Explorers/TBlazers offered by the domestics.
    Worth a call...
    BTW, I am going to disagree with hopeitsfriday on audio power requirement.
    First, the Bose rating is at 2 ohm, that is generally 4x the power required at 8ohm. Second, you have MORE speakers than a typical home stereo -- though it is only two channels of audio signal you have the rear seat speakers, the sub woofer, and 'twiddler' for the third row. Third you have road noise. Even with the moonroof shade closed and all the windows tightly closed there is more noise than most homes. Next, consider the less than optimal location of the speakers -- the front speakers are aimed basically at your shin. Consider too the highly padded/carpeted interior -- no way to get some 'reinforcement' from positioning speakers to fire from a hard surface. Finally, the power required to drive a small speaker in free air is very much higher than the power requirement of a large sealed box or horn driven speaker. Is 100W really needed? With optimal design that could be sufficient, but the real world shows more is better...
    I think you miss my point, I was simply trying to emphasize how crappy the standard speakers are in the MDX, even in the touring model.
    It doesn't matter if the system is 2 ohms, 4 ohms or 8 ohms. 100 watts is 100 watts. Since Watt=ohms * current square. If the wattage is the same and the ohms go down, the current must go up. Since speakers are inductive device, more current means better sound, and BTW, twiddler takes very little power to drive.
    Of course more power is better, but what is enough for the average driver. I like to be able to close all my windows and hear a loud and distorsion free sounds from my speakers, thats all I am after. But if you are the type that like to hear very loud music with the windows open, very heavy bass so that the car next to you will hear loud and clear what you are hearing, then you will need 200 watts and more. The carpeting actually helps the accoustic, it prevents echos. As far as sealed box, there is very little air movement inside your car doors. A near optimal design audio system in the MDX would mean just better speakers. As far as the speaker location, you really dont want a 100 watt system blasting right next your ear.
  • andrewtran71andrewtran71 Member Posts: 840
    How do the dimple seats look after a few years?
    I was going to say "leather seats", but I heard it's not all leather.
    I can't believe they still keep on making that kind of seats on a luxury vehicle, or is it a luxury vehicle?
    I noticed Lexus does not use dimple seats on their SUVs.
    Are you sure the side curtain airbags are for ALL THREE ROWS?
    Who is actually saying this? Honda/Acura or somebody else?
    I don't see anywhere on the Acura site that says the side curtain airbags are for ALL three rows of seating.
    If they made side curtain airbags for the 3rd row, did they also make the 3rd row leather instead of polyester or whatever fake material they use?
  • misc535misc535 Member Posts: 17
    Go to <http://www.hondanews.com/Forms/acura/MDX/*ws4d-db-query-Show.ws4d?*ws4d-db-query-Show***004697***-wieck_media***-***acura(directory)MDX(directory)***.ws4d?acura/MDX/results(r)_text.html> to see full side curtain air bags for all 3 rows. You can also use that web sites to see all of the changes for 2004, along with MSRP pricing and photos.
    Most manufacturers use leather on seating surfaces and different materials on the sides. I believe dimpling is more of an aesthetic item.
  • aggiedogaggiedog Member Posts: 238
    You can also go to acura.com and click on MDX. It clearly reads that they cover all three rows.
    Has anybody started dealing for a 2004? What kind of deals are people getting?
  • rhhennerhhenne Member Posts: 6
    I have ordered a 2004 and the best deal I'm getting is $700.00 off MSRP. That pretty much makes up for the increase cost in the 2004 model.
    This is a Chicagoland dealer.
  • dave210dave210 Member Posts: 242
    May I ask what Chicago dealer you're dealing with? I have a 2003 MDX from Acura of Libertyville and they were great, but at the time no one was offering any money off, so I ended up paying MSRP. I'm fine with that though, because at the time, some dealers were still forcing options.
  • xerrtoxerrto Member Posts: 11
    Any info and when the new nav dvd will be released?
    Why don't you call your parts department?
    Has anybody purchased, used, or know about the handsfree cellphone interface?
  • transpowertranspower Member Posts: 213
    Today's Wall Street Journal (p. D7) lists the 11 hottest models for September. Five of the models are from Honda Motor Company! Here they are: Honda Pilot (1st), Honda CR-V (6th), Acura TSX (7th), Acura MDX (8th), and Honda Odyssey (9th). This is certainly a testimony to the superb capabilities of Honda and Acura vehicles.
    Transpower
    I'm getting deal of $800 off MSRP(41700) + Protection package from a dealer in Connecticut. This was the best so far after I called lot of dealers. Most of them wont talk about anything less than the msrp price.
    Anybody doing better than this in Southern New England, I'm willing to travel upto 200 miles for better deal than this. I can give my mail id if someone has better offer...
  • carman36carman36 Member Posts: 14
    Has anyone seen this new 2004 color???
    What do you think?
    Also, has anyone seen below MSRP in NJ/PA?
  • mhenderson1mhenderson1 Member Posts: 164
    I have a 2003 Base model MDX (only 11, 000 miles). Recently I noticed that condensation has been building on the inside of the ddriver side headlight. I'm thinking that there is probably a hole somewhere in the insulation. Does anyone know how I can get rid of this condensation. I've tried leaving the lights "on" when driving to see if the heat from the light will make the condensation dissipate, but for some reason, it has not gone away. I have recently scheduled an appt with my dealer to check it out. Does anyone know if headlights are covered under the warranty?
    I also have discovered that the rear side window behind the driver tends to rattle when the window is placed down by at least halfway. Has anyone else experienced this on their vehicle? I'm hoping that the dealer can correct this as well.
    I noticed that same problem last year. It went away by itself after a few months.
    Transpower
  • ukkonen7ukkonen7 Member Posts: 22
    I do not know if anyone else is having problems but I thought I would share a couple with others on the MDX site.
    A couple weeks ago I had a new transmission put in under warranty. The transmission was shaking at low speeds in 5th gear. Now the check engine light has been going on and off. Now, also, the VTM-4 light has also come on. There is 45000 miles on my 2001 MDX touring. The lease is up in December. I have an appointment next week but the dealer is 160 miles away. Another trip!! How much now???
    I am NOT a happy camper... Something else for some of you to consider.....
  • habitat1habitat1 Member Posts: 4,282
    Do you know if the MDX 5-speed transmissionis the same one that's used in the Acura TL? That forum is filled with folks who are on their second and third transmission. I am seriously considering a Pilot or MDX shortly and would want to make sure I wasn't buying into that problem.
    Thanks for your post and please let us know the final outcome.
  • fndlyfmrflyrfndlyfmrflyr Member Posts: 668
    The MDX tranny was re designed for the 2003 model. The transmission in ukkonen7's MDX (post 5546) is not the same as what is sold now.
    The current transmission in the MDX is new and I suspect it may be the same in the Pilot. I am also considering the Pilot instead of the MDX. The price is better and the few toys less is not an issue with me. Good luck.
    The 2001-2002 MDX had a transmission that is based on the same problematic transmission in some other Hondas/Acuras. Thus far Honda hasn't said that those have issues and thus hasn't extended the transmission warranty on them. Supposedly the MDX transmission is a "beefed up" version for AWD and towing, with a similar design but some parts more heavy-duty. The part numbers are indeed different (on another forum, someone uploaded detail schematics and the diagrams).
    I think that the 2004 Pilot has this same transmission.
    Starting with the 2003 model, the MDX got a new, redesigned, "compact" transmission. I've seen the schematics for it and it is dramatically different than the previous ones.
    I've noted some problem reports on the 2001-2002 MDX transmission, as well as a few on '03's, but thus far I don't see any frequency similar to that afflicting the previous-generation TL and other problem models.
  • chrism124chrism124 Member Posts: 134
    I am looking at purchasing a 04 MDX Touring. The first question is regarding the Nav system. I am not sure if this option is worth the roughly $2k price increase. The dealer did not have one on the lot for an honest evaluation. Looking for opinions from current owners of the Nav, do you find this a useful feature or just an expensive toy? For those owners that didn't get the Nav, did you have any regrets?
    The second question is regarding color. Both my wife & I saw an MDX with the Sage Brush Pearl paint. We both liked the color but we where unable to see the interior color, being Quartz. I am looking for opinions as the dealer only has black, white or red with the black or sand combinations.
    Chris
    Thought the Nav would be just a toy. In fact, that is what we called it at first. Except for the fact that it is nice to have the screen in dash, a laptop with the appropriate software and gps ant. is a way to get more bang for the buck.
    We use the Nav frequently, mostly around town. Never expected to use it for anything but trips out of area, but find it very handy locally. It would be awkward for us to use a laptop for a nav unit and we don't need the laptop for DVD movies for young kids, so we prefer the factory installed unit.
    Looked at a Prius the other day and would spend the extra money to have a Nav unit in it even though the MDX would remain our trip car. The only reason our PT GT doesn't have a nav unit now is that the Chrysler unit doesn't have a touch screen or voice commands (uses a joystick instead). The Chrysler nav is similar to the Acura nav. Both are Alpine and display the same as far as I can tell. Looks to me like they have the same or very similar data bases too.
    In short, you can easily get along without a nav unit. However, I've found that once we started using one we want one in each car. A side benefit has been that it makes it much easier for our new teenage driver to find her way, especially at night.
    I have a 2003 Sage Brush Navigation MDX and love it. The color is like a chameleon and changes depending on the light outside.
    The Nav is great and didn't think I'd use it, but for example, I went to my son's college parent weekend and thanks to the nav, we found our way to a fraternity dinner, a place to eat on Saturday on a whim, and where the closest ATM was.
    Is it worth $2000? I don't know, but I'd surely buy it again and never a car again without it. Plus the MDX back-up camera comes in handy to see if obsticals are behind you or help with parallel parking.
    I say go for Sage Brush and go for the navigation! ;-)
    How do you like the Quartz interior? Does it match well with the trim pieces (such as the fake wood)? This part is unknown to me as the dealer only has Sand and Black interior versions.
    Do you find the information on the Nav DVD is accurate? Also I noticed the standard screens could not be seen if you are wearing polarized sunglasses. Does the voice command interface help or do you still need to use the touchscreen.
    Chris
    I like your suggestion and that's exactly the color/configuration I am considering for a 2004. I am trying to find one to look at, as it seems the Sage Brush isn't very common. I only wish it came with the black interior.
  • metmdxmetmdx Member Posts: 270
    To my knowledge, quartz is only interior available (per the Acura website). Has something changed and they didn't tell us????
    metmdx
  • cmp1960cmp1960 Member Posts: 5
    Trying to craft a deal that includes an extended warranty. Can anyone tell me what a good price for an Acura 7yr/100K, no deductible, runs for a 2004 MDX with NAV? or if there are any authorized Acura websites that sell the warranties at a deep discount.
    Also, for the 2004, has anyone noticed how the rims seemed to have a flat look to them?
    You are correct, the Quartz interior is the only one offered with the Sage exterior. My concern was that none of the local dealers had one that I could see. I did see the exterior color as one drove by me but I have yet to see the Quartz interior. My earlier post was to gauge response, favorable or otherwise, on this combination. If I do not go with Sage/Quartz than it will be Red/Sand.
    Chris
    Go to <http://www.curryacuracare.com/index.cfm#> for the best deal that I have found on the web. For a new MDX, 7yr/100k warranty with $0 deductible is $1,690, after $90 discount. Someone told me that cost is approx. $1,600; true, false? I would be happy to hear of a cheaper genuine Acuracare warranty, as I am in the market for one as well.
    Quick question here:
    I notice that '04 touring model has drivers power lumbar. Does/Did '03's have power drivers lumbar or manual.
    tia,
    metmdx
    The driver's lumbar in 01-03 is manual. The '04 has the power lumbar as a new feature.
    Thanks for the info !
    metmdx
    Just got my MDX back this weekend from having the front headlight replaced due to a leakage in the seals. I also had my rear window looked at because for some reason when I lower my rear driver side window down about half way, the window starts to rattle when i go over bumps or when I reach high speeds. The dealer service told my that they could not heare it rattle (as is always the case) and that it may be my fault for having put rain vent guards over the window frame. I immediately told them that the window was rattling before i put the vent guards on, and what should it matter if the vent guards are not touching the window. Dealers seem to hate to repair something which is covered under warranty. The dealer then proceeded to tell me that the window is normally that way. I could not accept this for a vehicle costing over $35,000. If this was a Chevy, maybe, but an Acura. I was then told that the mechanic placed some lubrication down in the window, but now the window is cloudy from this lubricant smearing the glass.
       Has anyone else had this problem with their back windows? I havent't heard anything yet, but i may take it to another dealer for servicing if I hear it again.
    I feel the Quartz interior is a nice median between the black and saddle colored interiors.
    I've had saddle colored interiors before and they tend to show a lot of dirt and wear, at least on the carpet and leather seats. And black is very dark and tends to show all the lint and hair on the carpet and get hot.
    The Quartz is a tastefully done two-tone with black dashboard, steering wheel, etc with what I would call "gray" seats, but my wife insists on calling them light Quartz (She called the interior of our old mini van Taupe (which is what Chrysler called it) but I just called it gray. The interior is definitely lighter than Taupe.
    The wood trim isn't a problem. The fake wood is what it is and it looks no worse in my opinion on any other color.
    As for the navigation being up to date, I feel it is. It is missing some restaurants that have been around for a couple years and a new development built a two years ago isn't there, so I feel it's very comprehensive but not exactly 2004 material... more like 2002 material in terms of data.
    I wish I could show you people pictures of the interior of my car at another website for the MDX but I guess I can't put in a link or refer to it.
    Maybe go to a search engine and look around.
  • popejohnpopejohn Member Posts: 11
    I have the '03 with sagebrush/quartz interior. I agree with dave210 that it is a good compromise between dark and light. The dash is dark and gets even darker if you put a preservative on it. I like the look of the lighter quartz (gray) seats. I had a dark car with black interior before, and it got very hot in the summer.
  • smarisettismarisetti Member Posts: 1
    I paid $1680 for 7 yrs/100k extended warranty for 2003 Acura MDX. I was looking around to see if this is a good price. I have a week to cancel if I feel I paid too much. Let me know if this is the right price or if I have paid too much. Thanks.
    I have no point of reference...however with a honda product I would rather put the $1600 in the bank...well interest returns are small now...but in somekind of investment and then pull it out if I needed it to fix the car. Invest in yourself. It is an insurance policy...if you invest in a 5 yr CD? Perhaps you get a good return...and then if you need the money for a repair you have it...if you don't need it...you still have your money...that is my $0.02
    I'm not sure whether or not $1,680 is a competitive price, but I have to question the rationale/economics in general.
    The extended warranty effectively covers UP TO 3 years (5-7) and 50,000 miles (50k to 100k). That $1,680 seems like a high price for covering a period between when any intial bugs or defects would have surfaced (and been covered by the standard warranty) but long before a vehicle like an Acura MDX would/should show serious wear.
    I have a 1995 Maxima that, between 3 yrs/36k miles and 7yrs/100k miles had absolutely no repairs that would have been covered under warranty. I would think the current crop of high quality Japanese cars and SUV's would have relatively little probelms between 50k and 100k, especially considering that to get to 100k in 7 years, you likely need to do a fair amount of low stress highway driving. If you were offered a 10 year/120k mile extended warranty for the same price and you were doing a lot of stop and go driving, I would have a different opinion.
    Extended warranties are a great money maker for the issuer. I believe I saw a Consumer Reports article that indicated fewer than 30% of buyers have any claim under the extended warranty and fewer than 10% have claims that exceed the amount they originally paid. The article suggested that 90%+ of buyers would have been much better off to have put the money in a bank account; especially Japanese model buyers.
    I would buy an Acura MDX (or Honda Pilot) in part because of their strong reputation for durability and reliability. If I really thought I needed an extended warranty to protect me from 50 to 100k miles, I'd probably be looking at a different vehicle.
    P.S. A friend who owns a 1997 E420 paid a similar amount ($2,100) for an extended warranty that covered the replacement of his transmission and other odds and ends that would have cost him over $5,000. But that's a $50k Mercedes with a reputation for needing expensive repairs.
    Here my 2 cents worth about extended warranties...Its a insurance policy, If you do not have the extended warranty, chances are you will not spend more than the policy itself for repairs during that extending warranty period. That probability is a little over 50 %. Thats How the insurance companies calculate the rated. It might be in the range of 60% or 70%.
    I had very good luck with both extended warranty on my last 2 vehicles. A 96 jeep grand cherokee and a 89 Toyota 4 runner. Or should I say bad luck, both vehicle got repairs over the extended warranty price. The jeep's about $2000 over and the 4 runner about a $600 over. One have to keep in mind that these 4 wheel drive vehicles are very expensive to fix. Usually, 1 major or 2 minor repairs will put you over that extended warranty price. I bought the extended warranty for my 03 MDX as well. I got a good deal, 7 years, 80000 miles for $1150. The salesman was a friend of mine.
